Question about Brother MFC-7820N Printer
Brother 7840 all in one--fax function--send fax with the page with the text facing up or down
    Champion:
  • 320 Answers
Using the adf feature face up good luck brother sr tech
Posted on Jan 24, 2009
When faxing documents on a Brother 525 fax machine do you put the item Face up or face down
If you have a Brother FAX-525DT, then place the document face down with the leading edge (top) down. The scan unit is on the bottom of the paper path for documents. The manual for the unit is available from Brother's EU division's support. The direct link is http://www.brother.com/pub/eur_fax_doc/fax515_525dt.pdf . The picture for how to position the document to be faxed is on page 55 (page 65 of the PDF).
I hope this helps.
Jan 27, 2016 | Brother Office Equipment & Supplies
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
My faxes are being received as blank page, why?
make sure the faxes you send are face down in the feeder, if you can read what you are sending they will be sent blank
Aug 17, 2010 | Brother IntelliFax-2920 Fax
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
How to fax (face up or face down)
If you put the document on the glass surface, your document should be face down. If instead you use the automatic feed on top of the machine you should place your document face up and the top of the page inside he feeder.
Hope it helps.
Aug 28, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-7840W fax will not work
Plug a regular phone into the wall jack and listen for a dial tone.
Phone cord should be connected to the LINE port of the fax.
Do you have DSL?
Unplug power cord for 10 seconds.
Oct 17, 2008 | Office Equipment & Supplies
Brother MFC-7820N Printer Logo
246 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
