Question about Motorola Mobility RAZR V3
Hi. I have an early razr with the small charger socket with 5 tiny pins. The wires have pulled off the mains end. Although they have left enough to reconnect i need to make sure i get the polarity correct. I know it uses the 2 outside pins but do you know which one is pos and which is neg. Thanks Martin
    Brigadier General:
  • 7,752 Answers
Red positive but you should get a new one
Posted on Dec 28, 2008
Hi,2004 Rocket,6000 miles,riding along lost tacho,speedo,neutral light,indicator warning lights,although they still work,main beam warning light,bike starts&runs ok????
Hi, Nigel I would start at the instrument cluster wiring harness connector made sure you have no corroded, broken or loose pins/sockets and make sure there is a solid ground for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.triumphrat.net/sprint-forum/660602-speedo-tach-light-not-working.html
Speedometer not working sensor
Triumph Rocket III Service Manual
OEM parts for Triumph
Triumph Rocket III Owner Handbook Manual
Jul 04, 2016 | Triumph Rocket III Motorcycles
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
Dimension 4500 not turning on
The Dell Dimension 4500 Desktop PC motherboard, has a 20-pin ATX main power cable connector,
http://www.auctiva.com/hostedimages/showimage.aspx?gid=1655902&image=561702676&images=561702587,561702631,561702676&formats=0,0,0&format=0
(Top left of motherboard)
This is a general example of a 20-pin ATX main power cable, and it's connector on the motherboard, (Note color never matters),
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20
The 20-pin ATX main power cable is left plugged into the motherboard, as shown in the photo to the far right.
A jumper wire is used in the connector for the 20-pin ATX main power cable.
IF the Power Supply comes on you have a bad Power On switch.
IF the Power Supply does Not come on you have a bad Power Supply.
You can still use the method to check the Power Supply too.
Just because it's new doesn't mean it's any good. DOA power supply's do happen. (Dead On Arrival)
Again looking at the photo to the far right note the Green wire.
This is the Soft Power On wire. (Abbreviated PS_ON)
Note all the Black wires. ALL Black wires are Ground wires.
The preferred jumper wire is a paper clip straightened out, then bent into a U-shape.
The top of the U is wrapped a few times with black plastic electrical tape. (Did you know that one wrap of black plastic tape, is good enough for 600 Volts DC?)
Turning the U upside down there are two 'legs'. The legs are what is used.
One leg goes down into a socket hole with the green wire in it.
The other leg goes down in a socket hole with ANY Black wire in it.
Where the wires go into the connector of the 20-pin ATX main power cable, is the Back of the connector.
This is where the jumper wire is used.
One leg goes down into the socket hole of the Green wire, RIGHT NEXT TO the insulation of the green wire, and slides down into the socket hole.
Has to slide down in far enough, to touch the metal terminal at the end of the wire.
Same with the other leg of the U-shaped jumper wire.
Goes down into ANY socket hole with a Black wire in it, next to the insulation of the wire, and down in the socket hole far enough to touch the metal terminal.
[All wires going into the connector of the ATX main power cable, end in a metal terminal,
http://www.molex.com/molex/products/datasheet.jsp?part=active/0002081202_CRIMP_TERMINALS.xml&channel=Products&Lang=en-US
The left side is the side that get's crimped on the wire. This is what the U-shaped jumper wire's leg touches. The right side is the font of the connector, and in the middle photo of the Playtool link you can see the tips of the metal connectors. (Brass colored ]
There may be a small spark when the jumper wire 'legs' make contact.
The Soft Power On circuit uses 5 Volts DC.
In comparison two D cell flashlight batteries store 3 Volts DC.
