Question about Dacor Preference RV36 Kitchen Hood
Raised vent is Rising after being lowered
Raised Vent is Rising
My dacor pinnacle raised vent system will lower but comes back up. What can i do? (model Rv30/rv36/rv46)
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
My RV30S was installed by a qualified service technician in approximately the year 2000. It finally developed a mind of its own. It would raise up and run for a bit and then stop....sometimes it wouldn't raise up or go down....it would switch from fast to slow to stop.....it became frustratingly unusable....
...today i finally took it upon myself to take it apart and I determined that the controller board had fried.
Before I go on -> Disclaimer: These units are hard-wired to live A.C. power. These units must be serviced by technically qualified service personnel. I do NOT recommend anyone to attempt this service. I've worked in the past as an electrical engineer by trade. But to save you time and money you can shop and buy the parts you need yourself and then hire an appliance service technician to safely install them for you. This way they can't rip you off by over charging for the parts and you can certainly count the hours for the install.
The controller board is shown here. In my case, this diode fried.
I found a replacement controller on E-Bay for only $82 bucks and change. At the time of this writing they had 14 in stock.
http://cgi.ebay.com/NEW-Dacor-Vent-Hood-Control-Board-DA-72881_W0QQitemZ120363680495QQcmdZViewItemQQptZRanges_Cooking_Appliances?hash=item120363680495&_trksid=p3286.m20.l1116
It sounds like you may be having the same problem. But please be sure to hire a qualified appliance service technician to do the work. If he quotes a price for the controller board anything over 82 bucks, you will indeed will be in a better position to negotiate a better deal.
Hope this helps anyone that is having or will have the same problem with an older RV30....
Posted on Mar 28, 2009
Pinnacle raised vent RV36 or RV46.
Disassembly will be necessary.
Jul 02, 2016 | Dryers
We have a separate Jenn-Air 36" telescoping downdraft vent (#HV363) installed behind a 36" 5-burner Jenn-Air gas cooktop. The problem is with the downdraft. Specifically, after several...
yes you are right..there are switches that should be detected that the unit is in its proper level ans hould stop and turn the fan on.
you may inspect the railing or where the moving part is moving to find limit switches or sliding switches or sensors..it could have been defective with oil or grease and not making contact to transfer the signal to the controller.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Kitchen Ranges
I need to know how to clean a dacor raised vent
two Phillips screws under side of raised vent removes top complete then switch has plastic piece that slides out with control be careful wires are short and very small easy to break
you will most likely have to change keyboard and buttons
Oct 01, 2017 | Dacor 30" Slim Raised Vent, in Stainless...
Dacor RV 30 raised vent. Replaced control board because it stopped mid way up. Now it is out of sync in that it raises stops and fan comes on as it should. Then when lowered, it lowers all the way and...
First thing is to manually drive it and verify there is no stiction in the mechanism. Most driven systems not ONLY look at limit switches, but time out to turn off the motor should a limit switch fail to work. Being this is is a moist environment and OHMMETER check of the switches MAY be inadequate. The reason is that if the switches go to electronic controls, electrical leakage currents can be tiny and be read by the electronics as incorrect status. You should find that when the switches are open the resistance should be greater than 1 Megohm and less than 100 ohms when closed if they drive electronics. Electronic controls take tiny currents so small leakage currents can give false readings... similarly they typically don't require perfect continuity. If switches are showing readings that are not good, try putting some CRC226 available at Home Depot elect dept in the switches. It is a moisture displacer for electrical purpose. Use ONLY that product as there are other CRC ones that are not suitable.
Feb 12, 2011 | Dacor Kitchen Ranges
Light goes off and on by itself
I have the same problem with a DACOR ECS 130 and also set the breaker panel switch to OFF to prevent the light from turning on-off or staying on. It might help to unplug the touchpad connector behind the control panel or it may be a problem relay on a circuit board. I've had the problem for several years but will start work on it tomorrow because we do not bake often at my house.
Bill (bsquared37@yahoo.com)
P.S. I'm not an appliance tech but have had problems with the DACOR DM024 microwave( made by SHARP) and the DACOR raised vent. I think DACOR products are junk. The raised vent problem required replacing the entire circuit board!
Aug 30, 2009 | Dacor ECS130 Epicure Electric Single Oven
Dacor Pinnacle Raised Vent
Unfortunately i had found myself in this same situation. i have no idea how the grill came out when it was closed, but it was stuck in the fan enclosure underneath the counter. Unlike the poster above i did not have access to the side screws to take the unit apart. instead i was able to remove the front panel, and then unscrew the motor arm from the protective case, and unscrew the case from the unit. This created enough wiggle room that i could raise the right side of the vent cover up and extract the left side out the bottom opening. then it was just a matter of reconnecting the arm to the cover and the cover to the unit.
Good Luck,
-Mark
Jun 15, 2009 | Dacor Preference RV36 Kitchen Hood
New Dacor Vent does not work
Hi, we have a Dacor RV 30 (I think) and twice I have had the unit go up and down endlessly until I turn the breaker off. The problem was water getting inside the switch. The first time, I got a real Dacor replacement ($80?) the next time, I got the part number off the switch, googled it and got two of them for about $4 each plus shipping.
Mar 22, 2009 | Dacor : 36" Pop-up Intake System RV36S...
Pinnacle Raised Vent System #RV36 or RV 46
Ours started doing the same thing. I got it to start working again by gently holding down the up/down button until it started to move. After doing this a few times it started working normally again. Also the keypad can be locked and unlocked by pressing the low and high buttons together for 1 second.
Dec 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Dacor Raised Vent Buttons reply, sc58@aol.com
There are two small screws on the bottom of the top lip. Remove them and pull out the endcap inserts. The top shoudl then pull up with maybe some light force. Then you can get to all the bottons.
Apr 20, 2008 | Dacor Preference RV36 Kitchen Hood
Dacor Preference RV36 Kitchen Hood Logo
1,746 people viewed this question
Top Dacor Kitchen Ranges Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
