Question about Video Cameras
Hitachi dx-gx5020a dvd will not reject
I have tried everything the manual says and no results.
  • 1 more comment
  • 9542 Dec 14, 2008
    Hitachi dx-gx5020a dvd will not reject . I have tried everything the manueal says and no luch. It won't turn off unless I take out the battery.
  • 9542 Dec 21, 2008
    I have had one response and it was of no help. I am not satisfied.
  • 9542 Dec 21, 2008
    How do you open it manually without breaking it?
    Scholar:
  • 145 Answers
I have seen all the comments made in reply to your problem. I also think there is a mechanical failure. Check if there is a small hole beneath the DVD tray. Take a office clip and straighten it. insert it gently inside the hole and gently push it.the disc should eject. While doing this procedure make sure your device is OFF and power supply removed.
But before that I want to ask that by any chance have you put a broken disc inside the device or did the device got a shock by any means(hitting/Dropping etc.) Mechanical problem is there for sure and if you are not qualified enough than an end user, I would very strongly recommended that you take it to the service center to avoid any more damage to the DELICATE device. May be the shop from where you bought can be also useful.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 21, 2008
  • 10,594 Answers
Its not do it yourself case, a lot mess can be end result.
DVD cameras are complicated and bit sensitive in handling.
I would recommend to take camera to repair shop for proper fix.
  • 275 Answers
Hi 9542, I had the same problem with mine , turns out that the gear that ejects the dvd gets stuck and moves out of place sometimes, what i did is I had it replaced by warranty, but if you dont have warranty you might want to go in there and manually put the gear back in place and that will defenetly fix your issue.
Posted on Dec 14, 2008
    President:
  • 2,110 Answers
Did you eject the disc when you had it plugged into the wall and not running on the battery source? If you did, take out the battery and plug it back in. Hopefully that will work.
    Genius:
  • 1,239 Answers
Hi
The door might be stuck. Try "helping" it open manually after pressing the eject button. Otherwise, something is probably broken and you might have to call a repairman.
Posted on Dec 08, 2008
    Sergeant:
    Champion:
  • 435 Answers
Hi, I assume you meant eject.
My be the eject door is stuck.
Try ejecting manually while pressing eject button.
If it doesnt work, may be something is broken inside.
    Sergeant:
  • 399 Answers
Try to tap on the dvd top and front side.if something is blocking it will eject.also shut off the device and then press the eject button and then on the device.press the eject button several times and try.if nothing helps u will have to open the device and check out for any blockage in gear assembly which moves the eject door.it is not very hard to open the device.just open the screws.
    Genius:
  • 1,550 Answers
Then you need to manually open the camcorder to take out the dvd .
The dvd is stuck inside due to mechanical failure .
The button is stuck from inside .
    Sergeant:
    Champion:
  • 304 Answers
try to remove the battery for a while.
put it back again the battery, while pushing/pressing the eject button.
let me know how things came up,
good luck
  • Elizabeth Krijt
    Elizabeth Krijt Dec 14, 2008
    posting back again:::
    hi there,
    good luck
I have the DZ-GX5020A DVD Cam....the disc eject door will not open.....I can hear it clicking trying to open, but no luck... everthing else works fine.......can you help me?
None of those options worked for me. I had to remove the single screw on top of the camera. Then slide the silver top panel forward to remove it. Then remove the dark panel where the screw was removed. Then you should see a small metal piece very close to the DVD door opening that is holding it closed. Slowly nudge it forward to unlatch the door. This allowed me to open the door to remove the DVD. Unfortunately I still have to do this every time to get the door open. I may try some lubricant on the metal to prevent sticking.
Jul 02, 2010 | Hitachi DZ-HS300A DVD Camcorder
Missing DC Power Cord for Hitachi DZ-GX5020A - where to buy?
YOU CAN GO TO PartsStore.com and get one for under $15
Jan 09, 2009 | Hitachi DZ-GX3100A DVD Camcorder
I have a hitachi dz=gx5020a and cannot eject the dvd
pull the battery
then turn unit on wait until all lights have stopped blinking and you feel no movment inside unit ....now try to open ...hold down eject
NOTE ALWAYS WAIT UNTIL ALL MOVMENT AND LIGHTS HAVE STOPPED .
YOU CAN CAUSE DISK ERRORS NEVER TRY TO OPEN WITH LIGHTS ON
GOOD LUCK
PS I NEED THE SOFTWARE TO DOWNLOAD INTO COMP. DONT KNOW WHAT I DID WITH DISK?
THANKS
Dec 08, 2008 | Video Cameras
Installation cd for my cam
Looks like Hitachi doesn't have any software available on line to do it. You will have to contact them to get one.
You can use abobe software for free to try to get them or goto Kodak.com and use their free software as well.
If it doesn't see your camera as a disk drive in my computer, you can get a card reader to retrieve the pictures that way.
Heres the owners manual if you need one:
http://merchant.satisfusion.com/sf/library/manuals/owners/DZGX5000A_5020A_5080A.pdf
Jun 22, 2008 | Hitachi DZ-GX20A DVD Camcorder
How do i play my dvd on a vista platform
I have the gx5020a camera, and found out that the VRO file is just MPEG2. So copy the VRO file onto your computer from your disc. Once its on your harddrive, you can right click on it and go to properties. Re-name your file from VRO to MPG, making sure that you still have the original VRO file in case you need it for other programs. Once I change it to MPG file name, I can use media player to play it and I have a DVD movie maker where i can edit and record to DVD.
Dec 27, 2007 | Hitachi DZ-MV350A DVD Camcorder
Codecs anyone?
I have the same camera, and found out that the VRO file is just MPEG2. So copy the VRO file onto your computer from your disc. Once its on your harddrive, you can right click on it and go to properties. Re-name your file from VRO to MPG, making sure that you still have the original VRO file in case you need it for other programs. Once I change it to MPG file name, I can use media player to play it and I have a DVD movie maker where i can edit and record to DVD.
Sep 11, 2007 | Hitachi DZ-GX20A DVD Camcorder
Hitachi DVD camcorder
Apr 09, 2006 | Hitachi DZ-MV580A DVD Camcorder
Video Cameras Logo
29 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
