Question about Sylvania 6240VE VHS/S-VHS playback VCR
Vcr says that there is a tape inside of the vcr when there isn't
This vcr has a light sensor that is lite up and says that there is a tape inside the vcr. I know that there isn't a tape inside of the vcr. Does this vcr have a sensor that can sense when a tape is inside of the unit?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 242 Answers
Press eject.
Posted on Jul 15, 2010
    Problem Solver:
  • 13 Answers
Most VCR's do have a sensor system inside. It consists of what looks like a bar that is standing up right in the middle of the area the tape sits down into, and sensors on one or both sides of the tape bay that detect this source. The source is usually an infrared diode, and it is most likely this diode that has malfunctioned. I would checjk to see if anything has gotten inside that might be blocking this sensor, if not then the diode probably needs replaced.
Posted on May 11, 2009
Can not put in a vcr tape
The belt on the loader motor may be slipping or fell off the pulley. There may be something blocking the tape end sensor inside the machine the gears inside may be slipping on their shafts.
Oct 01, 2014 | Sony Rdr-vx535 Dvd Recorder & Vcr Combo...
My 19 inch tv/vcr combo has the Tape In indicator lite on, but no tape in it, and we cannot insert a new tape. Can you help?
I guess the easiest thing you can try , if you are handy with tools and a little knowledgeble with mechanical things is to replace the loading belt. Most of these problems are due to a loose belt(side of the cassette load mechanism) or inthe rear of the vcr mechanism(facing back cover)if this does not do it then i suggest geting it to a tv shop, might need timing align or end lamp replacement.
Sep 03, 2009 | Emerson EWC1902 19 in. TV/VCR Combo
Vcr player eats tapes and will not eject casset tape
It sounds like either the take up spool isn`t turning because the motor has failed or there`s something inside stopping the spool from turning or there may be something sticky around the skirt of the video head assembly. All I can suggest is remove the top casing and place a tape in the machine and watch what`s happening, Hopefully, you may find a child's toy or something similar under the cassette or the deck. Those labels that you place on tapes were notorious for coming off and finding it`s way into the mechanism. Ian
Mar 22, 2009 | Symphonic WV806 DVD Player/VCR
AIWA VCR model HV-MX1problem
with the unit unplugged take the case off and look on both sides of where the front of the tape would set, you will see two towers, one is a light and the other a receiver,check to see they are plugged in and not obstructed.Also there is a switch that the tape pushes when its all the way in which might be stuck,click it a couple times with your finger.This might help, there are other more complicated things which could cause this problem but mechanical problems are more likely.
Jan 15, 2009 | Aiwa HV-MX1 VHS VCR
Is the top and end sensor supposed to be off in servo check mode
If the tape is inside, both sensor should be OFF because both are photo diodes and will ON when receive Light.
Tape inside covers both sensors, so no light, no ON signal.
Nov 10, 2008 | Sony UVW-1800P VCR
VCR repeatedly tries to play and eject when tape deck is empty
the tape carriage is probably stuck, or something stuck inside blocking the tape sensor.
feed a tape in and see if it does it "with" the tape too
hope this helps
Jan 08, 2008 | Sylvania 6313CB 13 in. TV/VCR Combo
DMR-EZ47VK Up-Converting 1080p DVD-Recorder/VCR Combo
I think the problem with the tapes stopping is that there is too much tension on the tape. Try another VCR and try to see if you have the same problem playing the tape. Forward and reverse through the part that causes the player to stop. It is also possible that the tape inside the vcr has become twisted or stuck. One can fix this if they are very careful opening the video tape. However, I would not recommend this for most people
Mike
Dec 22, 2007 | Lite On LVW-5045 DVD Recorder
VCR
you have probably bent the tab that holds the tape end sensor or its light. The tapes have a clear section at the end of the tape and the light shines through to the sensor to tell the unit that the tape is finished. The light should not pass through the recordable part of the tapes. If anything is bent the light may shine on the sensor and tell the unit you're at the end of the tape and to shut off. Some units have a tape tension sensor also that tells the unit that the tape is broken and to shut off. Only way to know is to remove power and take it apart and look for anything that may be bent. Stay away from the rotating head assembly and the posts that the tap travels on. Do not apply power with the unit open. Do not load a tape and remove power as some units freeze in the loaded position and will not load new tapes unless manually placed back in the unloaded position.
Oct 17, 2007 | Emerson EWR20V4 DVD Recorder/VCR
Machine won't stay on
Hi I'm not familiar with your model, but what it sounds like is a bad "end sensor" on your machine. There are photo sensors on either side of the cassette basket which is what holds the tape in the machine. There is a light source that ends up inside the cassette when loaded, which shines both left and right. There is a section of clear tape inside the cassette at both the beginning and end of the tape. When the sensor on the left side sees light through the clear tape, the VCR knows you have reached the end and goes into rewind, when it sees light on the left side, it knows you have reached the beginning of the tape, and stops rewinding. This sensor is also used in some models to sense when you insert a tape in the basket. In that case, if the right side end sensor goes bad, the VCR always thinks you are trying to load a tape, so it doesn't want to give them up, and when you rewind, it never senses the beginning of the tape, so it will shut down when it reaches the beginning, and could even snap the tape. I'm 99% positive that is what is wrong with your VCR, it is an easy fix, but unfortunately, you won't likely find a repair shop that will sell you the proper sensor. I hope this helps in some way. Good Luck!
Jan 13, 2007 | JVC HR-A592U S-VHS VCR
VCR WILL NOT PLAY
The problem is the tape mechanism is malfuctioning. It trys eather to load or play a tape and a sensor inside tells the microprocessor to shut down this mechanism before damage is done to the tape. BUT sometimes a malfunction causes a damaged tape too. this unit has NO user serviseable parts inside itself, so its time to take this puppy into a repair shop to see if its worth the repair , Unless this units more then a few years old?? then its time to buy a shiny new unit. Good luck
Jul 09, 2006 | Emerson EWD2203 DVD Player/VCR
Sylvania 6240VE VHS/S-VHS playback VCR Logo
119 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
