Question about HP LaserJet 2840 All-In-One Printer
There is a paper jam in the ADF... I have a hp 2840
I tried to pull the paper out myself, but I did not have enough leverage, and I ripped the paper. How do I get the paper out?
  • Anonymous Dec 13, 2008
    I have about 1/2 the paper still in the scanner path and do not know how to get it out. I do not want to harm any moving parts but have to get the paper out. I need to take the document feeder off first but forgot how they cliped on. It looks like it has two clips? I believe I can take the feeder down and then get to the paper? Any ideals
    Thanks
    gw
The top cover piece at the left-hand end of the ADF just lifts up. Put your fingers under the edge where the paper feeds into the ADF reader and lift gently on only the plastic cover itself. It is hinged on the leftmost outside of the reader mechanism. Once that cover is lifted then the main feed roller is exposed, and it also just swings up out of the way to the left to provide easy access to the feed path. You will likely also have to lift up the entire ADF to gain access to the flat glass flatbed read platten area to access the remainder of your original.
Posted on Dec 22, 2008
My printer displays "doc feeder jam". I have
Why dont you try remove the drum and cartridge, just try it
Jan 07, 2011 | HP LaserJet 2840 Printer
Doc. feeder jam... What's that means? N how to solve it?
Open ADF cover and check if there is paper inside/ blocking the roller or unplug/plug-in the power cable
My Artisan 810 ADF gets jam error. There is no paper there. The motor just whirls and then gives ADF jam error. My 810 is near new, less than 300 sheets printed, less than 100 scanned using...
Just fixed my problem today. It was the ADF assembly motor. The spur gear had cracked open where it can no longer grip tightly to the center rod when the motor spins. I bought a new motor assembly from CompassMicro for the total amount of $23 and my printer is back in running order like normal again. Beats taking it to a repair center and get ripped!
Sep 10, 2010 | Epson Artisan 800 All-In-One InkJet...
Printer says there is a paper jam but there isn't
: Clear the jam from paper tray 1
  1. Remove all paper from the output tray.
  2. Turn off the product.
  3. Unplug the power cord from the back of the product.
  4. Lift the output tray and then check for jammed paper in input tray 1. Use these steps to remove any jammed paper.
    1. Raise the output tray. Figure 3: Raise the output tray c01321359.gif
    2. Grasp the jammed paper and pull it out of the product, toward you.
    3. Lower the output tray.
  5. Plug the power cord back into the product.
  6. Try printing a document.
    4. Lift the product off tray 2.
    5. Remove the jammed paper from the bottom of the product or from tray 2.
    6. Reposition the product on top of tray 2.
    7. Plug the power cord back into the product.
    8. Try printing a document.
    • If the issue is resolved, do not continue troubleshooting.
    • If the issue continues, proceed to the next step.
If you would prefer to view a video with audio instructions, click here (in English).
  1. Turn off the product.
  2. Unplug the power cord from the back of the product.
  3. Remove the ADF input tray and open the ADF cover. Figure 4: Open the ADF cover c01285903.jpg
  4. Remove the jam cleanout part. With both hands, lift up on the two handles until the part unsnaps. Rotate and lift the cleanout part and then set it aside. Figure 5: Remove the jam cleanout part c01285904.jpg
  5. Lift the green lever attached to the pick mechanism and then rotate it back until it stays open. Figure 6: Lift the green lever c01285905.jpg
  6. Check the ADF paper path for jammed paper. Figure 7: Paper jammed in ADF paper path c01461018.gif
  7. Check for jammed paper where paper enters the ADF paper cleanout. Figure 8: Paper jammed as it enters the ADF paper cleanout c01461019.gif
  8. Gently remove the paper without tearing it. Figure 9: Remove the jammed paper
    • If the paper does not come out with gentle pulling, follow these instructions.
      1. Open the ADF, and then use both hands to gently loosen the paper.
      2. When the paper is free, gently pull it out.
      3. Close the ADF.
  9. Lower the green lever.
  10. Reinstall the jam cleanout part. Push down on the two tabs until the part snaps into place.
  11. Replace the ADF input tray.
    • Figure 11: Follow the correct method to attach the ADF frame c01461020.gifc01461021.gif
    • Make sure that the ADF cleanout part attachment is secure. If it is loose, push down on the two tabs until the part snaps into place.
Jun 22, 2009 | HP Officejet Pro L7680 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Paper jam hp officejet pro l7680
The full instructions are located here: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00839319&lc=en&dlc=en&cc=us&lang=en&rule=29041&product=2512009
The section you need is about halfway down the page (Step 6: Clearing the ADF)
Apr 09, 2009 | HP Officejet Pro L7680 All-In-One Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
Paper Jam HP Color LaserJet 2840
Pull out the drum cartridge by it's green handle then
look for your paper at the timing roll section-there is a plate you can lift or release to access jams.
other than that the fuser unit on the rear of the mfc can be pulled out by moving two levers.
Jun 16, 2008 | Office Equipment & Supplies
HP LaserJet 2840 All-In-One Printer Logo
438 people viewed this question
Seeker5211
Seeker5211
