Question about Lexmark X73 All-In-One InkJet Printer
Paper will not go through properly
When trying to copy, the paper drops down to the proper position when it starts to copy but then it stays in the same spot while it is printing. About halfway through printing the paper starts to move again and finishes. The print on the copy is all at the top of the paper and blurry.
Thanks for your help. Bob Kincart
  • 1 more comment
  • Anonymous Dec 11, 2008
    pape will not go though printer
  • Anonymous Dec 22, 2008
    Paper feeds half-way, begins printing, but paper will not advance. After the icon displays about 60% to 100% of printing job, the printer will not advance the paper and paper jam announcement is relayed.
    Upon pressing paper feed the printer seems to lock up. I have removed every paper that I can find, but I have no way of disassembling the unit to find if any paper pieces are left in the machine. All the paper has come out without tearing (complete) for this last job attempt. I have no way of knowing what is locking up the unit, preventing the paper from properly advancing during the printing job.
    Ransal
  • fayem Dec 27, 2008
    When I try to print the paper does not feed.What can I do? When I "paper feed" the paper it stops just before the print head so everything prints on the very tip of the paper. HELP!!!!
I didn't think I would have this much trouble finding a solution to my problem. I thought you people would be able to help me. I am going to buy another printer, but not a Lexmark.
Posted on Dec 09, 2008
Hp Officejet 6500 won't feed paper
Problem:
The 'drop down paper grabber' gears are not turning, and the printer gives you an error saying to make sure there is paper in the printer.
All of the fixes on the internet are for working printers, and their approach is to clean the rollers if they are not grabbing the paper. They are assuming they are turning properly and the rubber grabbing wheels are wither dirty of dried out.
In my case, however, the gears were not turning, and so the rubber grabbers wheels were not turning, even though the whole 'paper grabber' unit was dropping down properly
Solution:
Just inside the paper loader tray, along the top, there is a metal rod. It is about 1 inch from the front.
The gears from the drop down paper grabber are supposed to meet a gear that resides on this rod and sort of floats on it. However, the gear on my printer slipped to the left, and was not making contact with the other gears.
You can gently put your finger on the gears as you do a copy command, and confirm this.
To fix the printer, I just slid the floating gear over to the right and into place, and the paper began feeding properly.
Why there is nothing to keep the gear in place is a mystery to me.
Aug 20, 2014 | HP Officejet 6500 Wireless All-in-One...
Feeder in my canon mg5250 is not working properly. It seems to feed one side and twists the paper and then sticks.
Did you check, nothing is in the paper feeder? Could be just a little piece of paper or a staple is blocking proper functioning of the feeder.
Keep the paper try clean and take care you never drop or leave anything in the printer, that does not belong there.
Mar 08, 2014 | Canon Pixma Mg5250 Imageclass Inkjet Scan...
Kkonika minoltaprinter 363 paper not detected prperly
size detection assy stays back side of Tray.
if their tension plate moves out of position , then such issue happens.
Apr 12, 2017 | Konica Minolta Office Equipment & Supplies
My hawaiian breeze 16" fan isn't working properly.
try wedging a paper clip in between to hold the gaurd in place.
Jun 17, 2013 | Cars & Trucks
Get paper mismatch error.doesn't happen if I just copy,but has started giving paper mismatch everytime I try to copy from computer. I have tried everything suggested in tutorials. It doesn't copy if I just...
Clean the sensor on the right side bottom of the carriage assembly with a damp Q-tip. That sensor gets covered with ink and can't see the paper properly. You clean the underside that looks down at the paper as it passes thru...
Jul 21, 2009 | HP Photosmart C5580 All-In-One InkJet...
Cx3650 Problem with paper feeder
There could be an issue with the gear inside your printer now that is why it is not feeding the paper through properly anymore. Please try this basic troubleshooting steps:
Turn off the printer. Disconnect the USB cable from your printer. Open up the whole scanner unit to see if there are objects blocking the way of the printhead or if there are any objects down the paper feed area. Check if the cartridge cover is closed properly. Toggle the paper guide left to right back to the proper position. Load 10 to 20 sheets of regular paper into the printer. Turn the printer back on. Do a standalone copy.
If it does the same thing, please log on to support.epson.com. Click on help me find a service center to the right of the page to find an epson certified servicer near to your area.
May 12, 2009 | Office Equipment & Supplies
Paper Jam light
Make sure paper is loaded properly (pushed down under the end clips.) There could be a small piece stuck in the rollers somewhere. Look from the side door.
Aug 20, 2008 | Canon PC-920 Black and White Copier
I have a brother copy/fax/print MFC 5860. i am unable to print. no paper jam..the screen reads: no paper fed #2. reload paper, then press start. i have paper in both paper trays and have autoselect...
lower paper feeder is out of position. you have to open the printer and get to the lower paper tray feeder. push the plastic gear wheel and axe into position again.
May 15, 2008 | Brother Office Equipment & Supplies
Caution check scan platform
you need to check the scanning platform that is above the paper tray. it may be loose. you will have to close it properly and hopefully it will start working.
regards,
kumar
Oct 15, 2007 | Canon FAX L-120 Plain Paper Laser
BLANK COPY
The blue developer handle needs to be swung to the 3 0clock position. then try again
Feb 21, 2007 | Canon imageRUNNER 400S Copier
Lexmark X73 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
