Question about Zebra LP 2844 Thermal Printer
TLP 2844 skips 15-16 labels then prints intended label
Using 2.25"x.75" labels (direct thermal)
Using Parallel Port.
Labels will advance one label at a time when using manual advance.
When either of two of our programs, the printer will skip 15 -16 labels and then print desired label slightly off center. (Utilize several other TLP- and LP 2844 on programs without issue).
Perfomed Dump which looked to used 4 labels to calibrate, 16 blank labels,Serial Page Info..PageMode, 16 Blank labels, FMem info, 15 blank labels, S3...Option info, 15 labels, Now in Dump...Feed to Exit, 15 blank labels, and then Out of Dump message.
Have checked and verified all Printing Preference parameters.
  • radams97 Dec 08, 2008
    Another clue -
    When comparing Status Print outs to other working units the Reference Point value appears to have larger value:
    Working Unit -> R210,000
    Extra Label Unit -> R208,2561
    Loaded factory defaults but value remains the same.
    Would updating firmware help this situation?
    Is there a procedure to change this value?
It sounds like they may need to set their "Q" values for the labels they are using.   If that isn't it, we may need more info - are they using Zebra brand or custom labels?
To start with, I would ask them to try adding these "Q" value commands: q456 Q152,24
If that doesn't work, then maybe they can provide the other info mentioned above so we can understand the problem better.
Posted on Jan 05, 2009
Everytime i turn on my zebra tlp 2844-z it prints 2 blank labels.anyone please help me to solve this problem
Are you using the correct labels?
Direct Thermal Printers use different labels than printers with ribbons.
If you print a label using labels from a ribbon printer in a direct thermal printer they will come out blank.
Jan 28, 2011 | Zebra TLP 2844-Z Thermal Label Printer
Using tlp 2844-z
hold the green feed button down intill it flashes 4 time to default the printer and calibrate it
Apr 07, 2010 | Zebra TLP 2844-Z Thermal Label Printer
We are in need of thermal printers and Zebra LP
The LP2844 can only print on Direct Thermal labels.
DT labels have the ink within the label and the labels react to heat. If these labels are to be exposed to direct sunlight they will eventually turn black.
If you scrape the label with fingernail you can usually see the black ink on label
The physical size of the labels is this max width 1 inch (MInimum) to 4 inches (Max). Maximum length of label depends on the amount of memory in printer but maximum size for standard LP2844 is 11 inches. With full memory can be 22 inches long.
The labels must be on a 1 inch core.
These printer can handle all label types.
1: die cut Labels - Use gap sensing.*
2: Labels with Black mark on back - Use Black mark*
3: Continuous roll - select continuous *
* Select in printer driver media setting
Use the latest ZDesigner Driver V1.5.10
Download from Zebra Website.
Printer Preferences - Advanced Setup - Media Type.
Dec 02, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Issue with my TLP 2844
Check that your ribbon core is installed tightly onto sprocket guides. Push on firmly.
Jul 09, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Trying to Print USPS Labels from PayPal on TLP 2844
see if you can set the printer preferences to borderless printing.
Jun 14, 2009 | Zebra Eltron TLP 2844 Thermal Label...
Cant print on butterfly label with Zebra TLP 2844 printer
This is a problem of label sensing.
You are probably using the Gap sensor on the 2844, unfortunately the shape of the butterfly labels means you are sensing the wide gap between the labels in the centre, so it will not print anything in the apparent gap area on both ends of the label.
What your label or system supplier should have done is supplied you with the same labels but with a 3mm wide black mark on the underside of the label backing paper, centred between the labels. You can then change the printer sensor setting in the driver to Black Mark. You will then be able to print anywhere between the black marks.
Any problems with this contact us directly at Lancer labels Ltd
Nov 28, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Zebra 2844 print blank page
Possibly because the button does not work, causing the advance of the labels. Replace it.
May 13, 2008 | Zebra Eltron TLP 2844 Thermal Label...
TLP 2844 skips over labels
The first thing I would do is to default the printer then run a width calibration. The instruction are in the user's manual that should have come with the printer. If the instruction did not come with the printer I can provide the instruction.
May 07, 2008 | Zebra TLP 2844-Z Thermal Label Printer
Problem printing on Glossy Label [butterfly label] using Zebra TLP 2844 EPL
You must make sure that the ribbon is compatible with the label you are attempting to print on. It must be a permanent resin. We use the AXR7+ material. Try to avoid using such a high printer head temperature as this will reduce the life of the head.
Dec 26, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP 2844 Thermal Printer Logo
1,335 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
