Simple question does the companion 3 seriesii come multi voltage? I am 220V if I go the the USA do I need an adapter
  • 71 Answers
Yep !
Posted on Dec 08, 2008
Machine was purchased in USA what is a power supply?
USA standard is 110v. You need a "power adapter" to transform your 220v to 110v. Most US purchased electronics do not have switchable voltage.
Nov 23, 2015 | Office Equipment & Supplies
How do I use this adapter in the US with 220 voltage
is it an 220volt ac - dc adapter you could buy a 110V AC to DC adapter with the same DC Voltage and current rating
or you could buy a 110V to 220 Volt adapter
be careful with switch settings
please be aware if timing is required or electrical motors this could be a problem as usa is 60Hz and your appliciance may be designed to run at 50 Hz frequency
there are devices that can convert freq from 60hz to 50 hz
Dec 22, 2014 | Photography
Bought from usa to australia changed to recomended fuse, fuse blows as soon as turned on the unit was brand new any ideas ?
You have to check the working voltage of the adapter of you device. If it purchased from US then it will be 110V. I think the Line voltage in Australia is 220V.Also You have to check is there is any input voltage selector in the in its adaptor . If it there you have to change it to 220V. If there is no such selector then you have to buy a 220v to 110v converter .Then connect the out put of that converter to to your device. You can by this converter at any electronic spare part shope near to you. Or you have to by a new 9V 1.3Amps AC adaptor. When you going to by the converter or a new adaptor take the device. If so they will explain you how to connect the converter or adaptor . By changing a fuse you can't change the operating voltage. If The adapter is designed to use in 110V then the fuse will blow. If you change the fuse and make more experiment with it it will make the full system useless.
Aug 05, 2011 | Lexicon MX200 Multi-Effects Processor
A friend from US gave me hp netbook-1103135- is it 110 or 220v please advise thanks
It most likely has a 110V plug on the power supply; however, all you have to do is buy the appropriate 220v cable for the power supply for your country, and it should work fine on 220V.
External power supplies are designed to use either 110v or 220v -- all you have to do is change the cable or use an adapter and you're good to go.
Dec 20, 2010 | HP Computers & Internet
I wanted to purchase a Bose companion 3 set from the US through ebay. i wanted to know whether they work on 220V and if not how can I make them work at 220V.
Since this unit dose not come with power adaptor. It has direct plug in in to the port behind the sub-woofer unit and other end to the wall outlet. Is there any way to convert the power supply from UK to US (220v to 110v). For example Desktop PCs have a switch behind every desktop unit to change power from 110v to 220v or vise versa.
Anyone has any idea how to make this happen in Bose Companion 3 system.
I bought it from UK and now moved to US and I want it to work in US.
othervise use waltage adapter to use it
Aug 08, 2010 | Bose Companion 3 Computer Speakers
The transformer on my Bose Companion 3 may be dead
you need to change the adapter . there is no way you can repair
Jul 07, 2010 | Bose Companion 3 Computer Speakers
Bose Companion 5 110v/220v short circuit
The fact that everything but the power amp is still working, it could be only a fuse protecting the output that needs replacement although this fuse is probably circuit-wise after the main fuse you have already replaced and could be soldered on the board. Worst case, the output modules are blown and require replacement and depending on the power level it may be worth repairing instead of replacing.
Most modern electronic devices can be set or adapted to line voltages from 100-240 Volts and a good percentage of the devices, using the common switched mode power supply don't need any changes made by the user since they can be inherently 'auto-ranging.'
Apr 04, 2010 | Bose Companion 5 Multimedia Speaker System...
29 people viewed this question
