No video on monitor - Computers & Internet
  • 8 more comments
  • bstockert Dec 08, 2008
    Monitor works ok when i play any animations or video I do not see the video. Works ok when i view on the laptop which is hooked up to monitor?
  • bstockert Dec 09, 2008
    I dont htink it is the computer, Reason being it is hooked up to a laptop and the normal screen works OK, I also did hook up a cheap BENQ monitor worked fine. On this computer I also have a Philips LCD tv hooked up and this works great as well. I called Honeywell and they claim since everything on the monitor works except video that it is NOT the monitor?
    Correct when i try to watch a movie i get the program up with just a blank screen where the movie should be this also happens with ANY other video files as well
    I downloaded the codecs from the post, is there something i need to change setting wise with them? Just downloading and restart did not fix the issue?
    no video with the media player classic no i do not get any errors
    Still nothing? GRRRRRRRRR
  • Anonymous Dec 09, 2008
    wmv mpeg files etc.
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    can you clarify for me what can't you do? you say everything is fine! are you trying to watch movies?
  • Lee Hodgson
    so the monitors are fine exept when you want to watch a movie?
  • Lee Hodgson
    more information please
  • 4,806 Answers
Ok, now we are clear to the problem its codecs which are missing, download and install the codecs from here:
http://www.xpcodecpack.com/download
then restart the PC, you should be able to watch all your movies from now on
post back if any problems
regards and please don't forget to rate us
Posted on Dec 09, 2008
  • 2 more comments
  • Lee Hodgson
    Lee Hodgson Dec 09, 2008
    On the desktop you will see Media player classic, try to open a movie in this.
    post back if it doesn't because you may need extra codecs
    regards
  • Lee Hodgson
    also do you get ameesage saying region code not supported?
  • Lee Hodgson
    try this:
    http://findfiles.com/list.php?string=cod...
    download and install this
    post back if any probz
  • Lee Hodgson
    Ok, lets determin what you are trying to play, is it DIVX, XVID or are you trying to play a DVD
    post back please
    President:
  • 2,692 Answers
I would first try to reinstall the PCI video card. If that did nto work , I woud substitute aother monitor to determine if it is the computer or the monitor. If still a problem I would eitherr borrow or buy an inexpensive PCI video card and try that.
Posted on Dec 08, 2008
  • Thomas F. Schneider Dec 09, 2008
    Try updating or reinstalling the video player.
What does a video card do?
The video card sends video data to the monitor. If the monitor does not display any images then the video card could be faulty.
It could also mean the monitor is faulty.
To check whether the video card or monitor is faulty, connect another monitor to your computer, if this monitor also does not displays any image then the video card is faulty.
Apr 29, 2012 | Acer Veriton M661 PC Desktop
A blue display box continually pops up with Input Select D sub DVI. I am thinking it is something to do with the monitor. What is wrong?
This monitor has two types of video inputs, a 15 pin VGA D-sub connector and a DVI connector.
If the video card has a 15 pin D-Sub then connect the video cable to the 15 pin D-Sub connector on the monitor.
If the video connectors are DVI then connect the video card and monitor with a DVI video cable.
You will also need to configure the monitor for either the D-Sub or DVI video input.
Aug 03, 2011 | BenQ FP91G+ 19" LCD Monitor
My computer monitor says no signal
Check the monitor cable between the Desktop and the monitor. Remove it and reattach it. If you have another system try connecting the monitor to it to make sure the monitor is working correctly. If you have a spare monitor cable, use it to test the monitor. If both the cable and the monitor seem to be working correctly, you have a failed video board or video section of the motherboard.
If you have a add-in video board, remove the video cable and connect it directly to the video monitor jack on the motherboard to eliminate the video board as the failed component.
If you do not have a add-in video board, you can try a add-in video board or replace the motherboard.
Let me know if you have further questions. Thanks.
Oct 22, 2010 | Computers & Internet
Why does the Little Green Light on the front of my Monitor just Blink and the Monitor will not come on ?
The monitor is not getting any "signal" from the video-card.
Check that the video-cable is connected to both the monitor and to the video-card.
Try connecting the monitor to a different desktop/laptop,
to see if the monitor works "elsewhere".
Try connecting a different monitor to your desktop, to see if the video-card is the problem.
Sep 18, 2010 | Sceptre X20g-Naga III 20.1" LCD Monitor
E176FP 17" LCD Monitor: my computer will come on but the monitor won't...
Here is what you need to do to know if your monitor is defective. Plug the power cord of the monitor. Turn on the monitor. If the monitor display image for a second and then black out then the monitor is OK. If not you will need to replace it.
If the monitor is OK.. look for other possible problem. Next to it aside from checking the cable (connecting your video card to the monitor) the one to check is the video card.. the signal from the cpu will pass through the video card to your monitor. If no reaction to the monitor then its the video card.
May 18, 2010 | Dell E176FP 17" LCD Monitor
NO VIDEO TRANSFER
only way to do this is to put a video card in the computer
or
the video itself on the computer first
then play thru your monitor.
If you got a good monitor then
get a good video card too..........
May 03, 2010 | Proview PL19Wb Monitor
My monitor keeps giving me a no signal message after i turn on my computer
  1. make sure that the video cable is properly connected between the monitor and computer
  2. change the video cable
  3. do a monitor selftest
  • turn off the monitor
  • disconnect it from the power outlet
  • disconnect it from the computer
  • turn on the monitor without the video cable
if you see the monitor information (a box with RGB white colors, the monitor is working)
  • problem might be the cable, video input port of the monitor or the video output port of the computer
Apr 10, 2010 | Acer AL1916W 19" LCD Monitor
Morning start-up of monitor takes a long time. "Analog" appears at top left, then picture goes off. After turning monitor off-on many times, monitor eventually stays on and works fine the rest of the...
This is usually caused by the video card doens't have enough power or is degraded, the video cable is bad/poor.
Connect the monitor to another computer and verify that it isn't the monitor. If so, confirm that it is the monitor. Otherwise it is the video card.
If it is embedded video card, purchase/borrow another video card and install it. If you don't replace the card, you will have to disable the embedded video for the video card to work.
Jan 24, 2010 | Samsung SyncMaster 731B 17" LCD Monitor
Monitor keeps fading.. It looses it's color capability.. Is that the video card? I barely use this monitor, and am not sure why it's dying so fast. Maybe i've had it running 100 hrs
It's either:
* the video-card
* the video-cable
* loose connections at one end of the video-cable
* bent pins where the video-cable connects to the motherboard
* bent pins where the video-cable connects to the monitor
* the monitor
Connect the monitor to the VGA-output port on a notebook computer,
and see if it holds it colours.
If it really is the monitor, then it should be under warranty.
Take it back to where you bought it, and get it replaced or repaired.
Nov 08, 2009 | Acer AL1715 17" LCD Monitor
Monitor screen turns off new monitor new video card had problem
If you've replaced the monitor with a new one, it's probably not a monitor problem. Try uninstalling the video card and use the motherboard's on-board video. If that's not working, check into getting a new motherboard. If it works fine, check the settings on your video card.
Jul 15, 2009 | Sony SDM-HS73P 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
