Question about Toshiba Portege M400 PPM40U01000E Tablet PC
How enter to bois
My OS is damge I want to install new windows I started by smartdrive blue screen stop installaion how to configure sata or how to enter to bois
  • 624 Answers
Fadeel, You enter the BIOS on the M400 by pressing the ESC key during the POST operation. Let us know if you have any other questions and please don?t forget to rate this post.
Posted on Feb 24, 2007
How do i get to windows boot manager
Step 1 Turn on your computer.
Step 2 Press the space bar on the keyboard immediately after the BIOS screen appears and before the Windows logo screen appears. Press "F8" to access the boot options.
Step 3 Select an operating system to boot and press "Enter."
Jan 29, 2018 | Lenovo ThinkPad X200 Tablet PC
Windows cannot find any hard disk.This error comes whil i install window xp on my hp dv2001 laptop
shutdown your laptop. start it press f10 to enter bios. after getting into bios goto security then find sata native support .disable it try reinstalling windows.
Dec 30, 2010 | HP Tablets & eReaders
I have a panasonic toughbook cf18KHHZBZZ with 60 GB HDD and when i turne it on i get the panasonic screen.....the xp windows screen.... and then a black screen with only the mouse pointer to work but on a...
OK, you don't need to format. You can insert the CD and restart. You can ask to install but then the computer will say you already have a OS installed. You can press R to repair the OS. Your computer may have a recovery method. Some vendors don't give you a CD but recovery system is fed into a separate partition of the hard disk. See the documentation and check whether you have such a system.
Please feel free to ask for advice any time.
Repairing a OS is quite safe. You will not loose any software or updates.
Remember, don't press R at the first screen where you are given a chance to go to recovery console. There is very little you could do there. First ask to install then ask to repair the existing one.
After repairing the system, the first thing you need to do is to install a reliable Antivirus Software.
Aug 31, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
Acer travelmate c110 blue screen , how to fix it
If windows won't boot and if you have tried the safe mode and "Last Known Good Configuration" mode, then try the procedure below and repair the windows installation files.
Windows Start-up Errors
Step one, you need a Windows Installation CD. If you only have a recovery disk set like the ones from HP or Compaq they will not do what you need done. Under normal circumstances however, you can use a Dell disk because the Operating system is on a stand-alone disk. All retail versions are also acceptable as well as upgrade disks. For a rule of thumb, if the disk has the Microsoft hologram it should work.
While the computer is first starting up and you see the manufacturers splash screen, tap F12 (some computers it’s F9, others it may be another key, you may have to watch and see if the computer lists the key strokes for getting to the boot menu. If you still cannot find it, boot into the BIOS settings and change your boot order there. Save your settings and exit, the computer will now seek the cd rom as its boot source first.
Place your Windows disk in the computer and start it up. When you see the test at the top of the page “Press Any Key To Boot From CD” Just hit the space bar to activate. The next screen you will see will most likely be a Windows setup screen, when you see this press the “R” key to get to the recovery console. It will get there, it may take a little time, patience. Once it loads you will be given a choice of Windows installations, there should only be one, if there are more, always pick number one. It may ask for an administrators password, if you have not set this particular password, then just leave it blank and press enter. The next prompt you see is:
C:\Windows>
You need to type the following:
cd \
hit enter. Pay close attention to the spacing between the characters. There is a space between the character “d” and the “\”
You are now at the ROOT of the drive, this is where basic commands can be given and changed. You should now see the following:
C:\>
Now type the following:
CHKDSK /R
Hit the enter key.
The chkdsk /r command also includes the P command and will also look for lost recoverable information in bad sectors.
There are occasions depending on how corrupt the system is, that this process could take several hours, so be patient with it.
Now, after chkdsk has run type the following:
FIXBOOT
Hit the enter key.
It may prompt you with a warning, that’s ok, just continue. When fixboot has finished, type: EXIT hit enter and windows will reboot. When the system reboots, tap the F8 key during this time and you will see the multi-boot menu come up. Scroll to the title “Last Know Good Configuration” and hit the enter key. If you were having some simple drive errors this should have fixed them.
Jan 15, 2010 | Acer TravelMate C110 Tablet PC
O*oooooo7b(0*f7a21524,0*c0000034,0*00000000,0*00000000)
If you can install Windows Vista and only XP not work for sure this is the solution :
SATA operation mode is AHCI
To change this :
Open BIOS
Look for SATA Operation Mode or somethin equivalent and change-it to IDE or Compatibility Mode.
Jul 19, 2009 | Compaq tc4400 Tablet PC
Installation of windows xp to toshiba satellite 1695CDT
10gb of RAM is not enough for Windows XP. You need to upgrade your HDD to about atleast 40 GB HDD Minimal... I'd recommend a new PC if you can get that to work out, but I understand the tuff economical times.. If you need any mroe help ..throw me an email at joey@joeysitservices.com I'll give you some bootable tools that may help!
Apr 16, 2009 | Toshiba (K000680310) for Satellite...
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
Dec 20, 2008 | Compaq tc4400 Tablet PC (RL875AW#ABA)
Toshiba Portege M400 PPM40U01000E Tablet PC Logo
303 people viewed this question
Top Toshiba Tablets & eReaders Experts
k24674
Alun Cox
micky dee
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
