Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Hello, I have a GE Profile side-by-side (see below). If the water supply to the ice maker is turned off (vac home), but the Ice maker is left on - - will that damage the ice maker moter? Is there any risk to the refrigerator? PSC23MSTSS, GE Profile CustomStyle? 22.6 Cu. Ft. Side-by-Side Refrigerator with Dispenser) Thanks, -John
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
You can possibly burn out the solenoid valve. There is an off position on the ice maker itself and possibly a switch to turn the power off to the IM.
Posted on Dec 08, 2008
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
No water entering ice maker.
Replace the solenoid valve , the piece the wall water line connects to , on the refrig . With both ice maker AND valve replaced , that is the complete ice production new .
Jan 01, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
Frost build up in freezer (ice maker section)
Your ice maker is overflowing and asking for to mush water to make the ice, you may have a real hi water pressure on your water supply
the is a easy way to adjust that but you are going to have to take
your ice maker out
then using a flat head screw driver remove the white square cover
you will see a gear and a adjustment screw and a lever like this
( - I + )
turn the screw to the minus sing a quarter way and install the ice maker back up.
Or a easier way is just closing the water valve before your fridge a little so it wont have so mush pressure and will not fill your ice maker so fast.
the ice maker feel up buy time not buy water level.
Jun 28, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Mar 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Water supply to ref is turned-off, will that damage the ice maker
no there will be no problem the valve works with the water pressure. on the electronic side the switch just tunrs the power on and off to the valve, no problem there, thats what is made to do.
Dec 08, 2008 | GE Profile PSW26P Stainless Steel Side by...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
346 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
