Question about SanDisk Sansa m230 MP3 Player
Need help! my mp3 player will not put as much songs as usual i can only fot in 38 while usually i can fit 70 songs. also ill be scrolling song and the name for the last song will stay and the other song will and uf i let it be ill turn itself off why is that?
  • Anonymous Mar 27, 2008
    the volume wont change when i want it to get louder it will get quieter.whats up with that i have only droped it once and that was like 5 inches away from the ground.
Are you putting songs that are mostly mp3's instead of wma... mp3's take up more space
Posted on Mar 11, 2007
Are you using songs with the same bit rate as before? A song with a higher bit rate takes more space.
Posted on Feb 27, 2007
SOURCE:
How do i delete songs?
You can delete songs off your Eclipse MP3 player by connecting it to your computer. You can usually manage files on your MP3 player by opening up the file directory under My Computer > Device Name. Also, you can usually manage files with media player software like Windows Media Player.
Hope this helps!
Aug 01, 2015 | Eclipse Fit Clip 4GB* MP3 Player
I have a Craig mp4 player and when I try to sync music onto it some of the songs say " Did not fit on device" Why?? And what can I do to change it?
This is because the songs literally cannot fit onto your player. Songs, like all files, take up a certain amount of digital space. Craig MP4 players generally are small in space, usually ranging from 1-4GBs, which will not get you far if you have a lot of songs. The only real solutions for this without buying a new MP3/MP4 player is to be more selective with the songs you put onto it. There is not a way to change the amount of songs something can hold, so you just have to put less onto it. Also, If you put videos onto it, get rid of those first because videos take up way more space than songs.
If you want more space, I would recommend a 8GB or 16GB music player, those are satisfactory for most people with a lot of songs.
Also, for now you could try downgrading the audio quality, which will reduce the file size, effectively making more songs able to fit onto your player, but I would not recommend this because it does create a noticeably worse audio quality.
Apr 06, 2011 | Audio Players & Recorders
It wont play the downloading songs
The following may help:
- Ensure that your Music files are of the correct format (usually .MP3 or .WMA suffix and usually NOT .WAV which is the standard CD format). - Ensure that you upload your music .MP3 or .WMA files to the correct directory and names are not excessively long as some MP3 will limit the max name length. If you know a working song on your MP3, locate the directory it resides in and put your songs there. - Lastly, if you have put your song with the correct naming convention/suffix and you now see them in your player list but they will not play, then your MP3/WMA file has non-compatible 'property' whcih is usually the encoding 'bit rate' (usually anything under 128mbps fix rate is good but you can see what is acceptable by looking at the 'properties' of your working songs that are on your MP3 player)
Dec 19, 2009 | Element Electronics Zr-Element Digital...
Need to find ou thow to put music on an mp3 player
**Drag and Drop**
Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player.
--**Windows Media Player**--
If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 05, 2009 | Sony Audio Players & Recorders
My 120 GB I pod classic Doesn't play the next song
Hi. Check that when you plug your iPod in that it isn't selected to "Shuffle," play which can happen if you are expecting to go through songs. There is also another reason and one I didnt know about until I took my iPod Classic back to my retailer thinking there was a problem;
If the songs on your iTunes or default device isn't an AAC file the iPod will fail to play it. On MAC systems simply click the file that you want to put onto your iPod, right click and scroll to "Get Info." If the file doesn't say it is an AAC file it won't play on your iPod. Scroll further down on the list to "Create AAC version." This takes milliseconds, doesn't affect the sound quality but condenses the data fit for the iPod Classic. Once that's done you can add any song you like.
Generally when you put a CD into a MAC it will automatically change the AIFF files into AAC which means you don't need to manually convert. AAC is usually needed when individual tracks are called up and put onto your iPod. I hope this helps you - it drove me nuts until I found out about the AAC.
Apr 02, 2009 | Apple iPod classic MP3 Player
Cant put songs on opal
Yes. Forget media player and go to limewire.com. After you have downloaded their site type in the type of music or specific song and then dowload.Use songs that are high on the list and use ones that are marked mp3. after the song downloads you will see another area below with commands. Hit explore and it will open another file. Have your device plugged in and then hit copy this file scroll though and highlight your device first.It will usually say Mp3 or something like that. Oh yea before you hit explore you have to highlight the song. simply click on it at the lower area. Also limewire will always ask you to upgrade to PRO and unless you are really into it itis not nessessary. Have fun
Nov 07, 2008 | RCA OPAL M4001 MP3 Player
Can't select correct song
you need to format it and start all over again
Sep 28, 2008 | SanDisk Sansa e260 MP3 Player
80G Ipod Classic skips songs
Try converting the songs into a different format because the format that the song is in might not completely be played on the ipod. Right click on the song and click on convert to mp3. Then try transferring the mp3 format song onto the ipod and it should play right then.
Jun 24, 2008 | Apple iPod MA446LL/A MP3 Player
How do i put music on my mp3 player
if you already have songs in your computer connect your mp3 player it will say open folder answer yes, then click on the corner to lower or move your window drag your song from your computer folder to that window usually e or f. to drag the song you need to click and hold down your left mouse button on your song and move it to your e folder then release button. another way is by click right button on song then choose copy from the list then go to your mp3 folder e and right click then paste.
Aug 30, 2007 | RCA Lyra RD1072 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
55 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
