Honeywell T87F Thermostat
Was having problems with heater shutting off without reason. Hoping the termostat was the fix, I took the outer cover off and saw a little calibration scale, I moved it back and forth and put it back where I thought it had started and then I heard the heater kick back on. I beleive it is fixed, but I was hoping to know what it is I did, or more so what that calibration scale is and how to use it correctly.
    New Friend:
  • 9 Answers
This calibration is called the heat anticipator, this is set by the amp draw pulled through the t-stat,if you look very close at the scale you will see the word longer with an arrow ,if you push the lever in the direction of the arrow the heat will run longer .This is a very old style t-stat and is most likely out of calibration on the temp reading for the room, think of this portion of the t-stat as a stand alone thermometer,it may read 70 when the room is 74
Posted on Jul 02, 2013
Therinnaiguy
  • 1420 Answers
SOURCE: boiler will not shut off
Boilers are controlled by a few things, one being a thermostat, secondly a zone valve or circulator control and thirdly by an Aquastat that controls the boiler temperature and safety shutoff. If one of those controls is sticking, your boiler will turn or remain on until it reached a temperature where the safety control shuts it off. If your boiler is not shutting off at all, most likely it is the Aquastat control. The Aquastat will be located on the boiler and may have "Honeywell" printed or stamped on it. Take off the front cover and you will find model numbers on the backside of the cover. If you have some mechanical skills, you could probably replace it. Turn off your power first and wire it wire per wire.
If your boiler is shutting off on high limit, I would suspect a stuck zone valve or circulator control or a bad thermostat or shorted thermostat wire.
Posted on Nov 15, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: Thermostat not working
Chances are that the fuse in the furnace blew. Remove the inspection cover on the furnace and look for a 3 amp fuse either in-line of the wiring or on the control board. Also check the circuit breaker box.
Posted on Nov 21, 2008
  • 27 Answers
SOURCE: Honeywell PRO TH4110d Prog Thermostat not responding
cfheck to make sur ethat the t-stat is set for your type of heat. if you do not go through the instructions sep by sep then you will have problems. if you have then call a professional.
Posted on Nov 26, 2008
Benimur
  • 6966 Answers
SOURCE: Dy/night heater turns on for 10 sec then and off, over and over
Hi and welcome to FixYa,
If I understand your concern, it is that the heater switches itself on for 10 seconds and then switches itself automatically off. A couple of ideas of you may want to explore/check:
  1. the built-in protection system detects an internal fault and to prevent any further damage switches itself off;
  2. the faults could be:
  • open heating element (assuming it is electrical);
  • blower not turning;
  • open limit switch. The limit switch is an inline cutoff to the heater that automatically opens up when the heater exceeds a pre-determined temperature independent of the settings in the thermostat. This is like a thermal fuse once gone bad will remain open;
  • whereas a thermostatic switch will turn on if temperature is below its threshold and turn off if the temperature is above. It is basically an on/off switch.
Often the limit switch would look like the image below.
To be able to provide a more detailed information/assistance, pls verify & post back the model number of the Day Night Heater. Model 8ou-19 does not turn up anything. Or perhaps you can share the website you were referring to.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 21, 2008
billyvangogh
  • 108 Answers
SOURCE: Replaced mercury thermostat w/Honeywell CT87K - doesn't work!
You need a specific thermostat for a Wall Furnace it is a Millivolt Thermostat and not a 24v standard thermostat....usually it will work anyway however if the powerpile (generator produces millivolts from the pilot light) is weak it may not be producing enough...or the Pilot light may be dirty and lazy...won't produce enough millivolts ...or you can have bad or dirty contacts or connections....or a combination of any of the above.....a 24v Thermostat and particularly a non-mercury thermostat has too much resistance in it for a millivolt system....as your Wall Furnace (other than the fan) runs on less than 1 volt
Posted on Oct 31, 2009
How to reset the thermostat to shut off after 2 degrees/CT87B-4008?
on these thermostats remove the outer ring cover and in the lower right side you will see a slide adjustment. move it i believe left for closer cycles and right for longer cycles. it should be 2* on either side of set point. remember that the fan is not furnace shut off.and turning back and forth will not tell you anything. just set it and see how it works then change it again if you need to
Oct 13, 2014 | Honeywell CT87B ROUND HEATING&COOLING...
Furnace does not shut off ... temp set at 68 degrees and its up to 80 degrees ... had to shut furnace by main switch ... is it the termostat
Easiest way to find out is to disconnect the thermostat or at least the red wire on the thermostat. If it stops, it's the thermostat. If it continues, you will need to disconnect the wire going to the R terminal on the control board. If it stops, it's a crossed thermostat wire. If it continues, its a problem with the control board or relay and you will need a technician.
Mar 09, 2010 | Honeywell CT3200 5-2 Day Electronic...
The heater is not keeping the temperature
OK maybe it's not the thermostat. Without a make and model number of your heating system we will be shooting in the dark. If you have a furnace or air handler, check the air filter. Get in front of the heating system and give us details as how it is running, noises, temperature of components, etc... We can isolate the thermostat by jumping the wires going to R and W on the thermostat. If the system chugs away we know that the heating system is fine (with the exception of the air filter) and is not the problem. If it still has a problem getting to temp, then it is a heating system issue. Get back to us with info. Thanks.
Dec 29, 2009 | Honeywell Programmable Thermostat Heater
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
Honeywell manual thermostat t87F, how to take off dial
ring around clear number section pulls off then there are three small flat head screws undo those aand the outer face with the dial comes off. if you are just trying to clean out the clear dial from bugs or small debris simply lift with small screwdriver and blow into it.
Nov 22, 2008 | Honeywell Heating & Cooling
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
AC fan not blowing/ Honeywell T87F thermastat
ok heres a test i want you to do carefully remove the thermostat cover and you will see the 3 wires one is red the other one is yellow and a green one turn off the thermostat and remove the wire from thermostat labeled G and carefully touch it on the R terminal if fan turns on, thermostat is defective if it dosen't turn on there should be a fan section on control board that's defective
Jun 26, 2008 | Weather King 10AJA2501AH Air Conditioner
My Honeywell T87F Thermostat doesn't shut the A/C off when the temp in the room gets down to the Thermostat setting. I have it set on COOL and AUTO. I have to shut the A/C off; then later turn it back on...
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Jun 09, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
178 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
