Question about Fisher and Paykel IWL12 Top Load Washer
Constant dinging My Fisher-Pakel of three years has a constant dinging in the middle of the wash cycle - and will not go further. I called the repairman, and he instantly said "it is the electronic board" which costs $160 without installation. Has anyone else had this problem?
    Scholar:
  • 146 Answers
Please explain "dinging". When the machine stops, does it give a series of beeps and produce a fault code. The fault code is normally identified by the lights ( led's) that flash on the display module when the machine faults. When you look at the lights from left to right each one that is off represents a 0 (Zero) and each one that is lit represents a 1. ie If lights are on off on on off off the code would be 101100. If you can give us the fault code, we will be able to tell you what the problem is.
Posted on Nov 04, 2007
FISHER PAKEL DD605SS TOP DRAWER WILL OT RUN AND THERE IS NO ERROR CODE
If the power is connected and you are able to program the wash cycle, then it appears the drawer close sensor is failing. The controller is unable to detect drawer close and start the wash cycle. Need to replace the sensor or clean it. The location is shown on page 10 item 5 (tub home sensor) in this parts manual
http://data.manualslib.com/pdf/6/519/51826-fisher__paykel/dd603h.pdf?e53609423d7a330cba24becd37b5c6f1&take=binary
Mar 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
I have a fisher pakel double drawer dishwasher and it keeps pausing a couple of times through the cycle how do I stop this
Pausing - how long? The pause means the wash motor keeps halting as it is waiting for the water temperature to increase to the right wash selection. If the heater is sluggish then it will take longer to heat. Try a simple rinse cycle and see if there is any difference. (Rinse cycle will use cold water to complete)
Dec 04, 2013 | Fisher and Paykel DD24DCX6 Dishwasher
Fisher and Pakel WL26CW1 code 246
i would say its one of the boards usually the main motorcontroller
Jan 11, 2013 | Fisher Paykel Fisher & Paykel AquaSmart...
Fisher Pakel dish drawer sends F1 alarm flashing. It usually happens when there is a drop or change in water pressure. Have had 3 repairs on this disappointing product. Only repair person for Fisher...
F1 is a flood fault ir happens when the machine detects water on the base of the unit, to clear this fault you can remove the bottom draw and use a towel to clean up the water this should clear the fault, But usually there is only water on the base if the lid is not closing properly, this can happen due to you putting long utensils in and the lid cannot pull down or you have faulty lid actuators witch is probably the case and they wont pull the lid down correctly, So if the lid wont come down properly water splashes over the top and floods the base. :)
Jul 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Squealing sound on spin cycle.........
Turn power off AT THE WALL,under the wash bowl Spray some wd40 on to the pump at both ends, while this may stop it for a while. Your pump may well be on its way out. you should replace for a new one. bad pumps can cause more problems problems .
Mar 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer non stop beeping in cycle
hi any of these beeps that occur outside normal operation are normally indicating an error picked up by the processor and most times requires service you could try switching off machine and unpluging it for a couple of minutes then plug it back in ,this ill ussually reset any memery faults if they are able tobe reset
cheers grant
Oct 21, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher pakel water saver washer stopped early in cycle and is non stop beeping
www.ths.gardenweb.com/forum/laundry
try this website. I found answers to my questions on it that i did not find here.
repairman who came to my house yesterday said manuals are only available on dvd, not in paper anymore.
saw on the other website that you can order FP parts through Sears. have not tried, so don't know if that is reliable. maybe you can order a FP manual through Sears to tell you how to fix your issue.
Fisher pakel washer taking too long to wash clothes
How long does it take to fill the tub? if the water, on warm stteting, isn't blasting out fast or if, when set to cold, it's trickling out, your cold water valve is shot. I can help with this problem 'cause I had the same experiences you listed.
Oct 13, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher n pakel won't drain
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
Feb 20, 2008 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel IWL12 Top Load Washer Logo
232 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
