My kenmore washing machine will only fill partially and seems to be pumping out at the same time. What would cause this. Thanks, Jim
If the top of the drain hose is to low, the machine will begin siphoning out the water once the water reaches the height of the bend in your drain hose. Solution - Attach the curve of the drain hose to the top back of the machine above the height of the water level in the machine. You may need to extend the drain hose if their isn't enough play in the hose. If this does not solve your problem. More information would be needed to give you other possible solutions.
One other possibility is that the drain hose is to tight in the stand-pipe and it is also creating a vaccum and siphoning out the water. Your local hardeware store should carry an anti-siphon valve that can be installed in the drain hose to fix the problem. Good Luck
Posted on Dec 08, 2008
    Sergeant:
    Champion:
  • 291 Answers
Check and make sure your drain hose is as high as 2/3 hight of washer ,,, if not it will drain as it fills ,, also make sure the drain hose is free and not down in the drain pipe to far / larry
My Kenmore 500 top loading washing machine wont work right. sometimes it will work and other times it wont. I will put a load in it and sometimes when it hits the rinse cycle it seems like it gets stuck...
for the top loading washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.and the unit top load have drain pump you must be up the drain hose up to 90cm from floor lever to make the water lever is make in normal,the water automatically goes out by drain pump.
and for unbalance most of all top loader have problem in unbalance, the main reason is overload or the type of cloth you wash.
Nov 02, 2013 | Kenmore 24032\24036 Top Load Washer
Kenmore washing machine fills and pumps out but does not agitate or spin. The model is a 970-C29052-00 Serial #XL94933842. Thanks, Tim
Hi Tim and welcome to FixYa. I am Kelly.
I will be replying 2 times here but wanted to send this first one now so you can possibly check the lid switch. The machine will fill and pump out but if the lid switch is not functioning it will not agitate or spin.
As you just open or close the door or lid you should hear an audible click from the micro-switch. If you do not hear that click, The lid switch has a problem. (loose or failed)
The model number does not cross:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=970-C29052-00&=part+number&pathTaken=partSearch
Search results: "970-C29052-00" We're sorry. No exact or partial matches were found.
This is a common lid switch:
http://www.appliancepartspros.com/Appliance-Parts/WHIRLPOOL-Lid-switch-assembly-item-number-AP3100003.aspx
but may not be yours due to the model number issue.
There are 2 other possibilites also. One being the water level control or pressure switch and the timer assy. Most of the time the lid switch is the failure.
Thanks for using FixYa,
Kelly
Apr 02, 2010 | Washing Machines
Kenmore Front Load Washer filling up and giving LF warning
The FL error code means:
Flood Condition:
FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed
With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit.
Press STOP/CANCEL to clear the display.
This problem I see on these are the water pumps getting clogged with lint or other things, causing the pump not to pump all of the water out at times.
There is a check "valve" in the drain assembly that seems to sometimes cause problems with the FL error code. You can remove this piece, and might avoid changing the pump.
Calypso Service manual: https://docs.google.com/leaf?id=0B5If-wTgYWH5MTQ0OGIxZTAtZjQyMy00MzEzLWJkMzYtZTdmOTY2OTk3YTA4&hl=en
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!##@
Oct 15, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore washing machine 110.22082 does not drain
you probably looking for a new drain pump ( control board also possible)
Sep 05, 2009 | Washing Machines
Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Aug 27, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Leak top load kenmore
Excellent use of your deductive reasoning skills. You may be right on both assumptions. It is not uncommon for the pump or the drain hoses to develop leaks over a period of time. You will need to remove the outside casing of the washer, however to get a good look. This link explains how to replace the washer pump:
http://www.fixya.com/support/r397092-replacing_water_pump
Even if it is not the pump, it gives you necessary steps on how to disassemble the washer. Step 7 of the write up tells you where the pump is located. Inspect the two hoses for cracks and leaks as well.
NOTE: You will need to by-pass the lid switch, however, with the case removed in order to fill the washer with water. Or...you can fill the wash tub partially, shut the unit off, unplug the washer and remove the case and look for the leak that way as well. Let me know if you wish to attempt to by-pass the lid switch - this does not involve cutting and splicing any wires.
If you require further assistance please post back and let me know. I hope this helps you.
Jul 23, 2008 | Washing Machines
Kenmore 80 series leaking
the pump is most likely the cause if you have mach skills i can walk you thru it on how to open the unit and check it let me know
Jan 24, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine agitates but won't drain
if it has a filter, check for blocage. otherwise check hose down to the pump and for foreign objects (coins etc) in the pump
Mar 31, 2007 | Kenmore 80754 Top Load Stacked Washer /...
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
