Question about Proscan PS27500 27" TV
You guys are lucky!!
Mine is a Pannasonic 48 inch hdtv that wont even click or the little light wont even come on... any help?
  • 121 Answers
Mabey youl be lucky too. ck  outlet with lamp. check fuses.
Posted on Dec 08, 2008
AV-48WP74 48 in. Rear Projection HDTV-Ready Television: my 3 colors are all out of whack and the convergen...
you most likely need to replace the convergence ICs. If you are lucky, they may have unsoldered pin connections at the PCB, you can try re-soldering those loose pins. What usually happens is that because of the heat generated, the pins have become detached at the IC also, thus the need to replace the ICs. Some of these have either fuses or resistors to the ICs that have also opened & will need replaced also.
May 16, 2010 | JVC AV-48WP74 48" Rear Projection...
I have a 3 yo Zenith 50 inch plasma HDTV pop/sort noise & static
kenpogue, Yes, I'll just bet it's a "switch-mode-power-supply" that has failed because of some bad or poor quality electrolytic filter capacitors or poor quality of wave soldering of components on said printed circuit boards. Ask the service tech when you call him up, how many $100 bills you should have in your hand when he shows up!!! Prior to making the CALL, do yourself a favor and view some LCD repair vids at YOUTUBE first. The longer ones will be more imformative. You might even find one very similar to your own being repaired. Some of them are pretty good and you will learn a lot. You may even want to tear off the rear plastic panel to see what is inside your set as long as it is out of warranty?? Please pay particular attention to where these do-it-yourself-guys perform the task at hand. They and spouse may need to sleep on floor for a day or two!!! lol.... good luck guy. They (ZEC) laid me off over 10 yrs ago when Lucky Goldstar took over. Bye for now. 12fixlouie If this response was helpful, please rate on fixya.
Nov 09, 2009 | Panasonic TH-50PX50U 50 in. Plasma HDTV
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Rca big screen, no power light,, dead!
Ck capacitor cp150 2200uf 16 volts if bad 2 more in same circuit also needs to be replaced 220uf 35v.ck second ribbon connector on deflection board make sure it is in correctly,or set will not come on.
Dec 18, 2008 | RCA HD52W59 HDTV Projection Television
48in projection tv jvc
wow, i have the same problem with mine. did u get a answer to this?
Jun 23, 2008 | JVC AV-48WP74 48" Rear Projection...
Colour problem in jvc
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 13, 2007 | JVC AV-48WP74 48" Rear Projection...
Turns itself off after about 10 minutes of watching, then Blue Power Button Light starts blinking. Unplug and replug and then it will turn itself off again. Please Help my JVC AV-48P575 48 in. Rear...
I have experienced that and I found out that it was plugged to 110 volts instead of 220 volts. Becaouse I bought mine in the Philippines,it is 220 volts.
Nov 05, 2007 | JVC AV-48P575 48" Rear Projection...
Shuts off
Did it work when you first got it?
What are the indicator lights near the power switch doing?
Oct 07, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC MODEL # AV-48WP74 48 IN. BIGSCREEN TV.
I had a problem with my TV colors not lining up. One day I turned it on and the green was out of wack. I checked this message board and replaced the STK chips, bad soldering and all led to me just giving up on that and buying a whole new Convergence Board ($185). I just plugged this in and though now my Green lines up okay, my red is out of whack. Is there something I am doing wrong? Can anyone help me? Did i miss a step? Frustrated......Bruce
Jul 29, 2007 | JVC AV-48WP74 48" Rear Projection...
Proscan PS27500 27" TV Logo
24 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
