Sharper Image SI321 -  I cannot get clock to function after changing the battery. I'm getting power (charges my iPod) and the display light goes on, but there is no actual numbers displayed and none of the buttons work ... set, radio, soother. Is there an internal reset button?  Thanks, Phil
  • mdertien13 Jan 22, 2009
    The second si321 we pruchased is not anything like the first unit we purchased. Second unit does not hold the time or alarm time-unit keeps returning to 12:00 am. The display flashed low battery and after changing out the 9v battery, the unit had to be reset for time/alarm etc (odd considering the bottom of the unit states the 9v battery is for clock backup) even with the unit still plugged in to the wall. Now there are no display numbers - only the blue back light - no sounds,etc
  • 36 Answers
SOURCE: Lost functionality
I suppose I should offer my comment as a solution?
I too have the exact same problem, with a EX-Z850, and an online search turns up others with similar Casio Exilim models, with the same problem. It involves a malfunctioning Disp, Zoom, and non-functioning Set button, with all other functions working OK. Casio Support seems to recognize the problem, and indicates it has to be fixed at one of their authorized repair centers. Start with their online system: https://www.ecasiorepair.com/
Posted on Dec 05, 2007
SOURCE: Bose Wave Radio - clock display turns off after 1 minute
Hold down CD Mode button and press On/Off button to set display to always on.
Posted on Apr 10, 2008
SOURCE: SHARPER IMAGE S1785 alarm BUZZ to SOOTHER sound
Johnny, push "mode" once. The alarm symbol blinks. It is also displaying the alarm mode. Pushing "display" changes the alarm source. Bill
Posted on Oct 14, 2008
  • 70 Answers
SOURCE: Z213B Clock Radio
d3b32db.jpg 281dcb6.jpg Good luck.
Posted on Dec 20, 2008
SOURCE: 03 chev silverado radio on but no sound
My van radio runs on 2 different fuses- both in the fuse box under the dash. One runs the lights the other the sound. Hope this helps.
Posted on Jan 11, 2009
Replacement Power Supply AC Adapter Sharper Image SI601 S1601 51601 Travel Sound Soother 20 with LCD Alarm Clock your problem?
I also am looking for a replacement power AC adapter cord for a Sharper Image SI601. I tried a radio shack replacement, and it works about 50% of the time.
Thanks!
Chris
Aug 07, 2012 | Sharper Image Travel Soother 20 Clock...
How to change alarm sound on s1785 sharper image
Hello
You want to decrese the volume of alarm sound I assumes, and provides this solution.
To decrese or increase it volume.
[1] Press Mode switch. Alarm time and icon flashes on the display.
[2] Press [5] to change and select alarm volume.
LO=Soft
HI = Loud
UP = Ramp Up.
OK.
Nov 06, 2011 | Sharper Image SI785 Clock Radio
I have the S1721 Travel Soother Radio Alarm Clock. It has stopped & a radio technician said it can't be fixed. It is THE best radio on the planet because it has a radio timer. I cannot find anything...
I came home and found a weird display showing 12 00 and ______f. Nothing worked, even when I unplugged it and took the batteries out. (I really, really like this clock radio so I wanted to find a solution).
I looked for a "reset" button and found one in the back inside the battery case (you have to remove the battery case cover). I took a pin and pressed it into the reset slot. I had to do this several times, turning it on/off and pressing several buttons and plugging, unplugging the clock/radio. It cycled through several times, then slowly the functions started to return, almost one function at a time. After several cycles of this, it turned itself back on and started working again!
Dec 01, 2010 | Sharper Image Travel Soother 20 Clock...
Need 12 hour setting instead of 24 hour
I owned mine for years. This seems to happen when the power goes out. Push the mode button twice to get into the time set section. Once you are there, just keep pushing the mode button until the "pm" notification shows up on the digital display in the upper left corner. Once you get that use the 1-4 keys to set the clock. Good luck.
Nov 07, 2010 | Sharper Image SI686 Clock Radio
Power switch no longer works nothing works except
Please contact the below for service.
Online: customerservice@sharperimageonline.com
Phone: 1-877-714-7444 8:00 AM - 8:00 PM EST Monday - Friday
Oct 30, 2009 | Sharper Image Travel Soother 20 Clock...
Product RS2767i help
you need to turn it on at any mode to charge your ipod,as it has no charge function at standby mode .
Mar 27, 2009 | RCA Audio Players & Recorders
Sharper Image S1785 Clock Settings
When setting-up the time (by pushing the "mode" button), the alarm time set comes up first, followed by the time set.
When setting the proper hour in this mode, simply continue through the military "24 hour" cycle and the second cycle of 24 hours will be in the 12 hour format.
Continue through and finish the mode set-up function and your up and running. --
Dec 12, 2008 | Sharper Image SI785 Clock Radio
Sharper Image Alarm Clock won't reset after changing battery
  • https://www.sharperimage.com/si/pdf/manuals/204050.pdf
Jan 06, 2018 | Audio Players & Recorders
12 hour vs 24 hour read on clock
Push the "mode" button twice to enter the time change function. Once the display is blinking keep pushing the mode button until you see the "pm" icon on the LCD display. When that happens set the clock as you normally would using the 1-4 keys.
Remember to check if the 12 hour clock is set to AM or PM.
Good luck.
Sep 09, 2008 | Sharper Image SI686 Clock Radio
231 people viewed this question
 Grubhead
Grubhead
