FixYa.com
Tags:
Lexmark X6150 All-In-One InkJet Printer
Printer pulling on paper (by 5 users)
posted by angelaronay on Feb 23, 2007
My lexmark x6150 will not print. When I install the paper and try to print something, the paper is pulled to the right. The printer then stops and saids that there is a paper jam. I remove the paper, power off the system just as the printer screen saids and install new paper and try again--the same results. I have trouble shooted to no avail and the paper is installed correctly. Has anyone else had this problem? Any suggestions?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by sueoj, posted on Jul 01, 2008
I have the same problem. Have had this printer for years and the problem just started. Have not been able to fix it.
Comment by trina5, posted on May 24, 2008
I have the same problem the paper pulls to the right, printer said jamed. So I start all over again and the same thing happen, paper pulls to the right
Comment by Guest, posted on Feb 19, 2008
Same problem here.... there is nothing blocking the paper from going though the printer. I just can not print. Please let me know if anyone else has found the fix, I really can't afford a new printer right now..
Comment by cooldeli, posted on Dec 17, 2007
Hi, followed your advice on the problem where the paper pulls on the right and the printer gets jammed, however I still have the problem. Any other suggestion
Best Solution
posted on Jul 22, 2008
FixYa! (100)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I have the same printer with the same problem. I found a pen my 3 year old had put in it. After removing the pen it worked fine. A few months later it is doing it again. I don't feel anything in it & I don't hear anything in it when I picked it up. I'm not sure how to take it apart to see what might be in it...
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 10, 2008
Helpful (85)
bitpharked
Rating: 85%, 1 votes
Just found why I kept getting paperjam error on my X6150. When you open the top, you will see 4 plastic plates sitting over the main rollers. These plastic plates have 2 little mini rollers on each plate that sit on top of the main rollers. I found that these plates were all sitting back about 5mm back to where they should be. When mine jammed originally when a pen unknowingly fell into the paper feeder, the motor does a quick reverse motion and pushed these plates backwards, not sitting on the roller correctly. I pushed each of these plastic plates forward(towards the control panel) and each clicked back into place. No more paper jam and feeds normally.
Solution #3
posted on Feb 24, 2007
Thanks for Trying (70)
CoachTim
Rank:Wiz Wiz
Rating: 80%, 289 votes
When did the pulling paper happen? Was paper jammed and removed and then this problem occured? If so check for a stuck piece of paper in the leftside of the roller/feeder. Do the right and left feeders seem even? When the paper starts to feed tightly hold the paper on the rightside and see if the leftside frees up.
Let me know what happens.
Good Luck,
Tim
Solution #4
posted on Jul 02, 2008
Not Rated (0)
sueoj
Rating: 0%, 0 votes
My husband took the top cover off the printer and took a good look inside with a flashlight. He found a hot pink crayon stuck where the paper feeds through. I guess I should have had a better look initially, since the paper never made it all the way through the printer. Works like a charm now!!
Can you Help with these Printers problems?
Lexmark 6570 all in one
I just hooked it up for a fax... Answer This...
not printing out anything
it's saying it's printing but... Answer This...
lexmark x6150 cannot print
Don't know where I am going... Answer This...
My mom has given me her lexmark...
How do I connect it to my... Answer This...
blank paper ,no printing
it looks like its printing but... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