The contact made is 2 seconds. The Power On switch is a Momentary Contact Switch.
http://www.ebay.com/itm/Dell-Dimension-8400-Front-USB-Audio-I-O-Panel-Cables-M5989-/290780863258?pt=LH_DefaultDomain_0&hash=item43b3e3db1a
The Power On switch is on the small circuit board, that is at the upper right, and next to the word Upgrades.
http://support.dell.com/support/edocs/systems/dim4500/replace.htm#1114002
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 02, 2012 | Dell Dimension 4500 PC Desktop
Ms 7613 ver 1.1
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c01946060&printver=true
View the motherboard photo at the Top, and also the Motherboard layout illustration, at a little over halfway down the page.
1) In the motherboard photo, all the way to the right side. View the Yellowish/Whitish connector, that has two columns of 12 socket holes.
This is where the 24-pin ATX main power cable plugs in.
In the motherboard layout illustration it is labeled - ATX1.
Here is a general example of this power cable, and respective connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
Note that new Power Supply's, generally come with a 20+4-pin ATX main power cable.
This is so it can be used on the older computers that used a 20-pin ATX main power cable, and newer ones that need a 24-pin ATX main power cable.
Do not mix it's extra 4-pin power cable, with the 4-pin ATX +12 Volt power cable.
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain20plus4
Note the Lock on the side/middle. It has a hook on the end. The hooked end goes over a Tab, on the motherboard's connector.
The Lock works on the same principle as a see-saw on a playground.
You squeeze the top near where the wires come in, and this brings the hooked end away from the Tab, on the motherboard connector.
With the top of the Lock still squeezed in, the power cable is then removed USING the connector. (NOT the wires)
When assured that the power cable is plugged in tightly, and correctly, the hooked end of the Lock will be over the Tab, on the motherboard connector.
2) Look to the left of the Processor socket, and halfway in-between it, and the outside edge of the motherboard.
Whitish 4-socket hole square connector.
This is where the 4-pin ATX +12 Volt power cable plugs in. Power for the Processor. Note that it also has a Lock, with a Tab on the motherboard connector.
In the motherboard layout illustration it is labeled - PWR1
General example of power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
That's it for the motherboard as for power cables that plug into it.
The rest of the power cables from the Power Supply, plug into the optical drive/s, harddrive, and card reader if used.
4) If your harddrive is an IDE (PATA) unit, it will use a 4-pin standard Peripheral power cable. Same with an optical drive that is an IDE (PATA) unit,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
The computer case fan plugs into SYS_FAN1 connector, which is below the PWR1 connector. You may also have a computer case fan that uses the above power cable.
5) If your Harddrive, or optical drive/s are SATA, they will use a SATA power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
6) A Card Reader uses a power cable, that is also used for a Floppy Drive.
It is a 4-pin Small Peripheral power cable.
Has the same voltage wires; (Yellow - 12 Volts, Red - 5 Volts), and two Black ground wires, but a smaller connector, than a 4-pin Standard Peripheral power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#floppy
The front of your computer is the Front Panel.
The area of wires on the motherboard, that the main wires from the Front panel go to, is the Front Panel header.
Although the Front Panel header has NOTHING to do with the Power Supply, I will include it also,
Motherboard positioned in computer case; Processor to the Top, Ram Memory slots to the Right;
The Front Panel header is at the bottom/right of the motherboard.
Black rectangle with 9 contact pins.
In the Motherboard layout illustration, JFP1 is marked under this header.
There are 4 pins across the Top row, 5 pins across the Bottom row.
The pins on the Top row are numbered EVEN.
The pins on the Bottom row are numbered ODD.
Starting on the LEFT side going towards the Right, Top row;
Pins 2, 4, 6, and 8. There is NO Pin 10.
Starting on the LEFT side going towards the Right, Bottom row;
Pins 1, 3, 5, 7, and 9.
A) Pins 1 and 3 are for the HarDDrive activity LED. (Light Emitting Diode)
Pin 1 is for the Positive ( + ) wire.
If the HDD LED is dim when the harddrive is active, switch the wires around.
B) Pins 5 and 7 are for a Reset switch, IF a Reset switch is used.
C) Pin 9 is N/C. Not Connected. Reserved for factory use.
D) Pins 2 and 4 are for the Power On LED.
Pin 2 is for the Positive ( + ) wire.
