Question about JVC GR-SXM740 S-VHS-C Analog Camcorder
Tracking problems please help
When I record, the picture looks fine. When I playback, the picture has lines as if there is a tracking problem. I tried adjusting the tracking, but it does nothing. What can I do?
philipp
  • 217 Answers
SOURCE: Problems from the lens
Defective ccd imager!! the
company will replace this
ccd imager free of charge.
Year 2002 up to 2005 released
unit has a factory defect ccd
imager. the company recalled
those units and replaced with
a stronger version of ccd
imager ( they are still doing it).
check it out.
Posted on Dec 13, 2007
  • 19 Answers
SOURCE: GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Posted on Dec 21, 2007
  • 73 Answers
SOURCE: mini dv recorder
THIS IS A CCD.. CONTACT JVC FOR FREE REPAIR
Posted on Feb 23, 2008
babaloo60083
  • 4 Answers
SOURCE: JVC GR-DX76 - No Picture
which view finder? contrast or brightness?
Posted on Apr 24, 2008
SOURCE: tracking appears to be out - can it be adjusted?
Giving in and taking the camera back to the shop for repair!
Posted on Jul 07, 2009
Tape playback on Magnavox MWR20V6
When was the last time you ran the "head cleaning" tape in the machine? As tape collects dust and dirt - it gets deposited on the recording and playback heads. This ruins playback and recording quality. Also, since tape is magnetic - they tend to magnetize the heads, too (just like reel to reel, 8 track & cassette player / recorders). Demagnetizing them will help too. Here are links to both products:
head cleaner
head demagetizer
Feb 26, 2015 | Magnavox Televison & Video
Picture rolls on playback
Try cleaning the heads, but it seems like the heads may be faulty, you might need to replace the vcr, they don't cost much these days, the repair might cost more than a new vcr these days.
heres a cheap headcleaner, look for one at local shops, wallmart bestbuy and so on
http://www.pcconnection.com/IPA/Shop/Product/Detail.htm?sku=7632166&oext=1038A&ci_src=14110944&ci_sku=7632166
Sep 24, 2008 | Panasonic PV-V4021 S-VHS VCR
Playback problem EP
Do you have a tracking control on the
vcr if you do it should be centered during
record It can be adjusted during playback
to clear up the picture adjust it for the best
If you dont have a tracking control on the
vcr then it may require a mechanical adjustment
of the backtension or guidepost which requires
special tools to perform
Nov 18, 2007 | JVC HR-A592U S-VHS VCR
Copy tape to dvd using Q-VHQ 760 & Pinnacle instant dvd recorder. Playback looks great, unfortunately there is a thin fuzzy line at the bottom which never changes. My question - how can I fix this ? ...
Check the edge of the tape to see if it's wrinkled. That is the most common problem that shows that line. You may be looking at the head switching pulse too. Since your VCR has no tracking adjustment, it has to be done with special tools, an oscilloscope and a voltmeter. Not an easy task.
Feb 15, 2018 | Quasar VHQ760 VHS VCR
Toshiba DVD video recorder/video cassette recorder. The picture is unstable and jumps up and down on cassette playback in SLP mode.Adjusting the tracking does not make a difference.
need to adjust the arms that hold the tape around the main cylinder use a small screwdriver and adjust each one slightly until stable
Jan 04, 2010 | Toshiba Televison & Video
Volume loss after VCR recording
Try adjusting tracking to detent Sounds like audio heads are miss aligned . Does your unit have audio levels if so turn them up when recording. Try adjusting tracking or try patching recording unit to the tv .If it has L/R video inputs use the same deck you recorded on for playback. .
Oct 24, 2017 | Toshiba 24 24 in. TV/VCR/DVD Combo
Panasonic Super Drive video recorder
there are three creases in the head , have you made sure those are cleard?
Oct 21, 2008 | Zenith VCS442 VHS VCR
Solid blue lines through Picture on playback mini DV PV-gs19
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
cassette.
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Apr 21, 2008 | Panasonic PV-GS150 Mini DV Digital...
My camcorder not playing back
First, try head cleaning by trained technician. Tech will clean manually with cleaning chemical each head to make sure video heads are performing 100%. Otherwise, they will probably quotes you for tracking adjustment. Head cleaning is typically around $25-50. Tracking adjustment might cost you around $100-200 in US depending on service time.
Mar 17, 2007 | Panasonic Palmcorder PV-GS14 Mini DV...
Vcr record problems
It sounds like the back tension is off on the unit. the back tension is controled by a small band attached to a copper or metal strip and that ia wraped around the supply reel and is adjust by an arm that swings out and contacts the tape during record or playback and keeps a steady tension on the tape. If the back tension band breaks or wears out you will get a picture that looks like the tracking is off or bad or dirty video heads. Most likly you do not have a backtension gauge and it certainly would not be fesable for you to purchace one as a good one cost about 100 bucks or so. A repair shop may beable to adjust it for you, But even their fee may be cost prohibitive. Good Luck PS please do not forget to rate this.
Oct 14, 2006 | Sanyo DVW-7200 DVD/VCR
JVC GR-SXM740 S-VHS-C Analog Camcorder Logo
35 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Mohamad Abdan
Mohamad Abdan
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
