Question about HP D8597A Keyboard
Lazy finger causing keyboard to lock in all caps??
When I am typing something, somehow my keyboard will lock into all caps and I canNOT get rid of it unless I shut the computer down and start over again. I'm thinking I may be hitting the Fn key in the bottom left corner with something else and causing it, but cannot find help anywhere. HELP!!
  • 1 more comment
  • wasabiprince Dec 08, 2008
    No, I am not hitting Cap Locks. It's when my pinky finger goes down to the shift key, I think, to make one letter a cap. When it happens I've tried hitting cap locks, shift, FN, ctrl...everything down there to Undo it, but it doesn't work...any other suggestions?
  • Anonymous Feb 06, 2009
    I have exactly the same problem. I am not pressing Caps Lock either. Cant find help anywhere...
  • lpoliwog Apr 01, 2009
    other suggestions?
  • 4 Answers
Does it happen with everything you type or just in particular programs? If it happens in Microsoft word 2003 highlight the area where the all caps is happening then go to Format, Font. Under the Font tab there is a section called Effects, in this section there is an All caps option, uncheck it.
If it types all caps everywhere there could be a short in your keyboard. You can solve this by taking your keyboard apart using a multimeter to find the short and reconnecting with solder or electrical tape. Getting a new keyboard or talking to tech support can also help.
Posted on Jun 03, 2009
Are you running anything that catches the keyboard? Autohotkey? Synergy? I had the same problem. Restarting the program that locked the keyboard corrected it.
Posted on Oct 16, 2009
  • HP Master
  • 4,806 Answers
I think that you are pressing Caps Lock by accident, you don't need to press Fn to active this, if it does it again just press Caps Lock abd see what happends
kind regards and please don't forget to rate us
Posted on Dec 08, 2008
How do you get rid of the third light top right hand side of key board
depending on the keyboard it probably indicates caps lock or something like that. if not and you don't like it put some tape over it. Or I have used a black permanent marker to dim the light from an led that I find to bright. just an idea but don't do anything that would cause you to dislike the look of the keyboard.
Apr 01, 2017 | The Computers & Internet
My problem is with the keyboard. I seem to have locked the keys somehow. How do i get the keyboard to work properly again for lowe caser typing? I'm not sure what to press to do so. My acer laptop is acer...
Greetings,
Look for the Caps Lock key and press it once, try typing again.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 03, 2008 | Acer Computers & Internet
Sony Vaio keyboard repeating letters
Keyboards to wear out, but are not expensive to replace. Multiple key strikes and sticking can be caused by spilling "stuff" into the keyboard, even crumbs will do it.
Oct 29, 2015 | Sony VAIO Computers & Internet
How do I get the caps lock light to turn on and off?
Unlock the Caps on Computers The All-Caps or "Caps Lock" function causes all letters to appear as capital letters when typing into word processing documents, emails or other files. This is convenient when needing to type numerous capital letters or All-Caps phrases, as you do not have to hold down the "Shift" button with one finger as you type the words. When All-Caps is stuck and does not respond to the "Caps Lock" keyboard button, a simple procedure overrides and shuts down the function. Open a word processing program. Press the "Caps Lock" button located on the left side of the keyboard to turn Caps Lock off. Type inside the document. If lower case letters appear in the document, Caps are successfully unlocked. Proceed if the text is in All-Caps. Hold down "Shift" on the keyboard. Press the letter "P." A lower case "p" appears in the document. Release the "Shift" button. Type the phrase "rint" directly after the lower case "P." The word "pRINT" is now in the document, and the document cursor is after the phrase's "T." Press "Enter" on the keyboard. The cursor goes down one line and "pRINT" becomes "Print." The "Caps Lock" function is turned off. Restart the computer to save the setting.
Enable the Caps Lock Key The "Caps Lock" key is loved by some and disliked by others. The key turns all letters into capitals as you type. While this feature is useful in some situations, a more common occurrence is that the key is accidentally hit and all the text typed is capitalized. The person typing must then delete the capitalized type and rehit the key to turn off "Caps Lock." If the "Caps Lock" key needs to be enabled, it indicates that someone has disabled or remapped the key. If a user wanted to, the "Caps Lock" key can be disabled and enabled through the registry or remapped through the control panels. Updating the registry for the keyboard will enable the "Caps Lock" key. Open the Notepad program. Type the following: [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout] "Scancode Map"=- Select "Save As" from the "File" drop down menu. Navigate to the computer desktop as the save file location and choose "All Files" from the "Save as type:" drop-down menu at the bottom of the Save As window. Type "enable.reg" without quotes in the "File name:" field and click "Save." Minimize all open windows to view the desktop. Double-click on the "enable.reg" file. A box will pop up asking if you are sure you want to run the file. Select "Run" or "Yes" and then click "Yes" for the Registry Editor warning. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled. b> Manually Update the Registry b> Click the "Start" menu, type "regedit" without the quotes and press "Enter." In older versions of Windows, Click the "Start" menu, select "Run," type "regedit" without the quotes and press "Enter." This will launch the Registry Editor. Navigate to "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Keyboard Layout" to view the settings. Right click on the "Scancode Map" setting and choose "Delete." Click "Yes" to confirm the deletion. Reboot the computer. The registry will be updated and the "Caps Lock" key will be enabled.
