Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca d52w20b keep pushing on button it will finally come on has a great pic when its on dont go off but if i turn it off its hard to get it back on
  • 7 more comments
  • fred_1951 Dec 08, 2008
    ive unplugged it for the night and removed it from the cable box still the same
    hummmmmmmmmmm
    tv is 4 years old
    if its a board ill just replace it or what ever needs replaced
    im really glad i spent the money for all this great advice
    just glad it wasnt a hundred i think id be pissed
    ty for all your help i wont be back
    I NEED TO KNOW IF THIS IS A BOARD THAT I CAN REPLACE
    NO ITS THE SAME WITH THE REMOTE
    wealthwise has asked you to clarify your question to best assist with your rca d52w20b problem:
    Based on what you are describing, you are having a problem with the on off switch relay, it's most likely loose or a short either way it needs to be replaced, Suggest you contact RCA if it's stil in warranty otherwise have local shop take a look, there is not much else you can do except keep pushing the button till it completely goes out.
    how can i clearify it ant more everyone that is posting a problem with this model is the same thing ???????????????????????????????
  • 106 Answers
Capacitor CP150 on the power/deflection board is going bad. It is a 200 microfarad at 16 volts. Depending on you experience level, this may be a repair for an experienced tech. Hope this helps
Posted on Dec 09, 2008
  • 505 Answers
I've fixed this issue several times by purely soldering on the Deflection board. This is the board of the left-hand side when viewed from the back. It is held in by all clips, there are some on the edges of the board and some that go through the board. Pop these up with a flathead screwdriver to get the board out. You will have to undo several cables, most straightforward, but the two farthest from you have clips on them. Wiggle forward and back to undo the clips as you pull them up. The large red wire (coming from flyback transformer) is difficult to unhook so I leave it attached and just flip up the board and solder right there. Use a bright light and magnifying glass to inspect the solder connections for cracks. Heat the connection and add just a little solder to revitalize the connections. I usually find some in the middle of the board causing problems. Also make sure to solder the semi-circle of connection on the bottom of the flyback transformer as they are known to crack and pop fuses.
    Genius:
  • 2,920 Answers
The power button is getting worn out. id get a universal rremote and use it for the tv so you dont have to push the button to turn in on other than on the new remote.
Posted on Dec 08, 2008
    Genius:
  • 1,139 Answers
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
  • Henry McKelvey
    Henry McKelvey Dec 08, 2008
    The bad capacitor will appear to be puffy. I would suggest that you change this before it goes completely out. I have the schematics is you need them.
    Thank you,
    Shuttle83,
    http://www.electron-age-technologies-llc...
  • 121 Answers
Bad connection on power button. does handunit work ok?
  • 4,806 Answers
It could be the problem of convergence ic on the main board of the tv and it needs to be replaced. also one of the capacitors maybe getting heated up and creating this problem. that has to be checked on the main board and replaced.
If you can do this in the OSD give it a go and see what happends
kind regards
  • Lee Hodgson
    Lee Hodgson Dec 08, 2008
    the way you can clarify this is by basic troubleshooting. You state that the TV works fine exept when you come to turn it on!!! this obviously to do with the power relay switch behind the on/off button which has a faulty or has a dry solder, to check this you have to get to the panel which the on/off switch connects to, leave the TV on stand by until you can get this board out and checked for continuity
    regards
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, would venture that the unit has a heat related or more specifically, a cold solder issue. This would require a basic repair which involves "shotgun approach" of checking the reverse side of the PCBS and re-applying solder especially to the power components.
Alternately, a visual inspection would also help potential capacitor faults. Often capacitors that would have leaks or blistered top would take some time to charge itself causing delays in powering ON. Of course normal repair involves replacing the capacitor.
Good luck and Thank you for using FixYa. Happy Holidays.
  • Louie  Role
    Louie Role Dec 12, 2008
    Hi again,
    Any updates or developments so far?
  • 10,594 Answers
Let me know how old is this TV?
Seems it has weak capacitors in power and deflection circuits and needs to be replaced.
    Sergeant:
  • 399 Answers
The switch module button on the main board is bit loose and needs to be soldered to make it proper.
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug your TV from power chord for 30 minutes and plug back the power chord to the tv .
This will reset your tv.
Check for any blown fuse in your tv and also remove the connection from cable box and check for any loose connection between cable box and tv .
I have my samsung galaxy tab a 6 in a case and it keeps turning itself off and if i move it it comes back on why?
Without knowing what case you have that is a hard one? turn Your phone around in case from left to right! if the buttons are not in slots provided then the power button will be pushed in! Note as I said, have no pics, can't tell what kinda case You have!
Apr 03, 2017 | Samsung Galaxy Tab Tablet PC
I have a RCA 52 inch HDTV model D52W20B when you press the power button the green power light flash about 3 or 4 times and that's it no sound no video. Everytime it flashes you can hear I guess the power...
On Deflection board CK capacitors cp150 2200uf 16v if it is puffed up on top it is bad their is 2 more caps in same circuit replace them also cp114 cp120 220uf 35v also resolder all pins on FBT flyback Transfomer
Nov 10, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV turns off and on 50 times before finally kicking in!!!!
that is not a bad fuse! you probably shouldnt be doing anything to the set if you dont know what you are doing! These are well known for bad solder around the flyback or glycol leaking from the tubes on the boards inside. i suggest that you get a certified tech to work on this set.
Sep 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
The power button on my tv pushed in
The board is fine, unless u cracked it. You need to change the buttons only. Shouldn't be hard to find. Look for RCA microswitches.
Apr 08, 2009 | RCA P61927 61" Rear Projection Television
HAVE TO FUMBLE WITH ON AND OFF BUTTON 15 MINS BEFORE SET COMES ON
There are several bad capacitors in the power supply. Pretty hard to do yourself unless you have a technical background but an RCA technician can fix this easily.
Mar 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV won't turn on!
On the deflection board there is 3 capacitors cp150 2200uf 16v if puffed up on top it is bad so then replace other 2 capacitors as well 220uf 35v. cp114 cp120
Feb 12, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
Tv screen
try, mcmelectronics, vancebaldwin.com, tritronics
Oct 09, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
13 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
