Question about GE Profile JK915 Electric Single Oven
F3 code hi, my ge profile oven keeps giving me f3 and beeping. this happens when i put broiler on and ten minutes later broiler shuts off and oven beeps with f3 on display. if anyone can help me fix it i would be grateful. thanks
  • 1 more comment
  • mcarson Feb 16, 2009
    Our GE Profile JT915 acts similarly. If we set the oven to 350 and expect it to cook for over 20 minutes it won't. I'm not sure of the exact error displayed but it basically shuts off beeps for a while and then won't be able to be used for about 30 minutes. I thought it might be a dirty filter from the fan or something making it overheat. Could this be the temp sensor also. Have never been able to get the clean to work. Has always shut off after 10 minutes.
  • Anonymous Mar 15, 2014
    oven shuts off and shows on display E4-F3
    whirlpooloven.oven shuts off and E4-F3 shows on display
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Posted on Mar 12, 2007
  • Nancy Davis
    Nancy Davis Nov 26, 2014
    This answer was the right one I was ready to order a new oven Replaced the sensior and it works just fine thank you so much for your input
My frigerdaire oven heats for a while about 15-30 minutes then shuts down with a beeping noise and a f3 code.
Good Afternoon Friend,
I see that your Frigidaire double oven heats up for about 15-30 minutes, then shuts down and begins beeping while showing an F3error code. The F3 states that the oven is sensing a potential runaway temperature. This is possibly a sensor issue or it could be a false error code.
I suggest giving your double oven a hard reset by cutting the power at the circuit breaker for at least 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Let the oven heat up, and if you are still receiving an F3 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Jan 27, 2012 | Frigidaire 30 in. Electric Gallery Series...
F2 and F3 messages - shuts itself off. Any idea of what it is and how to fix it?
Hi
F2/F3 error message relates to the oven temperature sensor or thermostat faults.
The fix is normally to replace it.
This link may help if you want to do it yourself
www.wonderhowto.com/how-to-replace-cooker-thermostat-oven-250012/
Hope you get it fixed.
Dec 16, 2010 | GE JKP15 Electric Single Oven
What is an F3 message on a GE Profile JKP18 oven ?
Hi jmjburns,
The F3 fault code description is an open or shorted oven temperature sensor. Please check the sensor harness and harness connection between oven sensor and oven control. If the wiring is ok and still encountering the same error, please replace the temperature sensor.
Hope it helps.
Thank you for using FixYa.
Nov 10, 2010 | GE Profile JKP18 Electric Single Oven
How to Fix Code F3 on GE Oven
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 03, 2010 | GE Ovens
My GE Profile oven is beeping every minute. I've
if its an f-7 error code its due to a stuck error code
Feb 06, 2010 | GE Profile JT955 Electric Double Oven
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
F7 error
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Good Luck!!
Have a nice Day!!
May 03, 2009 | GE Profile JTP18 Electric Single Oven
F2 and F3 code appearing along with annoying beeping
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
GE Profile Oven Model JKP13G0V1BB
f3 is a bad oven sensor, two screws will remove it in the upper left or right hand side of inner cavity.thin metal shaft protuding maybe 3inches or so.
Mar 23, 2008 | GE Profile JTP18 Electric Single Oven
GE Model JTP15 oven shows F3 error code
I have the same problem. I noticed that the oven gets to the selected temp ok. Then when the pilot attempts to RELIGHT, it gets the error F3. Did you get a solution? After other posts, I will see if the temp sensor is around 1100 ohm as suggested by others. Ken
Jun 14, 2007 | GE JTP15 Electric Single Oven
GE Profile JK915 Electric Single Oven Logo
448 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