If the PWR ON LED is dim when the computer is on, switch the wires around.
E) Pins 6 and 8 are for the Power On switch.
F) Again, there is No Pin 10.
For additional questions post in a Comment.
Regards,
joecoolvette
Aug 15, 2012 | HP Computers & Internet
Jeep patriot won't crank
I had this exact same issue w/ my 08 Patriot. Had it towed the first time and mechanic changed the starter. Worked for about a week, then same issue. Found that moving the vehicle, even just a couple of inches, or putting in neutral helped start it. Issue stopped once weather warmed up. This all occurred last March (2014).
Until two weeks ago that is. Horn stopped working so I started looking for any corroded connections. I came across some relays under the left headlight. When I pulled them out, I found two had corroded pins. One was so bad that there was no pin left. It had barely been making a connection before I pulled it and now it wasn't going to at all. The wires to that pin were completely shot too. And guess what, car wouldn't start! Same symptoms as in March.
I ended up going to my parts recycling place and piucked up the whole relay enclosure w/ 4 relays and about a foot of the wiring. I used my smallest watch screw driver to carefully remove the spade connector from the recycled relay enclosure. The corroded connector in my Jeep completely destroyed its slot. I ended up having to gently remove the other spade connectors for the relay and relocated the surviving spade connectors to an open/unused location (luckily there were 2 open spots) and splicing in the salvaged connector. I used some dielectric grease on all of the relay slots, before putting everything back together, and was able to relocate the entire enclosure up next to the fuse enclosure (as recommended by by someone in anothe post. I apologize for not being able to find the link to it at the moment).
It's been working well for just over two weeks now. I hope this helps someone else.
BTW - horn turned out to be dead and I just ended up replacing it. Not related to the relays at all.
May 09, 2012 | 2008 Jeep Patriot
My motherboard is getting power from a 450w smps coz the board LED gets on when I switch on the ups. But pressing the power button on the cabinet does not switch on the system. Please help!!!!
From your diagnoses you may have a bad Power On switch, or a bad Power Supply.
Reasoning?
An ATX power on switch is connected to the motherboard's Front Panel header.
From there the circuit is continued through the ATX main power cable, and into the Power Supply.
The Power On switch connects the Soft Power On wire, to Ground.
(The Soft Power On wire is abbreviated as PS_ON. The wire is Green)
If the Power On switch is bad the Power Supply will not turn on.
A bad Power Supply will have a weak voltage power rail, (Or more than one)
Enough power to light LED lights, and perhaps spin fans, but not enough power to turn the Processor on.
No Processor operating, no computer.
1) If all of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use from 51 to 125 Watts. Depends on what Processor it is.
(Older Intel Pentium III's, and comparative AMD processors used less than 51 Watts)
You may have enough power to light that LED light, but not enough to spin fans, or turn the Processor on.
There is a simple test to see if the problem is the Power On switch, or the Power Supply.
Bypass the Power On switch.
A jumper wire is used to temporarily connect the Soft Power On wire to ANY Ground wire.
The connection is made at the Back of the ATX main power cable's connector, with the ATX main power cable plugged into the motherboard, and computer plugged into power.
1) The Asus M2N-MX (And SE version) motherboard uses a 24-pin ATX main power cable.
http://www.asus.com/Motherboards/AMD_AM2/M2NMX_SE_Plus/
This is one example of a 24-pin ATX main power cable, and it's respective connector on the motherboard,
Looking at the photo to the far right, shows the 24-pin ATX main power cable plugged into the motherboard.
This is the position for the test.
(Computer also plugged into power)
The BACK of the connector is where the wires go into the connector.
The jumper wire is used on the Back side of the connector.
One end of the jumper wire goes down into the socket hole with the Green wire.
(Soft Power On wire)
The other end of the jumper wire goes down into ANY socket hole with a Black wire in it.
The jumper wire goes down into the socket hole RIGHT NEXT TO the existing wire.
The jumper wire MUST go down into the socket hole far enough to touch a metal terminal.
