Question about Baby Gear
Britax boulevard harness installation
I have taken the covers off my 2 car seats to wash them...I cannot find exactly how to reinstall the shoulder harness into the back of the seat. Help!
Car seat. I took off the straps to wash them and can't figure out how to reinstall.
Scroll down this page, someone was kind enough to take pictures.
http://www.car-seat.org/showthread.php?t=21629
Posted on Feb 28, 2009
My husband just figured this out for me a minute ago.  If you look on the right side of the seat there is a diagram about using the latch, but it also shows the metal part that the straps hook into going through the black piece that is closest to the seat.  There is a black plastic piece that is kind of curved with a metal rod right above it & then closer to the back of the seat there is a black solid plastic piece right next to the seat back & this is what it goes through.  I know this post was a long time ago, but I ran onto it trying to get mine back together, so I thought it might help someone else. =)
Posted on Apr 25, 2009
How do you adjust the height over shoulders of harness on britax asis car seat
We would recommend you contact Britax to ask them or speak to your local nursery retailer for advice.
Apr 08, 2012 | Britax Baby Gear
Need to remove the cover from a britax eclipse si..how
Press and hold down the harness release button. With your other hand below the chest pads, pull the shoulder straps forward as far as possible. With the Eclipse Si fully reclined, open the seat-belt guard at the back of the shell. Pull the yoke out from behind the seat and unhook both shoulder straps. Pull the cover from the top of the seat so that you can see the slots in the seat shell. Pull each shoulder strap and chest pad strap forward and towards the centre of the shell, easing the metal tab and straps through the slot. Then thread them through to the front of the cover. Unfasten the buckle and remove the comfort pad. Gently pull the cover off the seat, easing the shoulder straps, chest pads, harness buckle and adjuster strap through the slots in the cover.
By Geraldine Thorne
Feb 24, 2011 | Britax Eclipse Si - Chantilly
Whe you adjust the tightness of the harness on my car seat, it no longer clicks a short length at time and is really hard to pull model # E9L74J2 Serial # E9L74J3001067
Have you removed the car seat from the car and made sure that none of the harness is caught up anywhere? I've had that happen before. I then completely extend the harness and then retract after to make sure all is smooth. If you can't see anything caught up, and you can't extend and retract freely I would make a phone call to Britax directly (888-427-4829) in case something is malfunctioning.
Feb 24, 2011 | Britax Boulevard
What is the best way to wash the cover on the britax boulevard? daughter vomited smoothie (red) on it
hi
here is the instruction book you answer is on page 20
http://www.britaxusa.com/uploads/cms/file/Boulevard-P363200-R1.pdf
Oct 19, 2010 | Britax Boulevard
Britax Boulevard-Is there a weight limit for latch system?
The weight limit for the UAS / Latch system is 48 Lbs. Read your owners manual for both the Car seat and your vehicle to be sure of all the regulations.
Jul 03, 2009 | Britax Boulevard
How do I put back together the straps on my car seat
would assume you're talking like a booster seat with the back just no 5pt harness. You just buckle them up like you do. If they have those arm rest looking things, the part where it buckels goes under that one arm rest and the shoulder strap should go resting over his shoulder like yours. Some of them have a loop up top for the shoulder strap to go through. Just make sure that the toddler does NOT put their arm over the shoulder part of the belt. If you get into an accident this could break his/her ribs.
Apr 20, 2009 | Britax Eclipse Si - Paris Convertible Car...
Lost my Instructions for a Britax Asis Car seat
First attach the long belts to the bottom of the chair. Then feed them through the seat cover and replace the cover. Feed the belts through the back of the chair (through the required shoulder height) and attach to the metal harness at the back of the chair. The folded over edge goes on first, so make sure you put the right belt on the right side! Finally, feed the padded shoulder straps through the same hole as the long belts at the to of the chair and that's it!
Any more problems, drop me a line
Apr 11, 2009 | Baby Gear
Harness on seat
I DID THE SAME THING. BUT DO NOT FEAR I FOUND A LINK YOU COULD USE. IT TAKES YOU TO THE WHOLE MANUAL. I HOPE THIS HELPED.
Dec 17, 2008 | Britax Eclipse Si - Paris Convertible Car...
Britax eclipse
Try Britax.co.uk, they have all the user guides and instructions available for free download. i had the same problem as i washed the seat covers and then couldn't remember how to put the harness back. Hope that Helps.
Jul 16, 2008 | Britax Eclipse Si - Paris Convertible Car...
How to take harness off britax evolva 123?
What a cool seat! We don't have that model in the US.
First , check out this site: http://www.britax.co.uk/index.php?Itemid=31&groupid=8&id=12&option=com_britax&task=showproduct
it shows how to remove the seat cover.
Next, from the back of the seat, there is a short, fat T shaped flat metal piece. Slide the shoulder belts off the piece. Those pieces can then be pulled from the front of the seat.
From the bottom, of the seat, pull the strap, then fold the strap, so the metal piece is perpendicular to the hold, , then push through.
Repeat on the other side and for the buckle in the center of the seat.
Do not place the harness/buckle in the laundry machine.
Jun 16, 2008 | Britax Evolva 123 - Barcelona
Baby Gear Logo
565 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