b> b> b> Disable the Caps Lock Key in Windows Your computer's Caps Lock key has likely only collected dust since you first brought the machine home. The Caps Lock key is beneficial if you want to type a long string of words entirely in capital letters, but this form of typing is not needed often. Consider disabling your Caps Lock key if you do not need it, or if you are tired of hitting the key accidentally while rapidly typing.
Restart your computer before beginning the process of disabling your Caps Lock key. Download the registry file necessary to disable your Caps Lock key. You have the option to disable your Caps Lock key or change the key to a number of different keystrokes. For example, you may choose to use the "ChangeCapsToShift" registry file if you want the Caps Lock button to function as a shift key. Double-click the registry file you have downloaded. A prompt will appear on your screen asking if you would like to add the registry file to your computer's registry. Select "Yes" to install the registry file. Restart your computer, once again, to complete the registry change. Upon reboot, your Caps Lock key will no longer function as a traditional Caps Lock key.
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key.
Feb 04, 2013 | ASUS R503u-rh21
CAP LIGHT DOES NOT COME ON
Disable the Caps Lock Key on a Computer The Caps Lock is an easy key to hit by accident, and often the user does not realize it immediately. When this mistake occurs, usually you must correct some text errors and your time is wasted. If you think the Caps Lock key is more of an aggravation than it is good, follow these steps to disable your Caps Lock key. Click on "Start" and select "Run". Type "regedit" into the textbox and hit "OK". This command will open the "Registry Editor" window. Select "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control". Double click on "Keyboard Layout" to open the folder. Open the "Edit" menu and choose "New" then "Binary Value". A new file will appear on the right side of your screen with the file name highlighted. Type "Scancode Map" for the new file name. Double click to open and type in "00000000 00000000 0200000000 003A00 00000000" into the Value data box. Hit the "OK" button. Close the "Registry Editor" by selecting "Exit" from the "File" menu. Restart your computer for the change to go into effect and enjoy life without the Caps Lock Key. Hope this helps
Jan 21, 2013 | Acer Computers & Internet
How to tell if caps lock is on
Some keyboards will have a light that goes on when caps lock is turned on
Type the following:
"Scancode Map"=-
Hope this helps
Nov 05, 2012 | Computers & Internet
How do you know if the CAPS LOCK button has been activated: do not see any indicator ?
I have the same keyboard and it does not have a caps lock lamp.
The only way of knowing if the caps lock is on is to type something in a text window although some websites will tell you if your caps lock is on as this can cause errors when entering passwords etc.
Jan 14, 2011 | Logitech Cordless Desktop MX3200 Laser...
I have a fairly new computer, bought in August. On the keyboard are red symbols which i inadvertantly press something that activates them and then I can't get rid of them. ie I want to use the at symbol...
you should have configured your keyboard at your first install,ie:correct location and keyboard type.if you havent done this re-install your soft and configure correctly--good luck!
Davey Snake!
(make sure your "Cap's "lock isnt on!)
Oct 25, 2010 | Toshiba Computers & Internet
Keyboard locks into all CAPS
Just a thought...one time I had a button that kept stiking itself with out me touching it...I removed the keys aroud it, only to find a tooth pick had found its way into my keyboard. Everytime I would hit any of the keys around it, it would also hit that button too. Dont know if this is your problem but worth a look!!
Sep 18, 2009 | HP D8597A Keyboard
Status light on upper right illuminated - how to turn it off?
Initially, have you checked/pressed on the "Scroll Lock" key (between Print Screen & Pause). To my knowledge, on most keyboards, the three common indicator lights are: Num Lock, Caps Lock and Scroll Lock.
Hope that this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 13, 2008 | Ingram BTC-5199 Keyboard
HP D8597A Keyboard Logo
943 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
