Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
REAR WHEEL REMOVEAL
HOW DO I REMOVE THE REAR WHEEL FOR REPAIR
  • Anonymous Dec 23, 2008
    Same problem, can't get rear wheel off even with puller. Just leaving on until I can find out more about it. I don't see how the rim can be integrated to the transmission but who knows.
It depends on which style mower most ayp (poulan craftsman husquvarna....) are put on with a e clip they may become froze to it but can be removed. now most mtd (yard man yard machines bolens troy bilt...) have a revers thread bolt with a tapered shaft trust me i worked on theses for 10 years. why would you want to take it off anyway? everything can be done with it still on
Posted on Jan 09, 2009
How to remove a rear axle
Why would you be working on or replacing
something like that on a 27 year old vehicle
Who is going to do that type work & why.
Your just using hand tools & unbolting things that
have to come out or be removed
No step by step instructions for that
I will assume your up to your ears in rust damage, to
the body or axle components & are taking on a restoration
project.
Apr 10, 2014 | 1987 Buick Regal
1996 Mazda Protege cv axel removeal
Jack vehicle up use jackstand remove wheel seperate lower balljoint remove axle nut push thru pull strut assembly to side the use prybar between trany and axl n pop it loose n reverse
Dec 24, 2013 | 1995 Mazda Protege
Brake drum removeal and size
The maximum machining dimension is cast into the surface of the drum. On disc brakes it is cast into the rotor. Using that information you can determine the correct shoes/pads for you vehicle.
To remove the drums you simply have to remove the wheel. If the drums have never been off before remove and discard the sheet metal nuts that are over the wheel studs. They are only there to hold the drums from falling off during assembly. After that you can pry on both sides with prybars or large screwdrivers against the drum backing plate to work the drum off. I might take some effort if the shoes have worn a groove into the drums.
Dec 19, 2012 | Cars & Trucks
How to replace rear wheel bearing
I think you can take it to the near car repair shop.
_______________
car keys replacement
Oct 08, 2012 | Lincoln Town Car Cars & Trucks
Removal of rear wheel on Suzuki VL800 to repair puncture
In order to remove the rear wheel assembly, you are going to need a motorcycle lifting jack stand or similar device.
1. Stand the bike on the side stand
On the left side of the rear wheel:
2. Remove the 2 froward facing bolts.
3. Remove the allen head bolt with the wide head.
On the right side of the rear wheel:
4. Remove the brake adjuster nut on the end of the actuating lever.
5. Remove the Toque link nut at the bottom of the wheel assembly.
6. Remove the axle nut (castle nut and cotter pin).
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end.
8. Remove the axle.
9. Remove the axle from the splined drive gear and place the wheel assembly on the ground.
10. Pull the wheel assembly rearward.
Reverse the process to replace the wheel.
Jan 03, 2011 | Suzuki VL 800 Volusia Motorcycles
Removal of rear wheel to repair puncture
8. Remove the axle.
Jan 03, 2011 | 2001 Suzuki VL 800 Volusia
Stearingwheel removeal
After the wheel center is removed, remove the clip (If it has one) then the nut, and then you need a steering wheel puller! Make sure you mark where the wheel is to re-install it.
Sep 18, 2010 | Dodge Neon Cars & Trucks
Rear wheel bearing is out, how easy to repair
not easy,you will probably need a hydraulic press to remove and reset the bearings
Apr 20, 2010 | 2002 GMC Yukon Denali
How to take off the right fender off a Mitsubishi 3000gt
Removeal steps
1. Remove wheel arch liner, this is a two peice part front and back. both these need to be removed, there should be 8 screws to remove.
2. You should then have access to all fender screws. There are 10 screws to remove to allow removeal of fender. 4 under the bonnet holding the top of the fender. 2 for the front going to a bracket. 1 underneath the fender where the arch liner was. 2 under the main body of the car towards the front of the side skirts and a final one, near to the door triangle where the mirror is. The fender should then come away but there is a sealant to stop water getting in, make you you reseal when putting back on with 3M ATD, part no 8625 or similar.
Dec 15, 2009 | 1997 Mitsubishi 3000GT
How to remove front buckets from a 1998 cadillac dellvil
2 bolts in the front and two in the rear of each seat, 10 minute job, disconnect wiring under seat, take care not to break the locks on the connectors for the power seats.
Dec 19, 2008 | 1998 Cadillac DeVille
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
625 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