At the end of every wire going down into the ATX main power cable's connector, is a metal terminal.
The metal terminal is pretty far down in the socket hole.
The preferred jumper wire used is a paper clip.
The paper clip's diameter is small enough, to go right next to the existing wire in the socket hole, and touch the metal terminal.
The paper clip is straightened out, then bent into a U-shape.
The 'legs' of the U-shape go down into the two socket holes.
The middle is wrapped with a few wraps of black plastic electrical tape.
The taped area is for your finger, and thumb to hold onto.
The voltage is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
There may be a small spark when you make the connection, advising you in advance.
The connection made is no longer than 2 seconds.
(The Power On switch is a Momentary Contact Switch)
Computer comes on, (Power Supply actually) you know you have a bad Power On switch.
Computer does Not come on, you know you have a bad Power Supply.
Regards,
joecoolvette
Jul 10, 2011 | ASUS M2N-MX Motherboard
Connecting jumper for start up
That would be connecting a jumper wire, from the Green wire to ANY Black wire, in the 20 or 24-pin ATX main power cable's connector.
If this problem is in direct relation to a Dell E210882 motherboard, it uses a 24-pin ATX main power cable,
http://en.community.dell.com/support-forums/desktop/f/3514/p/19298234/19565862.aspx#19565862
Example of a 24-pin power cable, and it's respective connector,
The Green wire is the Soft Power On wire. (Abbreviated as PS_ON)
ANY Black wire is Ground wire.
With the 24-pin ATX main power cable plugged into the motherboard, and the power supply,(Computer), plugged into power, the jumper wire is inserted into the back of the 24-pin ATX main power cable's connector.
Looking at the photo to the far right in the link, shows the ATX main power cable plugged in.
Where the wires go into the connector is the BACK of the connector.
One end of the jumper wire, goes down into the socket hole with the Green wire, RIGHT NEXT TO THE WIRE.
The other end goes down into a socket hole with ANY Black wire in it.
The end of every wire going down into the ATX main power cable connector, has a metal terminal end.
This metal terminal end is pretty far down into the connector, from the backside of the connector.
For this reason the jumper wire MUST go down into the socket hole, far enough to touch the metal terminal end.
The most widely used jumper wire is a paper clip.
The paper clip is straightened out, then bent into a U-shape. Black plastic electrical tape is applied to the center of the U shape.
This taped area is for your fingers.
(One wrap of black plastic electrical tape will insulate you from 600 Volts DC)
The 'legs' of the U-shaped paper clip then go down into the socket holes.
The voltage is VERY low, but there may be a small spark.
Warning you in advance.
Power supply comes on?
You have a bad Power On switch.
Power supply does Not come on?
You have a bad Power Supply.
For additional questions, or to clarify anything I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Dell (E210882) Motherboard
My computer will not turn on.
Suggest you start with checking the receptacle in the surge protector, that the Computer is plugged into.
I have had 3 surge protectors now that just THAT receptacle was bad.
"Hmmm, surge protector LED power on light is lit.
Monitor, printer, and router, plugged into the surge protector have power."
Plugging in a lamp into the receptacle in the surge protector, that the computer was plugged into, proved just THAT receptacle was bad.
Not an issue?
Then I suggest you check to see if the problem is the Power On switch, or the Power Supply.
The Power On switch is located inside the plastic Power On button.
This is an example of a generic ATX Power On switch,
http://www.directron.com/atxswitch.html
The test is to use a jumper wire for the Soft Power On, and bypass the Power On switch.
If the Power Supply comes on, the problem is the Power On switch.
If the Power Supply does Not come on, the problem is the Power Supply.
Bad Power Supply.
Dell Support, and the Service Manual main page, for the Dimension E310,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/index.htm
If you click on Technical Overview, then on System Board Components, you'll be taken to this page,
http://support.dell.com/support/edocs/systems/dim3100/en/sm/techov0.htm#wp1058089
Here you will see an illustration of your motherboard. This is a Top view. The view you will see when you open your computer case.
