Question about Kodak EasyShare V530 Digital Camera
E 45 error
I can turn on my camera but only get an E45 error. What does that mean??? Can you help me, please!!!
  • 4 Answers
My camera has the same problem. How could Kodak get away with that? Kodak V530 is a piece of garbage. I called Kodak's customer service. They offered repair for only $110. It is ridiculous, why we have to pay for manufactured defect? Take a look at the Kodak V530 on eBay. There are a lot of defective V530 up for sale. The government should review this E45 error lens issue, and have them take care of that. Or we should never buy Kodak again!!!!
Posted on Jan 20, 2008
Is there any place in uk to repare camera-kodak v530
Posted on Jun 15, 2009
My V530 had the same problem. When you turn it off smack the lens against the pam of your hand a few times and it will retract. Turn the camera back on and it will work as it should once more. This took a few tries for me, but now my camera is up and working again! Good luck.
Posted on Jul 14, 2008
I got the same preoblem with this.p..o..c.... they want 110 but, is this a manufatory defect they must fix.so I upset about it.
Posted on Apr 26, 2008
It most likely means that the lenses are stuck, smack camera against your hand before throwing it away as that just might fix it...
Posted on Dec 20, 2007
lock123
  • 6831 Answers
SOURCE: E 45 error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
mads_aye
  • 58 Answers
SOURCE: my camerais say error #e45
if you get this error message and it's telling you to see the user's guide - the user's guide will actually just tell you to do powercycle
with several powercycle (removing batt> putting it back in after 10 seconds> turn cam to auto) it may work again
if not, it needs repair
the user's guide doesn't have this defintion as it's an engineer code, only the repair center can determine or resolve
Posted on Feb 13, 2008
BillB-SA
  • 2761 Answers
SOURCE: Camera error #E45
Your fix could be as simple as cleaning the camera's battery contacts, or it could be something more serious and expensive. Before you pay for expensive repairs that you may or may not need, check the Kodak Help Center by clicking on the link below. It uses a simple Q&A format to diagnose problems and propose solutions.
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Posted on Aug 03, 2009
lock123
  • 6831 Answers
SOURCE: Camera error # E45
Hello
Regards
Andrea
lock123
  • 6831 Answers
SOURCE: error codes e45
Hello
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 14, 2010
ERRORE E 45
Hello and Welcome to FixYa!
E45 error message sometimes means that the lens is misaligned, This error is also may be due to failure of the control system.
To solve this follow the given solution:
You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. If none of these works then you can think of taking consensus with the service center.
You must keep in mind that to open the camera without good experience is not recommended and might tamper the delicate unit so best option is to Contact Kodak to see if your camera is still under warranty, otherwise contact any Kodak Cameras service provider, your problem will be solved.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Aug 04, 2011 | Kodak EasyShare V610 Digital Camera
How do I fix error e45 for a kodak LS753
Error # 45 means the retractable lens is stuck, possibly caused by a drop or sand or other gunk that has jammed the gears. It will cost more to have repaired than the camera is worth, so you have nothing to loose by trying this. Hold the camera in your strong hand with the lens away from you and smack it hard into the palm of your other hand (if you can't take pain maybe use the heel of a shoe) pretty hard. It may take several tries. Best results - smack camera immediatly after turning off.
Oct 14, 2010 | Kodak EasyShare LS753 Digital Camera
Getting an error code E 45
Error 45 in your camera clearly indicates it is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error you have to update the firmware and the error should go away.
Thank you !!
May 23, 2010 | Kodak EasyShare CX7430 Digital Camera
It shows Camera error 45 what to do?
The Error 45 report you have seen on your camera is related to a lens issue. Something has caused the lens to jam or stop working. When it does you get the E45 error. Update the firmware and the error should go away
Dec 24, 2009 | Cameras
My camera kodak easy share v530 has error e45 the zoom doesnt go in when i turn it off. when i turn it on it says error e45
E45 means it has a lens error., the gear of the lens is already defective you need to call precision camera for repair toll free 1 800 665 6515
Nov 01, 2009 | Cameras
Kodak digital camera V705 -error 45
Hi!
E45 means that a focus error occurred or the MCU BOARD malfunctioned. I'm afraid you will have to give it away for a repair. It's a hardware problem. You should contact your local Kodak service center.
Tom
Aug 01, 2009 | Kodak EasyShare V705 Digital Camera
Error E45
Turn your camera on and smack the camera against your hand. The E45 error means your lens is stuck. The lens on my V603 was stuck open, when I smacked it against my hand it closed and now works fine. Give that a shot.
Jun 23, 2008 | Kodak EasyShare V603 Digital Camera
Error #45
Error message appears on EVF/LCD screen
  • Turn the camera off, then on again.
  • Remove memory card from the camera.
  • Remove the battery and wipe the contacts with a clean, dry cloth ( Battery life).
  • Insert a new or charged battery ( Loading the batteries).
  • If all else fails, get customer support help
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Jan 04, 2008 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare V530 Digital Camera Logo
411 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
