Question about Canon imagePROGRAF W8200 InkJet Printer
Error E02E02 I have a Canon W7200 and keep getting this erro code "E02E02". I can't find any info. Please help. Thanks
E02E02
Roll media set sensor error
<Cause>
This is displayed when the roll media set sensor could not detect positional changes by the paper guide during the paper guide opening and closing operations.
<Probable problem locations>
Roll media set sensor, roll media tray unit, roll drive unit, motor driver PCB, engine controller, system controller
<Remedy>
1.Visual check
Remove any foreign objects adhering to the roll media set sensor.
2.Roll media set sensor
Check operation using SERVICE MODE>I/O DISPLAY, and replace if anything does not function normally.
3.Cable connection check
Replace the cable between the roll media set sensor and engine controller if the connection is not functioning normally.
4.Roll media tray unit
Replace the unit if a visual check reveals that the gears are damaged, deformed, or otherwise do not function normally.
Replace the unit if an operation check reveals that the roll release lever does not function normally.
5.Roll drive unit
6.Cable connection check
Replace the cable between the roll drive unit and motor driver PCB if the connection is not functioning normally.
7.Replace the motor driver PCB.
8.Cable connection check
Replace the cable between the motor driver PCB and engine controller if the connection is not functioning normally.
9.Replace the engine controller.
10. Replace the system controller.
Posted on Mar 19, 2009
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
I'm needind drivesr for download: Canon imagePROGRAF W7200, on WIN 7/ 64bits, please help me!!
You can download the Canon printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Aug 18, 2011 | Canon imagePROGRAF W7200 InkJet Printer
Please how to enter service mode in Canon W7200
press and hold paper source an donline key and turn on the printer while holding the mentioned keys until th einitializing process is over an d you see canon .. on the display then release the keys, by pressing the online key again once or twice you will get in Service mode.
Jan 16, 2010 | Canon imagePROGRAF W7200 InkJet Printer
Canon w7200 service manual
You can download service manual for CANON W7200/W7250 from;
http://dl.owneriq.net/f/fb283499-7d17-4044-bf68-b415e6ed0073.pdf
Regards;
Hassan
Sep 03, 2009 | Canon imagePROGRAF W7200 InkJet Printer
W7200
Take it out and clean all contacts, worth a try as they cost £500 from canon. An engineer told me they usually only last about a year and after problems with the cutter failing and colour problems in drawings we got a new one which fixed the problems. Third new printhead in 4 years, canon should be ashamed.
Oct 07, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Canon W7200 Error code E02D05
The Service Manual says:
E02D05 Airflow fan error
Fan rotation could not be detected while the air flowfan as running.
Air flow fan, engine controller, system controller
Remedy
1. Cable connection check (check - replace
2. Replace air flow fan
3. Replace engine controller
4. Replace system controller
I wish success
AToe
May 05, 2008 | Canon imagePROGRAF W7200 InkJet Printer
Erroe 5100
Hi You can Try
Error Code 5100 it needs to be cleaned
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All The Best: Pineworks
Mar 21, 2008 | Canon SELPHY DS810 InkJet Photo Printer
Canon imagePROGRAF W8200 InkJet Printer Logo
529 people viewed this question
old marine
old marine
