Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore cooktop/oven model # 790
The digital controls are not working correctly anymore on this unit. It locks itself and changes the clock's time, you can't set the temp. or turn the oven on or anything like normal. Is it likely I'll be able to repair this myself? And....how?
Thanks
Sears repair dept is just horrendous these days, goes with the economy. my clock on my kenmore oven will not set and thus the oven will not work, it clearly states that is the manual. trying to get someone to come out is impossible, you have to call the sears 800 # and who know where you end up. sears repair man came out and said it was the main board, $75 charged to come and check out over-cost to fix is $464.66, they applied the $75 to this charge it's a slide in stainless steel and will cost $1500 for a new one- sears will only give a 90 day warranty on the repair...
Posted on Jun 22, 2012
    Genius:
  • 1,550 Answers
You need to take to service center to get it repaired . Since your clock time is getting changed it indicates that your clock is faulty you need to replace the clock if you want to have the correct time.
But replacing clock is expensive .
Posted on Dec 08, 2008
  • 121 Answers
Not likly souds like intergrated cicuit acting up prob need sevice tech unless very handy  prb have to change out pc board.
    Sergeant:
    Champion:
  • 291 Answers
You will need to replace the control board and to get to it there is eather 2 screws at top on console or 3 under it going up into it ,,, have power turned off and then take screws out and lift console up and off and the control board is held on by 4 screws and go back same way / larryyb
    Sergeant:
    Champion:
  • 435 Answers
Hi, Are you sure the child lock is not on? Please check it.
    Sergeant:
  • 399 Answers
First unplug the unit form the device for some time then on it again.and try readjusting it properly.if it does not works.it might be the probem of touch pads gone short internally and needs reparing.
Why kenmore oven code f-10 comes on when bake or broil is on
I would first pull your range out from the wall, unplug your range, then take off the back access panel and ohm your oven sensor.
It should ohm out at 1100 ohms at room temperature.
If that checks good, then your control board is the problem.
Here's the oven sensor probe for your model:
Part#316217001show?id=yo6223wzsty&bids=122738.613159039&type=10&subid=
yNjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Here's your control board:
Part#316418208show?id=yo6223wzsty&bids=122738.582384825&type=10&subid=
0NjEzL0lDVy9zb3RvaHB0cmFwLw%3d%3d">
Aug 20, 2014 | Ovens
Kenmore oven 790 model number, door locked, won't open
do you have a button with a small padlock symbol?
yes hold for 10 seconds
no..do you have start button? press and hold for 5 seconds
no...how about a clear/off press and hold for a full 3 seconds.
Sorry I'm at home and the teck guides are not here. So I gave it what I know from memory.
last but not least try turning off the breaker to it for a minute.
Hope this helps a little.
Feb 02, 2018 | Kenmore 40494 / 40495 / 40499 Electric...
Electronic Oven Control for Kenmore model # 790-30172400
If the part numbers are the same then you can use that board. The revisions are to so that the control boards can be used on models that may have other features that yours may not.
Apr 23, 2012 | Kenmore Ovens
Kenmore electric range with ceramic cooktop, model # 79046593500. None of the elements or the oven will heat up. The controls work, the red indicator light goes on, but no heat.
It sounds like your Frigidaire made kenmore may have a power supply issue, the power block that is located at the rear of the oven may be at fault. part number 5303935061. However the digital clock can also cause this problem, and should be diagnosed by a technician.
Mar 14, 2010 | Ovens
My kenmoreoven cooktop works but the oven is not working properly the screen says e1-f2- how do i get help with that
Hi. This code is in reference to a possible unplugged key pad. Use this procedure to address further.
1. Check The keypad connector for firm connection (keypad connects to control board, via ribbon cable). If the cable is connected correctly, move on to the final step.
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate the keypad and control board, as one unit. In this case, replace control board (also called ERC or clock).
Dec 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven F1 error code
I have a whirpool oven that won't self clean anymore and it comes up with a FSE 1 error which is a factory service error and the code is a 1 . You need to call them to come out and have a tech fix it as it's digital
Mar 10, 2009 | Ovens
Oven and broiler will not heat top works fine kenmore 790
It appears your ERC/CLOCK has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 18, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 790 Oven Locking mechanism problem
I had the same problem. Open the oven door. Press and hold the light switch. You will hear the door lock move back into the correct position. Hope this fixes your problem. This has happened to me twice and holding the light switch always works.
Jul 14, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
130 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
