Question about Toshiba 62HM95 62" HDTV
Picture seems to be alot darker than before. toshiba 62hm95
Tv was working fine, than one day i turned it on and the picture just seems to be darker than before. Called a tv repair shop and they say that it might be the lamp going in the tv. Thats fine but the tv is only one year old and i can't see the lamp needing to be replaced yet. If the lamp was broken i shouldn't be getting a picture at all you would think? I'm not to sure though. If anybody could help me it would be appreciated.
    President:
  • 1,284 Answers
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Posted on Feb 23, 2007
SOURCE:
Toshiba 62hm95 has black vertical lines in the picture
Could be the optical light engine but some real tests requiring test equipment and a full service manual would be needed.
Dec 12, 2012 | Televison & Video
Why does the television power off by itself when color is fading in and out
Not real likely it is the lamp unless the picture is dark and has been getting darker.
I doubt it is the lamp.
Mar 16, 2012 | Toshiba 62HM95 62" DLP HDTV
My Toshiba 62HM95 DLP TV does not work with my PS3 via HDMI or Component cables. Is the TV not compatible or is something wrong?
hello, unplug all the cables from you ps3, turn the power off on the ps3 then turn it on press and hold the standby button on the front of the ps3 you will hear 1 bleep then 2 short bleeps after the short bleep relase the button, also turn your tv off then on again, when your ps3 comes back on plug the hdmi cable into your ps3 and then into your tv hdmi 1 on the tv go into the menu find hdmi click on this you should get a picture and sound hope it works
regards
shaun
Nov 22, 2010 | Toshiba 62HM95 62" HDTV
Tv turns off green light flashes twice and no
It trys to start but no picture? That means it's time to replace the lamp.
Apr 30, 2010 | Toshiba 62HM95 62" HDTV
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Zenith z44sz80 Dark picture
i have same problem. i replaced lamp but picture is still dark.
Aug 22, 2008 | Toshiba 46H83 46" Rear Projection...
Toshiba 32 inch 8year old tv set
Probably a bad connection on the tube base but your CF32H50 model dates from 1998!
Jan 28, 2018 | Toshiba CF32G40 32" TV
Toshiba 62HM95 has sound, but picture turns off after a few seconds
Did you change the light engine? If not they are very easy to do, you can do it yourself.
Feb 12, 2008 | Toshiba 62HM95 62" HDTV
No picture
Hello pravinp,
Since this is a DLP set, The bulb becomes suspect. I would take the bulb out and measure the voltage in the socket from which the bulb was taken to determine if the socket is hot. If it is I would then take a resistance reading of the bulb, the resistance should be at 0 ohms. If your bulb is blown replace it with the exact type. The TV might be shutting down to prevent further damage from occurring
I hope this helps
Shuttle83
Dec 21, 2007 | Toshiba 62HM95 62" HDTV
Toshiba 62HM95 62" HDTV Logo
322 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
