Kenmore front load washer wont spin...
I am a service tech in grants pass oregon and i am working on a kenmore front load washer mod # 417.44152400. I have done the diagnostic cycle and says that it has a bad control board. I just replaced it and now it still says i need to replace it. Code 43. Already replaced the door switch. Yes it does agitate and in the diagnostic cycle it does the final spin. Just wondering if anyone else has ran into it. (probably cause this washer is a piece of junk!!!!!!!!!) I think it may a speed controler but dont want to just replace it. A sears tech looked at before i got the washer and said it was a bad control board too. Just wondering if someone else has ran into this too. If so let me know what you did. I would like a quick fix. I dont want to spen hours to find the problem.
  • 1 more comment
  • Justin Duby
    Justin Duby Dec 10, 2008
    Thats what i thought too. thanks
  • chas1124 Jan 15, 2009
    I have this same exact problem with my same model. I found one post that said it might be the "motor" control board, not the main control board but I would like to know for sure before I spend the money on the parts. Calling Sears is absolutley worthless.
  • Justin Duby
    Justin Duby Jan 28, 2009
    If i were you i would buy a new washer. I already replaced the door switch, main control board and motor control board and it still didnt fix it. Get rid of this machine!!! its a lemon. I work at a repair shop and have ran into this before and couldnt fix this either. My friend is a sears tech and he couldnt figure it out either. I have had 4 of friends look at it (technicians) and nobody knows. Frigidaire wont help either. Sorry for the bad news.
  • 41 Answers
It's a bad wax motor inside the door latch. The diagnostics are buggy and do not test it properly. It should measure about 1.5K ohms, and when 120 VAC is applied to it, it should extend in about a minute. Part number 12002535 is $10 to $15.
To the tech that replaced the the main control board AND the latch: If the wax motor is short-circuited, maybe it blew the main control board, and then the replacement main control board.
Posted on May 14, 2009
  • Chris Goulet Jul 25, 2009
    If your bad wax motor is a 0.05A rating, replace it with a 99001807. It should measure about 1.5K ohms.
    If your bad wax motor is a 0.12A rating, replace it with a 12002535. It should measure about 1.0K ohms.
    Sergeant:
    Champion:
  • 291 Answers
Check the motor control board ,,, sound like thats what your looking at
Posted on Dec 10, 2008
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
How to fix a front load kenmore washer that won't spin?
Look under the machine
There may be a service & troubleshooting
manual in a bag, taped inside it
Aug 10, 2014 | Kenmore 3.5 cu. ft. Front Load Electric...
42936- My kenmore elite he front-load washer w/steel tub-has scrapping/unbalanced like sound coming from washer when in spin cycle, then after completed there is shredded plastic/fiberglass like mater
Sound like one of the wights has come off or is loose and damaging the drum and other parts take a under the machine and you may see the problem
Jul 29, 2014 | Kenmore Washing Machines
Kenmore washer MOD 110.24422300 SER CP4427442 the washer wont spin, it makes a harsh and loud noise when it comes onto the spin cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 20, 2010 | Kenmore 12502 Top Load Washer
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
Wont drain and wont spin
It sounds like you have a bad clutch in the washer. To diagnose this failure, you would need to pull off the washer cabinet and pull the transmission. It is likely that you would find the clutch band glazed over. It is probably not exerting enough torque to release the brake and spin the washer.
If you find this problem, you can try sanding the band to rough it up. Reassemble the washer and check for proper spin. If this fixes the problem, you will need to order and replace the clutch band.
This type of procedure is usually performed by a service technician. I don't recommend attempting this repair unless you are completely confident that you can safely perform the work.
Also check the motor drive coupler.
Mar 09, 2009 | Kenmore 44102 Front Load Washer
Wont spin at end of any cycle
I am a service technician in grants pass oregon and i had the same problem. It told me to replace the board too. I replaced the main boad, Motor control board, door switch and cleaned all the hoses and it still didnt fix it. I had 3 other service technicians look at it ( one from sears ) And nobody could figure it out.
Feb 03, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
475 people viewed this question
Top Washing Machines Experts
