Question about Garmin nuvi 205W GPS Receiver
NEW Garmin 205W Use of Apple Mac USB for charging Causes malfunct
I used my Mac computer to charge a new Gaemin 205. I have a login set up whereby I have to log in prior to allowing the desktop to come up The first time I connected the Garmin I did not log in, so no desktop...charging went well. Next time I logged in and put the machine on SLEEP and hooked up the Garmin to the USB port. As I walk away the blank Mac screen lights up and I see the desktop as if I had awakened the computer.......The Garmin will not turn on now. The screen displays the Garmin Logo, a small message is given about loading maps, followed by a beep. It cycles on and off. That's it. This is the second time this has happened. The instruction book clearly states that a computer cam be used to charge the unit. What do you suggest?
  • goforut Dec 30, 2008
    I have my Garmin on a new Mac.  I was able to download a new auto icon, so it must be connected, however it does not seem to charge, and while I was typing this note, I got a messag that the device had been disconnected, even though I did not touch it.
  • 35 Answers
Hold the power button to the left for approximately 15 seconds, then release it. It should reset the unit and turn ON. It happened to me before and it worked.
Posted on Jul 15, 2009
Garmin nuvi 205 is not recognized by garmin updater or by garmin site while trying to register
Make sure that your 205 is fully charged and that the usb cable is plugged directly into a usb port on your computer and not thru a usb hub.
Thanks for using FixYa
Apr 24, 2011 | Garmin nuvi 205W GPS Receiver
Tip
How to Perform a WebUpdate of the Garmin Nuvi 205 and 205W System Software
Does your Garmin Nuvi 205 or 205W get stuck or freeze at startup or when loading maps?
One trick to try when your GPS is acting up is to perform a Hard Reset.
Occasionally, your GPS may not start properly at all, and display a 'System Software Missing" message. Today's tip will describe how to restore your Nuvi GPS system software using Garmin Webupdater.
  1. The first step is to download the WebUpdater software.
  2. Plug in your Nuvi GPS into your PC with the USB cord.
  3. Run the WebUpdater program to install it to your PC and update the system software of your GPS.
Your Garmin Nuvi should be running as good as new.
on Jan 17, 2010 | Garmin nuvi 205 GPS Receiver
Garmin 205 how to charge on computer?
follow the steps below:
1st: make sure your NUVI is OFF then plug in the usb cable from the computer to the NUVI, after you hear your computer ding from new device connected, and the NUVI displays the computer icon move to step 2
step 2: if you have xp go to START and MY COMPUTER. with vista its START then COMPUTER button on the right side
step 3: with MY COMPUTER window open hold the NUVI power switch to the ON position and RIGHT CLICK the NUVI device logo (blue triangle) and select EJECT .. ( DON;T HIT SAFiLY REMOVE)
step 4: when you see GARMIN display on the screen you can letgo of the power button on the NUVI ****** if you unplugthe usb it will display message stating EXTERNAL POWER LOST SWITCHING TO BATTERY POWER***** while it is plugged to the computer the battery meter will disappear.
Good luck.
May 27, 2010 | Garmin nuvi 205W GPS Receiver
I left my garmin 205 in my glove box of my truck for the week after charging it for about a day n now i go to use it almost a week later i plug it into the cord plugged into the cigarette lighter it...
  • Please try to call the Garmin Technical support and then check if the device is still under warranty so that they can replace it.
  • You can also try if they have any promo on going so that you can take advantage of the promo.
Mar 28, 2010 | Garmin nuvi 205W GPS Receiver
How can i charge it if my car smoke thingy doesnt work?
Plugging your Nuvi into a computer's USB port will charge it. You can also use a powered usb hub that has a wall-power plug to act as a charging station for your nuvi without needing a computer at all.
Mar 11, 2010 | Garmin nuvi 205W GPS Receiver
My mains charger exploded and now 205 does not charge also no comms. Unit worked normally till battery went flat. When plugged into PC usb, Unit gets warm in area around mem card but does not charge.Any...
This is a new set of symptoms to me, but whenever these devices start acting up, I recommend performing a hard reset of your Gamin Nuvi 205. Also, use Garmin's WebUpdater service to make sure you have the latest software on your device.
I hope that helps.
Feb 11, 2010 | Garmin nuvi 205W GPS Receiver
Garmin 2005 will not charge, new in November of
Make sure the internal battery is charged by connecting it to your computer with the included USB cable. Make sure the computer is on and running. Let it charge at least a couple of hours and then try to turn the GPS on while still connected to the computer. If the unit still will not turn on you might need to return it to Garmin.
Apr 03, 2009 | Garmin nuvi 250W GPS Receiver
Garmin nuvi 205 can't find satellites
you can get the manual at www.garmin.com
you'll also need to get yourself a usb cable... the normal end for the computer and i believe the other end is called a mini b connector.
Robert
please take a moment to rate this solution.. thanks
Feb 02, 2009 | Garmin nuvi 205W GPS Receiver
Garmin 205 w - I cant connect usb driver .I need the driver
you have to download a third party software to upload the maps, I used GPSsendmap, can be obtained free from cGPSmapper.com.
Just download sendMap20 rev. 6.0 for windows. It works.
Dec 27, 2008 | Garmin nuvi 205W GPS Receiver
Garmin nuvi 205W GPS Receiver Logo
717 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
