Question about Mitsubishi WT-46809 46" Rear Projection Television
Tv is (bowing) rainbow effect, now turns on for second then shuts off
Have a mits wt-46809 the screen has been doing a rainbow effect (bowing) everyonce in a while, all colors are on screen, turn off might work great then dose same thing later, or few days later. now the tv will turn on for split second green light on front, then power off, with no picture, this tv is 4 years old friend gave it to me should i try and fix it or junk it. still looks like new!!! Have some electctronic back ground, just now on tvs, any area i should start at.... coponent Ect.... have ordered a manual
  • Anonymous Feb 25, 2008
    REPLACESD THE ICS AND THEY STILL WONT MOVE. REPLACED WITH NEW ICS... WHERE IS THE FUSE FOR THE B PLUS,
  • 4 Answers
I had the same problem. The issue may be the same although I am not sure the powering off is related to the convergence issue. This is what I did: 1. Order the STK392-570 convergence IC and heat sink thermal transfer paste( I silicone based)..(make sure it is a reputable company so you don't risk getting bad components, I got them from an electronics supplier in MD) 2. UNPLUG YOUR TV AND ALL COMPONENTS!!!! 3. Remove the back cover and black plastic cover. (retain all parts) 4. remove the retaining bolts and screws on the black plastic tray (they are on the sides verticle mounted and front center as you are looking down on the tray.) This allows the tray to slide out like a keyboard on a computer desk. DONT PULL IT OUT YET!!!! 5. Just above the boards there is a shade board that slides out. Carefully pull it out. 6. You will have to unplug all cables ON THE BOARDS except for the RED ONES ON THE FAR RIGHT and provide tension relief for the cables by carefully unraveling them. The cables are marked on the connector and match to the markings on the board (I.E. KM, all connectors are marked with a two letter designation) Just disconnect the cables from all the boards and nothing elese. 7. Now carefully slide the tray about half way so you can see the contents of the entire center board. This is the board you need. Look in the back center of the board. There is a really large heat sink. The ICs are on the back side of this heat sink. They are held in place by a retaining bar that sandwiches the heat sink to the ICs. 8. There are some connectors on three sides of the board that are flat and white. CAREFULLY ....AND I MEAN CAREFULLY pull the left (as you are looking at board) ones up and disconnect from the center board. The ones on the right (I think they disconnect from the right board). 9. Unscrew the board from the plastic tray. There are a lot of them around the perimeter and center as well as the ones that hold the heat sink onto the board ( they also hold the board onto the tray.) You have to remove the "sandwich bar" (refer to 7)in order to get at the screws that hold the heat sink to board. (you have to unscrew them. 10. There is a box shaped cover on the left front part of this board that is screwed onto board and is also part of the retension to the plastic board, remove it to. (always remember to be careful when tugging, unscrewing, ect as it could result in breaking somthing) 11. There are black plastic tabs to the rear of the board. Unhook those and CAREFULLY lift and pivot the board forward and then up and out. 12. Now comes the easy part. You may have to pry the heat sink from the ICs carefully because of heat sink paste. Clean off the heat sink (dont use cleaner, just wipe the old grease off) 13. Use a good soldering iron (PACE, regulated, good desoldering iron) The temp just needs to be high enough to heat solder. 14. MAKE SURE YOU REMOVE THE CARD THAT WE TALKED ABOUT EARLIER that is in the front left of the board. You dont want it to break. Turn the board over so the chips are facing down. Take the desoldering tool and put it over the pins and in a circular motion until it heats the solder and push the sucker button. Do this to all of them that relate to the ICs. DONT KEEP IT TOO LONG ON BOARD. once you have done that to all pins, gentely tug on the chip wiggling it out. (carefully!!!!!) if you feel resistance desolder a little more. Make sure your desolder device is giving enough suction. 15. Now solder them back on and make sure you dont create any cold solder joints. This would be bad!!!! 16. Apply a decent amount of thermal heat transfer (grease, goo, ect) Make sure you do this or bad things will happen. You need this stuff. You can get it at radio shack. 17. Now put it back together and hurray you are done... Hope this helps... GOOD LUCK DJ
Posted on Jun 22, 2007
Seems like a lot of work...How much would the repair cost normally?
Posted on Aug 20, 2008
Where is the fuses though thanks ive done all that
Posted on Feb 25, 2008
Replace convergence ic's and perform convergence alignment
Posted on May 24, 2007
Mitsubishi WT-36809 turns on for 2 seconds and then turns off. The error code is 22. Any ideas?
Verify the model number. Some of these Mits. family have bad picture tubes, and oil spills out onto the signal board. Look inside front panel, RHS tube, look below it onto signal board. If you see an oil puddle, then tv is toast!
Jan 18, 2011 | Mitsubishi WT-46809 46" Rear Projection...
I have a model # WT-46809 and in comes on and within 5 seconds shuts off error code repeats 2 pause 2 pause2 over and over what do u think it is
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
To get fixed either call in a local TV repair company or goto sites such as www.TvRepairKits.com to get a repair kit with instructions.
Oct 15, 2010 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi problem
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
  • Screen looks 3D
    Colors don't line up
    One or more colors can't be adjusted when using the convergence menu.
    Screen is bowed or warped.
    No Audio / No Video
You can see some examples and find a fix here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 25, 2009 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 wont turn on
it will need to be checked by a tech to determine the exact cause
electech
Oct 29, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi wt-46809 not turning on
Your convergence amp ICs have most likely failed and that will shut the TV down. You need to replace both convergence ICs they are both STK392-570 you can get replacement ICs with free instalation instructions at the following link.
http://servicemanuals.vstore.ca/
Jul 18, 2008 | Mitsubishi WT-46809 46" Rear Projection...
WT 46809 Big Screen
Good Day y'all;
When the is picture being intermittent and bowing then the most common problem is that the convergence circuit has failed or is failing. If you don't get fixed, the will go DOA soon.
Good Luck, big IRISH.
May 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
Thanks for your help with the Mitsubishi WT 46809 but, there is more:
Fuses and IC's are soldered in on large PC board in center of chassis....
Your model is a tight fit that is usually repaired by chassis pull first, then
board repair, normally by a skilled Mits tech........
Oct 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt 46809 Projection TV Mitzubishi
First check threads and do self diagnosis. Then live chat!
Mitsubishi WT-46809 46" Rear Projection Television Logo
834 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
