Seems to originate from Shock mounts at bottom
Could be ball joints or lower control arm bushings.
You can try soaking the bushings with wd40 and see if the squeak goes away temporarily.
Testimonial: "WD40 did help with Sueaking"
It is the lower ball joints. To find out punch a small hole in the rubber booth and take a can of penetrating oil with the spigot on it and put the spigot through the hole ... lube it very well.... let it spray inside the rubber booth very well. If that stops the squeak than take a grease gun needle and put all the grease you can inside the rubber booth. Dry the rubber booth where the hold is and seal it with clear finger nail polish.
I have had to replace balljoints and outer tyerod 2 times in the three years I have had my Dakota and when they are bad they squeak badly
SOURCE: 2003 Dodge Dakota front end makes click noise only when in a turn
check that the caliper slides are free and that you refiited the anti squel plates on the back of the new pads
SOURCE: 2001 Dodge Dakota loose steering
Hello
Welcome to FixYa
there is a u joint to be replaced on your steering shaft just after the steering shaft
open the hood look down to the steering shaft you will see a small u joint very common to go bad most auto parts stores carry the part
RD
SOURCE: Noise in front wheels of 97 dodge dakota
This sounds like a bad hub bearing .It will come as a unit. bearing and hub together .most likely the left side!
