Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
D52w20b wont turn on
When it does come on its has a great picture is it the flyback trans ?
    Genius:
  • 1,139 Answers
I posted this earlier, but I believe it applies here to:
Hello This is a common problem with the ITC222 chassis, I would check CP120, CP140, CP150 to see if they are bad I suspect CP150 is the one that is bad. Its value is 2200uf 16VDC. It is located on the same board as the IHVT and is in between the Heat sink in the middle of the board.
I hope this helps,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Dec 08, 2008
Show picture of flyback transformer and out put transistor
Heres a picture of the flyback. The trans HOT is located just ahead and to the right of the flyback its attached to an aluminum heat sink,slinteriors_16.jpgslinteriors_17.jpg
Jul 24, 2011 | RCA P61960 61" Rear Projection Television
My Hitachi 50SBX70B wont stay on
i think you may have a bad flyback. i have an hitachi that did that and ha to change mine out.
Dec 28, 2008 | Toshiba 55H70 55" Rear Projection...
My tv will not turn on RCA45 inch tv model D52W20B
The flyback is going out and the CP150 capacitor is almost certainly failing as well. You can get the replacement Flyback number 259296 and the CP150 Capacitor at the following link and they provide step by step instructions with pictures so you can easially do the repair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Nov 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
D52w20b rca tv no power blinks 3 times
I have the same problem, if you hear of anything let me know, or post it. AW
Oct 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 INCH D52W20B WON'T COME ON
A 1995 60 inch rca good picture and sound. Then it started a cracking noise and a hissing sound, then the picture went blurry. then it was nice picture and sound, then it died. took the back off and turned out the lights. Plugged the tv in and out from the wall socket and there was a sparking noise and a small arc when i plugged it in and out a few times ,at the part that the power plug plugs into.The white part that is beside the white power plug part has thick red wire coming out of it and goes into another plug that has more red wires in it. but the big white part beside the power plug part looks burnt and has black powder on it. that part is probably the problem but maybe not, what it the name of that part and how much would it cost and is it plugged in or soldered.
Oct 18, 2008 | RCA P52937 52" Rear Projection Television
RCA Model D52W20B Serial # F074C312B Chasis ITC222 Set does not turn on the power light comes on then flashes and goes off. I need the part number in order to fix the problem
if the light flashes three times then goes out you need flyback 259296 if the light only comes on once then goes out you need the deflecion board. You can get any part you need at the following link and if your not sure leave them a email with the model number and symptom they respond quickly.
Sep 25, 2008 | Televison & Video
Flyback 259296
When you remove the rear panel look to the left side of the chassis and you will see the Flyback with the two wires coming out of the top one is a large thick red wire the other is a small wire. You can get a new replacement at the following link under 50.00 which includes free shipping and free support to help you install it by on line instant message with a repair tech.
Jun 18, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W20B Vert/ Hor Hold Problem
Nothing inside to adjust. try re-soldering the vertical output IC and also the flyback connections RCA has had some issues with the flyback solder connections
Feb 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Diagonal lines and ghost images
You may have a bad flyback transformer (high voltage trans former). The lines you're seeing are retrace lines caused by the picture tube screen set too high. This is often caused by the screen control opening up. This control is part of the flyback.
Stargazer
Dec 02, 2007 | Proscan PS32500 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
