Question about Linksys Wireless-G WRT54G Router
Port forwarding to 192.168.1.xx and 192.168.2.xx
My network uses both 192.168.1.xx & 192.168.2.xx the router will only allow access to 192.168.1.xx nodes. Do I require add another router and port forward to that unit and then to the 192.168.2.xx nodes or use a different router to do so?
  • 52 Answers
You have to set the ip of the router to 192.168.1.1 and the mask to 255.255.254.0 this will make the router to detect IP's from 192.168.1.2 till 192.168.2.255
please rate my solution.
Posted on Dec 08, 2008
Panasonic wj hd316a accessing through verizon router
If you're trying to access it from outside your network, you will need to setup port forwarding to whichever the recorder uses. Google "Port forward <your router model"
Mar 08, 2014 | Computers & Internet
Tip
Port Forwarding for PLAY STATION on NETGEAR routers
The following steps will help you forward ports on the NETGEAR router for Play station network (PS2, PS3, PSP). At time you can not access or play online games through your PS and in such cases you need to make sure that you have the required ports forwarded on your router as mentioned below. The below steps are applicable for NETGEAR router model WGR614, WGT624, WPN824, WNR2000, WNDR3300, WNR854T, WNR834B etc
1. Open a browser (Internet Explorer, Mozilla Firefox or Safari) on your computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router (Username = admin and Password = Password unless you have changed it).
4. Click on Port Forwarding under Advanced.
5. Click on 'Add Custom Service' button.
6. Specify any name for the service (PSN1). Select Service Type as TCP/UDP
7. Specify the Start and the End Port as 80.
8. In the server IP Address specify the ip address of the PS3.
9. Click on 'Add' button.
10. Follow the same steps to open the below ports
Start = 443 End = 443 use name as PSN2
Start = 5223 End = 5223 use name as PSN3
Start = 3478 End = 3479 use name as PSN4.
Start = 3658 End = 3658 use name as PSN5.
Start = 10070 End = 10080 use name as PSN6.
Click Apply.
These steps would allow you to access online games on your PS connected through the NETGEAR router.
on Mar 18, 2010 | NetGear WGR614 Router
How to make port forwarding on Edimax EW-7228APn
Access points does not come with port-forwarding feature. only a router/modem does that.
Jan 07, 2013 | Edimax Network EW-7228APN Wireless N 150M...
How can i configure aip w505 for att elevate internet, in order to view my qc dvr
You need to enable the virtual server settings on the AIPW505
You also need to allocate a static address to the DVR within the range of the DHCP address range.
Virtual Server Settings - Selects between enabling or disabling port
forwarding the virtual server. (Default: Disable)
? IP Address - Specifies the IP address on the local network to allow external access.
? Port Range - Specifies the port range through which traffic is
forwarded.
? Protocol - Specifies a protocol to use for port forwarding, either TCP,UDP or TCP&UDP.
? Comment - Enter a useful comment to help identify the forwarded
port service on the network..
The manual can be obtained from here
ALFA NETWORK Inc
Oct 21, 2012 | ADVANCE Alfa AIP-W505 802.11n/b/g Wireless...
I am trying to portforward azareus ip adress 192.168.0.1 dlink dir 165
Port-forwarding allows connections from the network, i.e., to TCP port #80 at the IP-address assigned to your router, to be "forwarded" (much like a switchboard operator at a university)
to any specific TCP port (but usually the identical port-number) on a SPECIFIC computer "inside" your network.
If your router is '192.168.0.1', then it probably will give-out IP-addresses like '192.168.0.100'
and '192.168.0.101', and '192.168.0.102' to the first 3 computers on your network.
So, "port-forwarding" is used to designate one of those 3 IP-addresses as the one to receive/process all the 'TCP port #80' traffic.
On the router's web-interface, on the "port-forwarding" page, just add an entry for 'TCP port #80'.
Dec 22, 2010 | Computers & Internet
How do I open ports 500, 4500, 53, and 52428 on Dell TrueMobile 2300 wireless router. Need to open them for Verizon Network Extender
1.Open the router interface by checking the default gateway
2.Under FIREWALL, you can find an option that would say "Virtual Servers"
3.Enable these ports, along with their types(TCP/UDP/Both) and assign an IP address that your Verizon Network Extender is going get( you to set that manually on the verizon device)
Save the changes and the ports will get forwarded!
**Note: In this case, DMZ under FIREWALL will NOT work!
Jan 18, 2010 | Dell Wireless 2350 Router
Settings on Linksys router for the DCS 5220 to view remotely and settings on Securicam
Configuring your Linksys router for remote desktop is a task that's needed before you can access your computer from outside the network. If you plan to connect to your remote desktop machine from the Internet, you need to configure the router to allow traffic to the PC. Linksys is a common router used on home networks for wireless and LAN configurations. Configuring your router to allow port forwarding to a remote desktop only takes a few steps through the graphical user interface.
  1. tep 1 Open your browser window and type the IP address of the router in your address bar. This opens a window for the username and password needed for access to configure the router.
  2. Step 2 Click the "Applications and Gaming" tab on the opening screen. This opens a window with a list of ports of which you can open for access on your network.
  3. Step 3 Type "Remote Desktop" in the application textbox.
  4. Step 4 Enter "3389" in the "Start" and "Stop" port ranges. This port number is specific to the remote desktop application.
  5. Step 5 Leave the value of "Both" in the protocol listbox.
  6. Step 6 Type the IP address of the internal machine on your network. The IP address is the machine running remote desktop. When traffic from the Internet reaches the router, it forwards the request to this IP address.
  7. Step 7 Check the "Enabled" checkbox and click "Save Settings."
  8. Step 8 Close the browser window.
Nov 14, 2009 | D-Link DCS-5220 Network Camera
My xbox 360 will not connect because the WEP keys are off
ahhhh using a router. You need to use a computer that can surf. Google your router model along with default user and password and ip address. should be a 192.168.xx.xx. open a website. Put the ip addy in the address bar and log in to the router. Wireless Security setting will give you the wep and network name
Oct 10, 2009 | NetGear RangeMax Dual-Band Wireless-N...
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
BEFSX41 and Microsoft PPTP
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Linksys Wireless-G WRT54G Router Logo
173 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
