Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag Gemini bottom oven not working
MRG6772BDS Maytag Gemini----The bottom oven will not heat up. There are no error signs and everthing else works fine. It stays at 100F.
  • 1 more comment
  • Anonymous Dec 13, 2008
    same problem with my lower oven. not heating. top oven is fine.
  • jjfrain Jan 21, 2009
    Gas stove with same problem. Cooktop works, top oven works, but bottom oven just shows 100d but does not heat. Cleaned oven about a week ago.
  • fredlongo May 13, 2009
    My bottom oven works but the top does not.
Both ovens on my new stainless steel maytagmgr6775 not heating up.............
Posted on Dec 11, 2010
My electric maytag gemini lower oven i not heating up but I do not get any error codes
Pull the temperature sensor and check it with a multi-meter. It should read 1100 Ohms. Post back your results.
Dec 21, 2012 | Maytag MER6772 Gemini Electric Kitchen...
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
I have a maytag gemini double gas oven and the bottom will not heat up. modle # MGR6775ADW. what might cause this?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Aug 26, 2011 | Maytag MGR6775A Gas Kitchen Range
Our gemini stove's bottom oven will not ignite
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 13, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oven not working Maytag MGR6875ADS
IF THE RANGE IS DOING EVERTHING BUT HEATING THE OVEN IT IS MOST OFTEN THE IGNITOR
Jul 19, 2009 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Jan 16, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Bottom oven does not heat
i ceertainly think that there is problem with the burner. as per the working principle of an Oven the ignitor is doin its job so the problem is with the burner please do check it out...
Nov 25, 2008 | Maytag MGR6772 Gemini Gas Kitchen Range
Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Oct 25, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini top oven, the bottom element does not get hot. I replaced the element with a new one from maytag. what is the problem?
Hello jrlibs
Welcome,
You said, Your Maytag Gemini top oven, the bottom element does not get hot. You replaced the element with a new one from Maytag. Asking what is the problem?
1.What is the model number and the year of your Gemini Range?
2.Was there an error code that came up before you changed the heat element?
3.If yes what was the code?
4.Did you check for current in the connection leading to the element before you installed the new one? Or just plug it in hoping for the best?
Waiting for your reply!
Huuum
Oct 16, 2008 | Kitchen Ranges
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
2,284 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
