Question about PfaFF Creative 7570
My pfaff 2056 sewing machine keeps scrolling through all sewing stitches over and over.
  • markpier Dec 08, 2008
    No it was not the tention.
    Genius:
  • 1,239 Answers
Hi welcome to fixya Make sure you have the machine set on straight stitch and if you have a three needle position make sure it is in the centre, if you have a three position needle and it is in the centre but the needle is not, take the top off the machine and you will see two adjusting screws on the lever, you can slacken those screws off and move the needle to where you want it, if you do not have a three position needle you will find the adjusting screw on the needle bar itself which will adjust the needle bar when you slacken it off because it is a concentric screw.
Posted on Dec 08, 2008
    Sergeant:
    Champion:
  • 304 Answers
a foot controller to output a start/stop instruction and a rotation speed instruction of a sewing machine motor to a control unit to control the sewing machine motor, a plug to disconnectably connect the foot controller to the control unit and a contact failure detection unit to detect a contact failure of the connector between the plug and the control unit.
let me know
    Sergeant:
  • 399 Answers
Remove the needle and readjust the thread and bobbin again properly.also check out the lower belt may it is slightly twisted or got loose.
    Genius:
  • 1,550 Answers
It sound like a tension adjustment is required .
Adjust the tension and check out .
  • SAM ANDERSON Dec 09, 2008
    Try this following fixes
    Rethread your needle
    It may be threaded incorrect
    Reinsert your needle
    Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
    flat side away from the bobbin, but consult your machine’s manual to be sure.
    Change your needle
    Your needle may be blunt, bent, or otherwise damaged.
    Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
    thinner fabrics, smaller needles. You may also need a larger needle if
    you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit
    fabrics and a sharp needle for wovens
    And make sure your needle is appropriate for the type of thread you’re using.
    Adjust the pressure of your pressure foot
    It may be too light for your fabric.
    Change your thread
    If your upper thread and bobbin threads are different types, try using the same thread for
    both. And use a good quality, brand name thread.
    Adjust your thread tension
    It may be too tight or too loose.
    Rethread your machine
    It may be threaded incorrectly.
    Change your needle plate
    Try switching to a needle plate with a smaller hole .
    Source for the above information sewingsupport.com
The presser foot lever keeps falling down when set in the up position on my Pfaff Performance 2056. How do I fix it?
The presser foot return spring needs to be replaced, it's a inexpensive repair.
This sounds like a job for a repair shop.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 28, 2014 | PfaFF Sewing Machines
Do I need to oil the model 2056
contact pfaff sewing machine customer service and ask them if the machine has to be oiled or is self oiling...
Oct 21, 2013 | PfaFF Sewing Machines
My pfaff 2056 is about 10 yrs old. One sewing store says it needs a new power supply board. Is it worth repairing?
I suggest checking to see how much a new pfaff costs and then see how much the part for your sewing machine cost and decide which price would be better for you...
Sep 14, 2013 | PfaFF Creative 7570
Message remove thread jam under the stitch plate keeps appearing! It's clean!
After cleaning out the bobbin area, re-threading the top thread, turning my Pfaff 4.2 off and on it still said " remove thread jam under the the stitch plate". I pushed the "ok" button and it started working again.
Keeping my fingers crossed.
Aug 13, 2012 | Pfaff Creative 4.0 Sewing Machnie
The touch screen on my Pfaff 2056 went dead, what can I do to fix it myself?
Apr 26, 2012 | Sewing Machines
The bottom tension on my Pfaff 2056 sewing machine is loose and keeps jamming up.
check the top tension try a 3 or 4 but I wouldn't go any higher than 5
also put in a new needle
clean under the needle plate & in the bobbin area for loose threads & lint
make sure the thread doesn't come off the thread take up lever
make sure the bobbin is inserted correctly
Aug 10, 2011 | Sewing Machines
2056 the understitch is loose. Is this a problem wit the tension ?
Sounds like a threading problem. Thread the machine all the way to the needle but not the needle eye. Then pull on the thread and lift the presser foot up and down. You should have tension when it is down and no tension when it is up. If this is the case try sewing, should fix the problem. If this is not the case your machine will need to be adjusted buy your pfaff dealer.
Hope this helps
Mar 22, 2011 | PfaFF Hobby 4260
Pfaff 7530/ electronic problem?
Where has it been for ten years? This could have a big affect on an electronic sewing machine.
Take the machine in to a sewing machine shop for service.
Feb 22, 2010 | PfaFF Sewing Machines
Pfaff 7570 Sewing Slow
Unfortunately, this is most likely a computer board issue and there's just no way to predict if/when a board will go bad.
Your only option at this point is to take it to an authorized Pfaff dealer. If the person who serviced it was an authorized Pfaff tech, take it back to them. If not, do take it to a Pfaff dealer - non-Pfaff authorized techs are not trained on the machines.
Sorry I can't give you a simpler answer, but until this is corrected, your machine won't work properly.
Best,
Kim
Mar 18, 2008 | PfaFF Creative 7570
Sewing Machines Logo
52 people viewed this question
Top PfaFF Sewing Machines Experts
SewTechWayne
SewTechWayne
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