(Main menu - Removing the Computer Cover)
The number 9 points to the ATX main power connector on the motherboard.
Viewing closely you will count 24 socket holes.
12 on top, 12 on bottom.
This connector is a 24-pin ATX main power cable connector.
If you scroll down the page to the heading - Power Supply DC Connector Pin Assignments, and to the heading underneath - DC Power Connector P1, you will see the Dimension E310 has a 24-pin ATX main power cable.
This is a more in-depth view of a typical 24-pin ATX main power cable, and it's respective connector, plus a view of a typical 24-pin ATX main power cable connector, on a motherboard,
(Not a Dell Dimension E310),
The photo to the far Left, shows a 24-pin ATX main power cable connector, on a typical motherboard.
There is no 24-pin ATX main power cable plugged in.
The photo in the middle, shows a 24-pin ATX main power cable.
The photo to the far Right shows the 24-pin ATX main power cable plugged into the connector.
In the photo to the far Right you will see that one of the power wires has Green insulation.
Also abbreviated as PS_ON
You will see many wires with Black insulation.
ALL of these wires are a Ground wire.
The jumper wire is connected to the Soft Power On wire, (Green), and to ANY Ground wire. (Black)
The method is to insert one end of a jumper wire, into the socket hole with the Green wire, and the other end into a socket hole with a Ground wire.
(ANY Ground wire)
Again looking at the photo to the far Right, you will see that the power wires go down into individual socket holes.
The insulation of the power wires goes down into the socket hole pretty far.
At the end of each power wire is a metal terminal. It is a female terminal.
This is what it looks like,
http://www.alliedelec.com/search/productdetail.aspx?SKU=8630463
The jumper wire must go down into the socket hole, (Right next to the existing wire already in the socket hole), far enough to touch that metal terminal pin.
it has been suggested to use a paper clip.
The paper clip is straightened out, then bent into a U shape.
The center of the U shape is wrapped with black electrical tape.
The taped area is where you hold the 'jumper wire'
You may wish to wear a glove also.
There may be a spark.
Hence I advised wearing a glove. Not so much for your safety, but for your peace of mind.
One end down into the socket hole with the Green wire, (Soft Power On), and the other end down into ANY socket hole with a Black (Ground) wire.
The contact period used is no longer than 2 seconds.
If the Power Supply comes on, you have a bad Power On switch.
If the Power Supply does Not come on, you have a bad Power Supply.
The Power Supply can come on, and still be bad. Weak voltage power rail.
Enough power to light LED lights, and perhaps spin fans, but not enough to turn the Processor on.
1) ALL of the LED lights combined, use less than 1 Watt of power.
3) A typical Processor can use 51 to 125 Watts.
Post additional questions in a Comment.
Regards,
joecoolvette
Sep 13, 2010 | Dell Dimension E310 PC Desktop
Hp a210n won't power up. Where should I start to troubleshoot the problem ?
Start at the wall outlet, then to the power cable, Then go on to the power switch (these have been known to go bad), then on to the power unit, you can buy a PSU checker at a computer retail store like CompUSA, just plug each of the power unit's connectors into the tester to make sure the appropriate power and voltage is going where it needs to. Also at the store look for a temp power switch that slips onto the pins of the motherboard and can be pressed in that area.
May 23, 2010 | HP Pavilion A210N (DF210A#ABA) PC Desktop
My razr v3m always thinks its charging even when i take the charger out it still says charging. and the phone wont stay off it turns right back on and says unauthorized charger
Sounds like the connector for the charger/data cable has become damages, there are tiny pin contacts inside that can get bent or the female port on the phone can become wallowed out. If you have insurance on your phone you can take it back and have it replaced. You might also try some compressed air blown into the connector gently to see if there is something stuck inside.
Check also the charger cable end if you look carefully inside you can see the pins, make sure they aren' bent or pushed in, might have bad charger connector.
Hope this helps
TankMurdock
Apr 23, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
