Question about Samsung HP-R5072 50 in. Plasma HDTV
Black piture in the middle 1 sq foot 2inces lower
My plasma is tiny ph-50d8 i was tall the pc board is not working the pc no is 667phsd8-01 samsung same part is used in pilado pla-504 main digital processing board
  • 4 more comments
  • anil_shah70 Dec 08, 2008
    the part nos are for new pc board
    i have unpluged inside and tryed turning on same problum
    i have no menual for this tv
  • anil_shah70 Dec 09, 2008
    my plasma is 50 and have i have a black screen in the middle top
    i have polaroid 5040 50in plasma tv my tv work perfectly but in the middle top 2ins lower i have 1footsq black screen in which i can see a negative picture
  • anil_shah70 Dec 10, 2008
    my plasma is same as polaroid 5040 50in i have full picture but i have a black 1 foot sq picture in the middle in which i can see negative picture
  • 2,326 Answers
Click here to find more info and the service manual for your TV, click on the first pdf file and once downloaded go to page # 30 to find additional info on where the failure could be.
Good Luck.
Posted on Dec 10, 2008
  • 505 Answers
You could possibly fix by just reseating (unplug, replug) the cables that go to that section of the tv. There will be ribbon cables hooked to the board across the top of the tv, the area of the distortion will be the same area as the board. If there are no boards at the top, then they are all at the bottom. Reseat the ribbon cables to the x board that controls that part of the screen. If this does not fix, you need a new control (logic) board or a new middle X drive board. With your symptom, you could have a burnt up COF (chip on film) IC.. the chip is inside the ribbon cable. If you see a pin sized black hole in the IC, then it is bad. Unfortunately these ICs are part of the plasma panel.
    Genius:
  • 2,920 Answers
Why not simplify it and send it to a shop and have them repair it right the first time it seems harder to try to figure out what they can figure out in about an hour.
Posted on Dec 08, 2008
    Genius:
  • 1,239 Answers
HI possible ysus pc board assy.
  • 148 Answers
First you have to check if the PLasma Power Supply is ok...check with a multimeter...
Take a Look in the LCD Logical Board and see if you can find any blow capacitors....
Check all the Smd´s Fusistors...
You need to find your Samsung HP-R5072 Service manual...try to find it in google...
Good Luck!
  • Samsung Master
  • 19,396 Answers
Look like a caption settings problem, check on the user manual how to reset caption.
  • 734 Answers
please discribe a more ........
Thanks
  • futureloginn
    futureloginn Dec 10, 2008
    follow the link -----
    http://www.retrevo.com/samples/TV-manual...
    Thanks
  • Samsung Master
  • 4,806 Answers
Now you have replaced the board the TV settings have to be reset again, try this:
1 Press the MENU button. Press the ▲ or ▼ button to select
“Picture”, then press the ENTER button.
2 Press the ENTER button again to select “Mode”.
3 Press the ENTER button.
Press the ▲ or ▼ button to select the desired picture
mode (Dynamic, Standard, Movie, Custom), then press
the ENTER button.
4 Press the MENU button to exit.
• Choose Dynamic for viewing the TV during the day or when there is bright light in the room.
• Choose Standard for the standard factory settings.
• Choose Movie when viewing the movie.
• Choose Custom if you want to adjust the settings according to personal preference
Hope this helps
kind regards
  • 1 more comment
  • Lee Hodgson
    Lee Hodgson Dec 08, 2008
    Ok, try to reset the picture:
    Resetting the Picture Settings to the Factory Defaults
    To return the factory defaults, select “Reset” by pressing
    the ▲ or ▼ button.
    The previously adjusted settings will be reset to the
    factory defaults.
    kind regards
  • Lee Hodgson
    go here for the manual:
    http://www.retrevo.com/search/v2/jsp/myt...
    if it won't let you download it post back please
    regards
  • Lee Hodgson
    regards
    Sergeant:
    Champion:
  • 435 Answers
Hi, I am sorry. I think there are typos. Do you mean you installed some pc board ? or are you telling us what are the part numbers. Please clarify.
Thanks,
    Genius:
  • 1,550 Answers
Try hard reset .
Unplug your tv from power chord for 30 minutes and plug back the power chord to the tv .
This will reset your tv .
If this doesnot work check the connection from the circuit board for any loose connection .
    Sergeant:
  • 399 Answers
Try unplugging the machine fron the power outlet for sometime.then connect it properly and try out.as it is the prtoblem of the board it is either to be replaced or repaired.
Samsung plasma pn60f5300bf black screen third of the screen
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 18, 2017 | Samsung Televison & Video
4 ft x 4 ft x 5 inches = square foot?
when I went to school a board foot a board 1 foot wide and 1 foot long 1 inch thick, a 1X6 2 foot long a 1X4 3 foot long etc. a 4X4X3 inches would be considered a board foot but with new math and metric system, I'll leave the exact formula to the calculators and smart phones (I don't own one) 20 square feet would be my answer,
Apr 16, 2017 | Office Equipment & Supplies
I have vertical black lines in my Samsung s42ax-yb09 plasma TV. one 3 inch band down the right side and a 9 inch band down the middle a foot from the right of the screen and 15.5 inches from the left
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 29, 2016 | Samsung Televison & Video
Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
Jul 18, 2011 | Samsung 50 in. Plasma TV
We have lost a two inch wide black section on the right side of the plasma panel, any ideas
Most likely the lower buffer board " E " needs to be replaced. Right now I'm working on repairing a 42" Samsung plasma HP-R4272. The Service manual for that TV says for trouble shooting for that problem is the lower buffer board " E ".
Best to find the correct Service Manual for your TV over the internet to get the correct part number for replacement. The Service Manual should be less than $20.
Oct 25, 2009 | Samsung PS42P2S 42 in. Plasma Television
I have a black vertical line in the middle of my
There are two boards at the bottom of the set connected to the panel. Follow the black line to the boards(it will be inline with one or the other) either that board is bad or the panel itself is bad . The boards do not meet exactly in the middle.
Oct 21, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Digistar PH-4210D Black Screen
Plasma tvs do not have "back lights" LCDs do. you probably have a bad driver board along with the upper or lower buffer board or maybe both, best to have a tv shop look at it.
Aug 30, 2009 | Televison & Video
Samsung plasma tv hp-r4262
The x drive board is bad in the area you see as black. OR the cable came loose.
Jul 03, 2008 | Samsung PS42S5H 42 in. HD-Ready Plasma...
Samsung HP-R5052 50 bottom hallf screen turns black
its the lower buffer card.. (y buffer lower board) they cost about $90.. i changed mine myself on my samsung hpr-4262 42 inch plasma.. pretty easy,, took approz 20 minutes.. the card has 3 ribbon cables and 3 other connectors and 1 screw.. removing all the screws out of the back pannel took the most time.. i found the repair manual for my tv on line for $13 (download PDF file) the manual had a trouble shooting section and what board to replace for each problem.. got the manual from here http://store.payloadz.com/ ordered the replacement board from www.partstore.com
good luck
troy
Jun 24, 2008 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung HP-R5072 50 in. Plasma HDTV Logo
29 people viewed this question
Henry  Thomas
Henry Thomas
