Question about SanDisk Sansa e260 MP3 Player
My e260 repeats each song even with repeat turned off
I have tried selecting "off" in the repeat mode, but when I push the select button it changes to "song" or "all". It is setting itself to repeat each song whenever I play any previously unplayed album. I cannot get it to reset because it does not freeze up.
IT IS BECUASE UR HOT BREATH IT'S
Posted on Dec 08, 2008
I have a mp4 player but the song only pla 10 s
This situation is usually caused by the "repeat mode" settings of the payer has been set to "intro" mode. You should push menu button and select this feature and modify it to normal or no repeat mode.
gylacz
Mar 10, 2011 | Craig CMP168C MP3 Player
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
How can I ''shuffle''my songs on sylvania's smpk4083 model?
The SMPK4083 can shuflle songs, selecting Random:
Follow next procedure:
In PLAYING mode, press M while playing music to enter
the selection menu screen.
Choose Repeat and press M to enter the Repeat menu screen.
Next go to Random using |<< / >>| buttons, while selected Random, press M to choose for random play.
Jan 23, 2010 | Sylvania Audio Players & Recorders
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
My songs are shuffled
Since you cannot see what you are doing on the screen, I will tell you what buttons to push to un-shuffle your songs. Press the buttons in the exact order I tell you. Ok. Turn off the mp3 player, then turn it back on. Press the little menu button. Push the left arrow button once. Press the play button 3 times slowly. You are now in the menu that gives you the following options to unshuffle your music:
1. Off
2. Repeat single Track
3. Shuffle/No Repeat
4. Repeat all Tracks
5. Repeat all With Shuffle
I'm guessing that you may have to push the down arrow once or the up arrow once. This should select the Repeat all Tracks option. After scrolling up or down one time, press the play button once, then the menu button twice. Now push play to start your music. If this does not work, you can set your player back to the default settings by pushing the menu button once, pushing left arrow once, hit the play button. Scroll down 5 times, hit the play button, and push down 3 times. Be careful, because if you do not push the down arrow THREE times, you might accidentally select the option of erasing the memory.Once you push down 3 times and hit the play button, push down once more to select Yes of reseting your player back to it's original settings. This should help you out.
Aug 07, 2008 | Insignia Sport MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
Songs wont change
It is stuck on "Repeat One" - refer to p.23 of your user's manual -
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
While you are playing music you can see the following active play mode screen.
-Tha Mp3 Doctor
Oct 30, 2007 | Philips HDD1630 MP3 Player
Message states unable to format
Make sure you dont have Rhapsody, or Windows Media Player open. Go to My Computer>Device Name (e260)>Right Click and select FORMAT. If that doesnt work, change the mode on the device Settings>Mode or USB Mode and repeat. Best of Luck.
Sep 23, 2007 | SanDisk Sansa e260 MP3 Player
Pink Screen says "No Song"
Hi. It would seem that either the internal memory of your player has been corrupted or the firmware has experienced some errors. The best way to fix your player would be to either format it or re-load its firmware. Either way, you may need to re-load your music files once again. First, you would need to set your player to MSC mode by navigating the menu as follows: Menu >> Settings >> USB Mode, then select "MSC". If you have the "Rhapsody" E200 version, then select "Rhapsody" (it's the same as "MSC" mode) Next, plug your player in your computer and look for the drive letter corresponding to your Sansa. Right-click on the drive letter, then select "Format". Just make sure that the File System is set to FAT32. Click "Start" to begin the Format and follow the on-screen prompts. Since your songs came from audio CD, simply Drag-and-drop the files to your player (MSC mode is will actually work best with audio CD songs) If this does not work, then go ahead and re-load your Firmmware using this instruction I received from SanDisk technical support: Switch your Sansa E260 to its Recovery Mode: 1. Make sure the player is powered off 2. Enable the "Hold" switch (located on the top of the player). You would know it's enabled when you see the "orange-colored" surface 3. Press the "Record" button. Make sure you keep it pressed while pressing on the "Menu" button. 4. keep your fingers pressed on these 2 buttons until the E260 LCD screen displays "Welcome to Recovery Mode" 5. Connect your E260 to your computer. (Just a reminder: The minimum Operating System requirements for a Sansa E200 player is Windows XP and above) 6. Double-click on "My Computer" and you would see your Sansa E260 appear as a "16 MB" drive. Note: If you do not see that "16 MB" drive/partition, please repeat steps 1-6. Next, Apply the firmware for the E260 (your player should be connected to your PC at this time): Step 1: Use this link to download the firmware for your Sansa E260 (for better results, please save this file on your "Desktop": http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe Step 2: Double left-click on the downloaded file, and follow the on-screen prompts. The file will automatically re-flash your player and format it as well, thereby clearing all possible file/system corruptions that may have occurred. Step 3: When the process is complete, unplug your E260 from your computer, and please make sure you disable the "Hold" switch Step 4: Power up your E260 and 90-99% of the time, it would restore your player to normal settings.
May 16, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
107 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
