Question about Dell 3100cn Laser Printer
Invalid job, press set
Printer starts to print then i get the message "invalid job, press set" ?
MUKHTAR
  • 2022 Answers
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
Posted on Oct 06, 2007
SOURCE: Dell 5100cn Laser Printer Multipurpose Feed Problem
I had the same problem, my solution was:
1) Go into the Print dialog window, select your 5100cn printer and click the "Properties" button next to it.
2) Select the second tab, labeled "Paper Tray".
3) Select "MPF" from the "Paper Source" drop-down list.
4) Click the "MPF Settings" button and select "Envelope".
That should allow your program to print to MPF for envelopes. This needs to be done in your software, setting it on the printer's control panel didn't work for me.
Posted on Jan 29, 2008
SOURCE: Printer not receiving jobs
I have a Mac Book/Leopard & when I try to print to my HP 2410, it works for 2-3 weeks & then I can not get it to print.  I call Tech Support thru Apple & they reroute my Airport Extreme & change passwords, & reinstall " Mac Os X Install Disc 1" which sometimes means being on the telephone for a couple of hours only to have it last a week or two & we have to go thru the same thing again.  They tell me that my HP 2410 must be going into the "sleep mode" & the printer will not print.  I don't know if going in & "waking up" the printer each time I want to print would solve the problem or not.  Do you have any suggestions??    Thank you---Leon
Posted on Mar 23, 2008
  • 85 Answers
SOURCE: Will not print with giving an error message
on left side of tray are 3 fingers, for letter size paper bottom 2 are out, next one in. verify slider on bottom of tray is in place. Essentially paper not sensed correctly. print config page and see paper size
Posted on Feb 15, 2009
  • 77 Answers
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Posted on Apr 28, 2009
Gympac 1600 manual
Device error An internal error occurred in the device. Press (Select) to resume the job. - Door open The printer door is open. The door must be closed before printing can continue. - Engine comm. error The device experienced an internal communication error. This is a warning message only. Job output might be affected. - Invalid driver You are using the incorrect printer driver. Reselect the printer driver appropriate for your device. - Invalid entry Invalid data or response. Correct the entry. - Jam in Cartridge area A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel - Jam in Output bin A paper jam has occurred in the output area. Clear the jam, and then press the (Select) button on the control panel. - Jam in print paper path. A paper jam has occurred in the print path. Open the door and clear the jam. Then press the (Select) button on the control panel. - Jam in tray 2 A paper jam has occurred in Tray 2. Clear the jam, and then press the (Select) button on the control panel. - Jam in tray 3 A paper jam has occurred in Tray 3. Clear the jam, and then press the (Select) button on the control panel - Load paper The HP Color LaserJet 1600 printer is out of paper. Please load specified paper type into the tray indicated. - Load Tray X [TYPE] [SIZE] The printer is processing job, but the tray indicated is empty. Please load specified paper type and size into the tray indicated. - Manual feed The printer is waiting for paper in the tray indicated Load the paper as indicated. - Memory is low The device memory has been almost completely filled. Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages. - Misprint The printed pages have been incorrectly placed on the paper. To continue, press the (Select) button on the control panel.
Dec 31, 2014 | Office Equipment & Supplies
HP 4350 ERROR MESSAGE: 49.2F90
"the printing operation has been aborted.
The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications.
Action :
1> Press Cancel Job to clear the print job from the printer memory.
2> Turn the printer off and then on to clear the error message.
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
If the above action does not solve the issue, contact HP or authorized service provider."
Mar 15, 2008 | Office Equipment & Supplies
49 4C02 - error
From looking online this message indicates the following: "A critical firmware error has occurred that caused the processor on the formatter to abort operation. This type of error can be caused by invalid print commands, corrupt data, or invalid operations. In some cases, electrical noise in the cable can corrupt data during transmission to the printer. Other causes include poor quality parallel cables, poor connections, or homegrown applications."
The advice for resolving this issue is as follows:
1. Press CANCEL JOB to clear the print job from the printer memory.
2. Turn the printer off and then back on.
3. Try printing a job from a different software application. If the job prints, go back to
the first application and try printing a different file. If the message appears only with a certain software application or print job, contact the software vendor for assistance.
4. If the message persists with different software applications and print jobs, disconnect all cables to the printer that connect it to the network or PC.
5. Turn the printer off.
6. Remove all memory DIMMs or third-party DIMMs from the printer. (Do not remove the firmware DIMM in slot J1.)
7. Remove all EIO devices from the printer.
8. Turn the printer on.
9. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and back on as you install each
device.
