Question about Sanyo DP42746 42 in. Plasma Television
Problem with hd reception
Can not get tv to bring in hd reception
  • 71 Answers
What have u hookedup.
Posted on Mar 05, 2009
How do I bring in all available channels
You did not mention make or model, but you have to find: MENU, TUNER, choose ANTENNA, SEARCH ALL CHANNELS.
Dec 06, 2014 | Televison & Video
I have a freeview build into my tv which is Panasonic plasms tv Model no. TH-46PZ8BA and wish to know how I can receive HD channels BBC or ITV. Please advice and help.
HD Ready just means the tv can display HD images from an HD source.
The built-in Freeview box on your tv is not Freeview HD compatible so you'll either have to buy a separate external Freeview HD box or subscribe to an HD satellite or cable service.
In any case, most built in Freeview receivers are of barely adequate picture and reception quality. An external box is usually far better in both respects.
May 29, 2010 | Televison & Video
Aquos LCD tv no pic or sound on HD tv
The tuner is one board but I wouldn't suggest anyone but a qualified technician to replace it.
Oct 17, 2009 | Televison & Video
No digital reception with HD ready TV.
Someone did not explain to you what HDTV "Ready" means. It means you do not have a ATSC tuner in it to except over the air digital signal. The only way you will get digital reception is either from a HD Cable box with RGB outputs that plug into your RGB inputs, or being on Satellite connecting the same way. Seven years ago manufacturers never made it easy to understand and Salesmen only made it worse. So in short the term HDTV Ready meant it can, with a BOX.
Jun 13, 2009 | Samsung HCJ552W 55" Rear Projection...
Power off presents magic focus screen, tv must be unplugged.
you will have to determine if tv fault or cable fault, shut down cable box and unplug it`s power cable. Once all power is removed from cable co. equipment retry your tv controls, if tv turns on correctly problem with cable co, if not tv has corrupted data (try unplugging tv for 1 minute and then retry) ifstill bad tv has bad control board or logic problem, either one will require tv tech to fix, hope this helps, video-tek
Jun 01, 2009 | Hitachi 57F500 57" Rear Projection...
Just the one TV freezes
hello, it possible if your sharing the signal to sometimes loose reception you should have a dedicated hdtv antena or hdtv cable service for your main tv.
you can check by removing all the other sets and see,
if it happens again then you need a dedicated hd antenna or signal. this should be better for you and your hdtv reception.
Dec 17, 2008 | Vizio VU37L 37 in. LCD TV
HL-R6167W tv reception problems
Are you using a Hd cable box/directv or dishnetwork box?Or you are using your coaxial cable straight into your TV coax input?
Aug 30, 2008 | Samsung HL-R6167W 61" HDTV
HD reception
To have HD on cable, you will need an HD cable box with the HD service activated by the cable company. Some cable carriers will provide some basic HD services included in the base cost with the box.
From the HD cable box to the TV, you will need an HDMI cable between the cable box and the TV set. This is an HDTV interconnect wire. You will have to refer to the instructions on the cable box and on the TV to get everything going properly.
Jerry G.
Apr 28, 2008 | Sanyo DP26746 26 in. LCD Television
Over air reception
Unfortunately, I'm in Australia and not familiar with New York TV transmissions, however, the reception principals are the same.
Your signals are most likely bouncing off walls etc in your apartment with several 'reflections' being picked up by your indoor antenna.
This 'multipath' reception causes errors in the digital signals.
Your receiver can correct a certain amount of errors, but if there are too many, your picture will pixelate and the sound will make loud noises and then you will lose reception altogether.
The fix for this problem is connecting to a roof-mounted antenna and signal distribution system. Most apartment buildings have one, however some only distribute cable channels.
There is a possibility of a fault with your TV, but from what you describe, it sounds like a signal issue.
Have a chat to your building manager and ask what system they use for FTA reception in your building.. perhaps there's a fault that they are not aware of.
Sorry I can't be of more help.
Good luck.
Apr 22, 2008 | Televison & Video
Sanyo DP42746 42 in. Plasma Television Logo
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
