Question about Brother MFC-8460N All-In-One Printer
I moved my printer/fax and now I am not able to fax
I can only print off the internet nothing from my work info.
    Problem Solver:
  • 8 Answers
Reboot the system.. leave off for about 30/45 secs and reboot
Posted on Dec 08, 2008
Before I moved, my Lexmark all-in-one printer worked perfectly, but after I moved, everything worked EXCEPT printing of an incoming fax. Everything sounds the same through the sounds the telephone makes as...
Please go through the following checklist:
  • Make sure to plug the telephone fax line from the phone jack in the wall to the Line port on the back of your printer. For more info, please refer to the Lexmark X125 User's Guide.
  • If you have an answering machine connected to the same fax line, be sure to configure it so that it answers first before the fax machine (e.g. if your answering machine picks up on the 3rd ring, set your fax to pick up on the 6th ring or more)
  • If the line has a voicemail feature, disable it or request for a distinctive ring from your phone company.
Sep 14, 2011 | Lexmark X125 All-In-One InkJet Printer
Printer does not communicate with computer.
your problem must be not selecting the right printer...
find your printer in that drop down menu (i.e: in my pc is the 692c) and then accept everything else..ffe6acd.gif
Dec 27, 2007 | Lexmark X2550 All-In-One Printer
HP CM1312 on small office network.
do you have a printer server setup in the network,if so try restarting the server when it happens and see if the prints will print, check with your network administrator, the printer spooler might be at fault, also try adding more memory to the printer.
Mar 25, 2010 | HP LaserJet CM1312 All-In-One Printer
Fax issue with HP Laserjet 3055
Hi. The fax-module in lj 3055 needs a 100% analog dial tone. You might get it working on a internet-phone-line, but HP garantees nothing because there are so many internet-phone-providers, and all of them operates with different specs and line-quality. You might try to lower the baud rate, turn off JBIG compession and error-correction. If the problem still remains, you need to replace your phone-line to a 100% analog line. Not any internet or ISDN/adapter-stuff. You should test your fax on any analog line at a friends house, just to make sure the fax i working anway.
Jul 27, 2009 | HP LaserJet 3050 Printer
Hp office jet 4255 printer not printing anything or copying
ok..first try to make a copy and check if it copies fine or not..
if it copies then hardware is working fine..
turn off the laptop and unplug the USB cable..
turn on the laptop and wait for 5mins and then connect the USB cable..once the USB cable is connected do not try printing..wait for the hardware to get installed..
and then go to the printers folder and check if the printer icon says 0 ready..if it says then try printing..that should work
Feb 19, 2009 | HP OfficeJet 4255 All-In-One InkJet...
Setting up printer
THIS IN ON THE INTERNET PROVIDE I THINK IT IS SAY YOU ARE WORKING OFF LINE, AAL YOU HAVE TO DO IS GO TO FILE LOOK FOR WORKING OFF LINE AND REMOVE THE CHECK MARK AND EVERYTHING SHOULD WORK.
ROD
Feb 05, 2009 | HP OfficeJet 4215 All-In-One InkJet...
Winfax sending issue,
What you describe appears to be a printer driver problem but cannot be sure , I'd suggest looking at : http://www.getfaxing.com/cgi-bin/ib315/ikonboard.cgi?act=ST;f=17;t=413
Sep 19, 2008 | Symantec Winfax Pro 10.03 (winfax10.03)...
Not Printing at all
Is the machine printing the incorrerect colors ? the the key beep , need more info
May 13, 2008 | Brother MFC 210C All-In-One InkJet Printer
Won't print faxes that are in memory...
what type of fax machine is this ? model serial #
Mar 25, 2008 | Epson ACULASER CX11NF All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