10. Replace a DIMM or EIO device if you determine that it causes the error.
11. Remember to reconnect all cables that connect the printer to the network or computer.
12. If the error persists, replace the firmware DIMM.
13. Replace the formatter and calibrate the printer. See Calibrate now.
Hope this helps.
Nov 20, 2012 | HP LaserJet 4345mfp Printer
49 ff95 service error for hp 5200n LJ
causes include poor-quality parallel cable, poor connections, or home-grown programs.
1. Turn the printer off and then on.
2. Press Stop to clear all print jobs from the printer memory.
3. Turn the printer off and then on.
4. Try printing a job using a different software program. If the job prints, try using the original software program to print a different job.
NOTE If the error message only appears when using certain software programs, contact the software program vendor for assistance.
5. If the message persists with different
software programs and print jobs, disconnect all of the cables and turn the printer off.
6. If the error persists, perform a firmware upgrade.
7. Remove all DIMMs, EIO devices, and CompactFlash solutions.
8. Remove all EIO devices.
9. Turn the printer on.
10. If the error does not persist, reinstall the DIMMs, EIO devices, and CompactFlash one at a time.
NOTE You must turn the printer off and then on when reinstalling each component.
11. Replace the DIMM, EIO device, or CompactFlash if necessary.
12. Reconnect all of the cables.
Jul 16, 2011 | HP LaserJet 2420dn Printer
" 49.FF04 Error Turn off
Critical firmware error. Can be caused by invalid print commands, corrupt data, invalid operations or even electrical noise in the cable.
Turn off the printer, then turn it on.
Press Stop to clear the print job from memory.
Turn off and back on.
Print a document from a different software program.
If that document prints, go back to the first program that failed and print a different file.
If the error comes back, that file is corrupt.
If the message persists with different programs and print jobs have the formatter replaced.
Apr 16, 2011 | HP LaserJet P4014n Printer
Error code 0051930 49.bb28 Printer prints old jobs even when it says no jobs stored. I have turn off the printer, unpluged the printer and it is slow or much later or not at all print the job requsted.
Other causes include poor-quality parallel cables, poor-connections, or home-grown programs.
On rare occasions, the formatter is at fault, which is usually indicated by a 79 Service Error.
1. Turn the printer off then on.
2. Press Stop to clear the print job from the printer memory.
3. Turn the printer off then on.
4. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message displays only with a certain software program or print job, contact the software vendor for assistance.
5. If the message persists with different software programs and print jobs, disconnect all of the cables to the printer that connect it to the network or computer.
6. Turn the printer off.
7. Remove all memory DIMMs or third party DIMMs from the printer. (Do not remove the firmware DIMM.)
8. Remove all EIO (JetDirect Cards) devices from the printer.
*Remember to protect from ESD
10. If the error no longer exists, install each DIMM and EIO device one at a time, making sure to turn the printer off and on again as you install each device.
Apr 26, 2010 | HP LaserJet 4700 Printer
Problem with our printer 5200tn ...error 49 4c02
From the Service Manual:
49.XXXXX ERROR
alternates with
To continue turn off then on
which typically appears as a 79 Service Error.
Dec 18, 2008 | HP LaserJet 5200tn Printer
LaserJet 4350n Error 49.C02
49.XXXX PRINTER ERROR To continue turn the printer off then on Description The printing operation has been aborted. The issue can be caused by a firmware error, invalid print commands, corrupt data, invalid operations, poor quality parallel cables, poor connections or specific applications. Action
  1. Press Cancel Job to clear the print job from the printer memory.
  2. Turn the printer off and then on to clear the error message.
  3. Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
  4. If the above action does not solve the issue, contact HP or authorized service provider.
Dec 05, 2008 | HP LaserJet 4350 Printer
Hp laserjet 4650n
Hi 123sha:
49.XXXX
PRINTER ERROR
To continue
turn off then on
Other causes include poorquality
parallel cables, poorconnections,
or home-grown
programs. On rare
Error.
1 Press CANCEL JOB to
the printer memory.
2 Turn the printer off and
then on.
3 Try printing a job from a
different software
program. If the job
the message appears
only with a certain
software program or
software vendor for
assistance.
4 If the message persists
or computer.
5 Turn the printer off.
6 Remove all memory
7 Remove all EIO devices
from the printer.
8 Turn the printer on.
9 If the error no longer
DIMM and EIO device
10 Replace a DIMM or EIO
Try new network card
pdouglasss
Jun 18, 2008 | HP LaserJet 4650 Color Printer Manual...
Action :
3> Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job,.
Mar 15, 2008 | HP LaserJet 4350 Printer
Dell 3100cn Laser Printer Logo
356 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
