Thomson DTI 6300 Digital TV Recorder freezes
When I go to the programme library the box freezes and I get nowhere. I have to pull the plug out and start over. It's driving us nuts and has already spoiled one series recording (which is where the problem started I think)
  • 1 more comment
  • jdaga58 Dec 21, 2008
    I am having the same problem, don't know what to do about it though. If you find out let me know.
    J.D.
  • Anonymous Dec 23, 2008
    io'io;
  • darthhall Jan 06, 2009
    I have a similar problem, I recored a programme that should have been 25mins and it came up as 58mins. Now every time i go to the library section the box freezes and I have to turn it off at the socket.
Try this forum http://kafkasworld.com/phpBB2/ they have tons of stuff on thomson dtis
Posted on Dec 21, 2008
I've been taking mine to my local TV repair man who fixes quite a few set top boxes and knows this one well. Not enough power getting to drive, somet to do with blown capacitors (if I remember rightly).
Posted on Dec 02, 2014
No programme guide or Synopsis
try going to menu > set-up > box settings and then change the TV Guide type to the Freeview 8 day guide.
Nov 15, 2013 | Televison & Video
Playback of Topup TV Sky / ESPN Recordings
I am just guessing but you may have an ant-copy signal embedded into program signal causing to when you are trying to look at a recording to another source. If that is the case then there is one way that would work. You need to connect inline with the video line out to the in of the other unit (yellow) and that would solve the problem. Go to xdimax.com and check out a dimax signal adaptor( can not recall what it goes by,description-wise) This is almost like trying to use a hdmi output and a audio/video connection at the same time.This also happened when doing the same with some video decks (vcr)
Sep 02, 2017 | Thomson Televison & Video
Hi, Please can someone help? I can not find my manual for my Thomson DTI 6300 does anyone have the codes for a toshiba tv?
0538 0090 1538 0065 1319 0066 0100 0132 0744 0271 0247 0139 0225 0221 0648 1938 0039 0067 1194 1193 0748
These are the list of codes to try for your toshiba tv for connection to thomsoo dti 6300.
Hope i`ve helped
Dec 04, 2009 | Televison & Video
Thomson dti6300-16
You can still record all the freeview channels. What has happened is you've run out of room on your hard drive. First you must deselect all the top up channels;
menu > 'Setup' > 'Customise TUTV', and un-ticking all boxes releases space and produces a report of '100%' free for recording. The time available for recording depends on the size of the hard drive and amount of data saved in each recording and 15% of disc space is not counted. This is for software or programme information etc. and, even when not subscribed, ads from TUTV are downloaded to library. However they are replaced or removed automatically, and messages are deleted after a week.
Also delete all the recordings in the library you don't need anymore.
Oct 02, 2009 | RCA Thomson Digital Cable Modem (DCM305R)
Thompson DTI 6300 16 Red light all the time
hi
The solution has been listed as a Samsung recorder rather than the Thomson listed above
regards
manby
May 18, 2009 | Samsung HDTV Digital Terrestrial Receiver
Thomson Digital TV Recorder DTI 6300-16 volume control
The manual is not very clear.
The volume control will work after entering the code for your TV make.
Press TV
Press AV and OK together and wait. The TV button will flash twice eventually.
then using the numeric keypad enter the code ie 0680 for Panasonic,
a list was provided with your instructions.
On entering the code the TV button will flash twice again t confirm.
Now the volume of the TV can be controllled using the buttons on the Thomson remote.
Teletext and other functions like "mute" are now present.
peterh
Dec 25, 2008 | Televison & Video
User manual needed
remove power at plug socket
when you plug power back in start to repeatedly press the standby button on the front of the box
when this causes the orange light to stop flashing press the buttons up, down, left, right
(these buttons are on the front of the box not the remote)
this causes the hard drive to reset itself
WARNING
this will cause the box to completely reformat meaning you will loose all data recorded
but after this reset the box will work as new
Dec 01, 2008 | Arris DCT2608
Thomson DT16300 TV Recorder Continually Freezes
Just got off the phone to TopUp TV and they knew how to sort this out.
Follow these steps
1. Turn on unit and press menu
2. choose set-up
3. then choose Help
4. On the help screen type the number 1397 on your remote - This will take you to an Engineer set-up screen.
5. Scroll down to option 7 (disable library video window) and toggle this option to "YES"
navigate back to your programs and delete the recording that was giving you the problem.
Oct 07, 2008 | Televison & Video
Thomson dti 6300 16 top tv version box tuner works but programe lbrary where recordingd are available has frozen cannot access or delete
Hi! This is not a great solution and a bit long winded, but aimed at those who've lost the receipt! Start by recording a new programme - the box should still record. Now the corrupt recording is not the first one in the library. When you press library now, all appears to be well. You can find which is the corrupt recording by scrolling down slowly. The corrupt one should be the one with no thumbnail picture (plus it'll be the one that freezes the box up again!). Restart the box agan and press library. If you have recordings before the corrupt one you should be able to scroll very quickly past it and delete them now. Now the corrupt programme is at the bottom of the library list - you can't delete it but at least you can avoid it now...
Like I said far from ideal, but it works on mine. Still no word from Thomson. Hope this helps.
Apr 27, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Frozen hard drive
If you have a Thomson DT16300, here's a handy fix that address freeze ups, lack of reception and problems on your Hard Disk:
goto MENU screen
goto SETUP screen
goto HELP screen
At HELP screen, Enter 1397 - this accesses the engineer panel - you can reformat the HDD in this menu - you will lose all recorded programmes and planned recordings but it clears locked or corrupted files
OR - at the HELP screen, press the GREEN button
On the lower half of the screen youwill see 3 options:
Blue - Reformat HDD - clears all the memory/HDD - useful if you have a corrupted file - you will lose all recorded programmes though
Red - reset the whole box to factory settings - good if you have a locked box or reception problems or cannto scan for new channels. It goes back to when you bought the box, so you will have to input favourites and planned recordings again
Yellow - Software revert - allows you to go back to the previous software driver - you may lose new functions, but you can always restore it back again using the same feature
Feb 15, 2008 | Thomson DPL909VD System
Televison & Video Logo
702 people viewed this question
Top Televison & Video Experts
