Computers & Internet Logo
Posted on Dec 08, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cmos clear my foxconn motherboard g31ax came with the cmos jumper on 1and 2. It needs to be on 2 and 3 for normal opearting. the problem is I'm not sure if it did com on 1 and 2 how do I know what pin is what
Anonymous
Level 2:
  • Expert 52 Answers
  • Posted on Dec 08, 2008
Anonymous
Expert
Level 2:
Answers
52
Questions
0
Helped
12378
Points
134
Try this link to download the manual.
Jumpers
Remove the jumper plug from the CMOS jumper (CLEAR CMOS) pins 2 and 3. Place the jumper plug on the CMOS jumper (CLEAR CMOS) pins 1 and 2 and wait approximately five seconds. Remove the jumper plug and replace it on the CMOS jumper (CLEAR CMOS) pins 2 and 3
Installed this motherboard but PC will not boot up past the windows resume page, keeps resetting the power. CMOS jumper position seems to be mislabelled in the manual as it appears to be in the CLEAR...
Hello
Resetting? Have a look at your memory stick locations.There should be 4 slots,each a color.
Say blue orange and blue orange.If your using 2 sticks they both need to be in either both blue or orange slots.
If your using 3 sticks then its Blue orange and orange.Also the jumper not be in the clear position.
It needs to be in the 2and 3 position.The 1 and 2 position is to clear the c mos.2 and 3 are for normal operation.
1helpful
Changed cpu multiplier from 17 to 19 now have blank screen on foxconn a88gmx, cant reset as cannot access bios
Try clearing the CMOS --- the down side is your lose all your setting --- the up side is you should be
able to access your BIOS
Clear CMOS Jumper: CLR_CMOS1 ( Located near CMOS battery )
The motherboard uses CMOS RAM to store the basic hardware information (such as BIOS data,
date, time information, hardware password...etc.). Clear CMOS data is the fast way to go back to
factory default when the BIOS settings were mistakenly modified.
The steps to clear CMOS data are :
1. Turn off the computer, unplug the power cord from the power outlet.
2. Remove jumper cap from pins 2-3, put it onto pins 1-2 to short them.
This will clear CMOS data.
3. Return the setting to its original with pins 2-3 closed.
4. Plug in the power cord to your computer and turn it on.
5. Go to BIOS Setup to configure new system as described in next chapter.
Clear Jumper on pins 1 & 2
1 ----
2 ----
Normal
(Default)
3 ----
CLR_CMOS1
  • Disconnect the power cable before adjusting the jumper settings.
  • Do not clear the CMOS while the system is turned on.
WARNING!
Jumper Diagram Definition Description
1-2 Set Pin 1 and Pin 2 closed
2-3 Set Pin 2 and Pin 3 closed
1helpful
Where is cmos reset jumper? Is it near battery,
Try
http://support.acer.com/acerpanam/manuals/acer/0000/servicemanuals/S.G_Aspire_M5640_M3640M1640_BOOK_VerC.pdf
page 77
label CLR CMOS 3 pin type 1-2 clear 2-3 normal
2helpful
HOW CLEAR INTEL D915 GAV BIOS PASSWORD
Intel mother board is very populer brand.I like it very much.If itself, It has three leg jumper near the cmos battery.1-2 short defaultor normal.2-3 short clear cmos.you like 2-3 short then fix your bios password.you must be power switch on.Un plug power cable.again jumper short 1-2 normal position. your bios clear.
1helpful
2answers
How do you rest the bios on a ASUS p4vp-mx mother board
it has a coms jumper in side coms battery 1-2 jumper normal position 2-3 clear coms choice 2-3 then *********** board reset
Clearing up cmos
Dear seth79
As with any CMOS it ussually takes 2 seconds :) but to be completely sure take 30 seconds at each step.
1. Lifting off the jumper - 30 seconds
2. Bridging the pins indicating by the M/B manual - Another 30 seconds
3. Connecting the jumper to its original location.
Please remember to switch of the computer completely off before doing this. (Even the PSU if possible)
Also ground yourself in order to avoid ESD discharge damage on the components near your fingers.
Regards
EngineerGR
2helpful
2answers
Foxconn F845DA jumper settings
JP1 PIN 1-2 = On board audio disable
JP1 PIN 2-3 = On board audio enable
JP2 = Temperature Sense connector
JP3 PIN 1-2 = Normal
JP3 PIN 2-3 = Clear CMOS
1. Power off the system and unplug the chassis AC power cord.
2. Short JP3 at PIN 2-3 for a few seconds.
3. Set JP3 back to it's normal position at pin 1-2.
4. Plug the AC power cord to the chassis.
5. Power on the system and load the BIOS setup default.
Top Foxconn Computers & Internet Experts
Jose Ramirez
Mohammad Abumuailek
Mohammad Abumuailek
Grand Canyon Tech
Grand Canyon Tech
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
