Question about Nokia 3200
Memory Problem In my Phone memory I have 240 Phone number but it does not display the number. I went to contact settings and checked everthing is proper. It shows phone memory is 94% when i am connect the phone through Ir to a system it shows only 4 number then i backup the number, rest i could not take the number,it shows problem in memory read error. When i try to use the camera, display just goes down . My games, gallery , Photos everthing washed way . i d'not know what to do , Please Help
    Scholar:
  • 91 Answers
Try using a data cable and Motorola phone tools if that doesn't work get mobiledit forensic version and see if that can't find your numbers.
Posted on Mar 01, 2007
All my contacts on phone memory dissappeared (N97) but when someone calls his details appears normally on the screen as if contact was there normally . Connected my phone to PC suite and nothing on t
if you have an Android phone... the contacts are still there they are just not displayed. they may be hidden.
press:
Phone
Contacts
Menu
Settings or Display Settings or Contacts to Display.
(it may be different depending on your phone)
All emails that you have synced with the phone should be displayed. make sure you click each one and check all the boxes including "All Other Contacts"
Hit Save or Done if your phone asks you to.
Oct 30, 2012 | Cell Phones
Caller name not displayed in nokia 5230 phone
Which memory is in used" phone or sim card" that you have set in contacts memory in use"?If there are one number in the same name or same number in both Sim and Phone were saved,besides you select both the memory in use only number will display.So select memory in use in only one i.e.phone or sim.Good luck
Jul 14, 2011 | Cell Phones
I am using a Nokia C5-00 phone that I got yesterday. Seems like it has the latest software version. But for some reason, it doesnt display the contact name during an incoming call or while listing missed...
This is a very common issue with nokia phones. It occurs mainly when you have stored a particular number with more than one name.
For example if you have a number stored to your sim using one name and you have it stored to your phone memory with another name. In most cases, when you install a new SIM card to a nokia phone, it might copy the contacts from the SIM memory to the phone memory automatically and add some extra information or edit the name automatically. This can cause a conflict between which name the phone should display when any action associated with the number is to be performed. In this case, it displays just the number.
To solve this problem without having to delete any contact, all you need to do is to go to your contact settings and then select which memory should be the default display memory.
Hope this helps you? Please comment for more information and thank you for using FixYa.
Apr 03, 2011 | Nokia C5 Cell Phone
How do you sync number from sim
try going to contacts then look for options, select it, select contacts to display, then check "sim Only" after that all your sim contacts would appear now go back to options select "mark/unmark" then select "all" all of your sim contacts will be checked now go back to options select "copy" lastly select phone memory, wait for it to finish after finishing, go back to options, select settings, then select contacts to display now choose phone memory instead of sim.
Aug 20, 2010 | Nokia 5230 Cell Phone
Sir when I am dailling my numbers are not recorded
HI there,
For clarification of your problem, may I know what exactly the phone model that you have.
Did you mean that only number and not the name of your contact appeared on the screen or into your call registry?
In some cases like this, it just happen that you have eventually has done a double entry of the number on your phone book or into your cellphone. If you have entered or save 2 or more names on one number, the unit will only display the number and not the name assigned to it, because it will not display multiple name on one same number.
Also check if your contact was saved into the phone memory or into the SIM memory. Check the phone book settings and check the memory in use, by default choose >>Phone - SIM memory, to use both locations.
Please kindly let me know, and hope to hear more info soon.
Thank you for using fixya.
Jun 22, 2010 | Cell Phones
My phone no longer displays contact name on incoming calls, just their number
hi, the problem could be that you have all the numbers saved on your sim memory as well as on the phone memory, if this is done you will experience what you are experiencing...
also it could be that you have disrupted the setting on the phone..you could check your contact setting, you select NAME AND NUMBER.
Jun 02, 2010 | Nokia 6310i
On nokia 6500 slide contact name not displayed when someone calls just contact number help
Hello
The problem you are experiencing occurs when you store your contacts on your Sim card and the memory in use is your phone memory or vice versa
what you should do is this;
In your contacts settings copy your contacts into your phone memory and set your memory in use to phone memory
You wouldn't experience this problem anymore
best of luck
Feb 19, 2010 | Nokia 6500 Slide Cellular Phone
How get do I get my incoming phone numbers to be displayed
Most phones will only do what you require if the contacts are stored on the phones memory instead of the SIM memory. This will also prevent you from assigning photos to contacts and one touch speed dials (i.e. press and hold a number to dial a stored number) Try copying all your contacts to the phones memory. If you see duplicate names, go into phone book settings and adjust setting for phone just to look at phones memory and this will stop duplicates being shown. hope that helps?
Apr 26, 2009 | Nokia 6600 slide Cellular Phone
Phone lock code
You need to take the phone to a mobile store and ahve them reset the code for you
Jul 20, 2008 | Sony Ericsson W550i Cellular Phone
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Nokia 3200 Logo
80 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
