SOURCE: wheel adjustment on a ge fridge
if you take the front kick plate off by pulling on it. once the front kick plate at the bottom of refrig. is off bend down and you will see 1 bolt head that looks bigger than the rest of them. 1 on each side of the refrig. now if you need to lower the refrig turn to the left. to raise turn to the right. this do it for you. thanks eddy
SOURCE: u-line water level too full
If you have a icemaker then remove the cover. You will see a screw with a spring around it. Turn that clockwise like your tightening it this will reduce the size of the cube. Also make sure it is leveled. And make sure no corrosion is around the gears on that same plate. This could make the motor run slower and more water comes into it.
SOURCE: How do you adjust the doors to closed completely?
The lower hinge on each door
may have a door closing cam. It raises the door up ¼ inch when opening and this
assist in closing the door. If it’s wore out and doesn’t work the door may not
seal and the gasket can be damaged. Watch the operation of the door to see if
it rises up when opened.
Leave the door shut and let the magnetic gasket hold the
door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking
note of order of removal of parts. Slide new cams on. You probably need two.
SOURCE: The doors on my Frigidaire
you could try packing out the hinges with thin washers,,,,the door has only plastic bearings on its hinges and that door is lumpy?
