Question about Goodman GDS80904BNA Open Flame Heater
Goodman Furnace GMP050-03
Goodman Natural Gas Heater just shop firing First stage fan comes on Electic Ingiator Comes on Get red hot as normal but gas does not come on to Ingite and warm up to start the second stage Blower
You either need an ignitor...even though it gets red it may not get hot enough...just repaired one doing the samething yours is doing same model number as yours. If that is not the problem the only other thing it could be is the circuit board
Posted on Dec 10, 2008
Furnace blower won't turn on
You may need to replace the sail switch. It senses the fan speed and when it connects the gas valve should open and furnace should fire up.
Dec 09, 2013 | SUBURBAN MANUFACTURING Rv Motorhome...
Model gch90703bxab
There could be other problems but check and see if your igniter is not burnt out. Ours did that and tried to ignite for two days and then I found I had to change the igniter.
Dec 05, 2017 | Goodman Manufacturing Goodman GMH950704CX...
Furnace will not light,on Goodman Furnace model#GME80704BX
Is the gas turned on or does it come on but goes off quickly?
Oct 06, 2012 | Cozy Enclosed Front Console Heater 70,000...
When the pilot lights the furnace the fan comes on and the fire goes out
could be a bad roll out switch a small thermal device located around the base of the burner ,locate on wirind diagram an ck with ohm meter should read closed , also could be to much gas presure if natural gas get the gas co. to check presure , also could be a faulty equipment ground from supply from breaker panel make sure well grounded and connections tight ,must have this gnd to keep gas valve open , hope some of these ideas help .
Dec 28, 2009 | Goodman GMS90703BXA Heater
I had a friend install my new Goodman GMH950704CX 95% 92,000btu 2-stage multi speed furnace. When I switch the thermostat to HEAT and turn it up to 80 degrees, the inducer fan comes on, then the igniter...
he didnt hook up the secondary heat exchanger drain properly. common mistake and he probably threw away the bag of parts to do it which came with the furnace . loook at your installation instructions
Sep 29, 2009 | Goodman GMS90703BXA Heater
WHEN THE HEATER COMES ON THE FAN STARTS INSTANTLY AND BLOWS COLD
Do you have a heat pump? If so this is normal. You are probably used to a gas furnace. There are heat pumps that do have a delay though. Look on the circuit board in the air handler. There may be a set of pins that say 0-30-60-90 yours may be at 0. Also some digital T-stats offer that function for delay off to get the extra heat or cold from the system. Find out what the model number of the air handler and call the Goodman supplier in your area to see if you have these options.
If you have a gas furnace and it's not delaying the blower there is definately something wrong.
Mar 17, 2009 | Goodman Heating & Cooling
Goodman gms9090 furnace
Based on your description I would guess that there is a "leak" somewhere between the gas valve and the actual fire. Use soap bubbles to check the connections at the gas valve. Also check the gaskets in the Gas valve the same way. Lastly there may be a cracked or misaligned burner causing the "leak". Best of Luck!
Jan 29, 2009 | Goodman GDS80703ANA Open Flame Mid-Size...
Main Fan won't turn off even with thermostat removed. Burner not
There is a chart with the wiring diagram and othere charts that will tell you what the 6 blinks are for. That should tell you what is wrong and what part you need. Sounds to me like the board has an issue or the gas valve is locked out.
Jan 10, 2009 | Goodman GDS81155CNA Open Flame Mid-Size...
Heating & Cooling Logo
138 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
