Question about Cuisinart DGB-600 Coffee Maker
Turning on when plugged in lcd screen has 3 dashes with no availability to set the time or brew coffee unplugging coffemaker doesn't fix the problem
I have had this happen too. You need to unplug the unit so that it resets itself. After you re-plug it in you need to set the time. If you just reset it without setting the time it will happen again. This has happened to me a few times. Good luck!
Posted on Sep 09, 2007
SOURCE:
What does brewing time off mean
You can try the reset for the B60. I do bot understand your original What does brewing time off mean??...
1. Simultaneously press and release "small mug" and "medium mug". Immediately afterward press "menu" 3 times. (Menu is the black button under the display screen.) You should see a time 6:09 on your screen.
2. Press "menu" once. Your LCD screen should say Brew 0:00.
3. (I messed this step up like 10 times and had to unplug the machine, then replug it and start over at step one. You have to unplug if the LCD displays "auto ____". If it continues to flash "Not Ready" and "Brew" then you can just keep trying step 3). Press and hold "medium mug". While holding "medium mug" press and release "menu". Immediately after pressing "menu" (while still holding "medium mug") press "small mug". Release "small mug" and "medium mug" at the same time. This entire thing needs to be done very quickly. as soon as you release "menu" go to "small mug" and release both buttons quickly.
4. Unplug the machine (do not turn it off). Wait for 3 seconds or so. Plug it back in, turn it on and follow the instructions for priming.
Jul 02, 2014 | Keurig B60 Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
Brew lit, but "not ready" lit solid "not flashing" fix
There are 4 steps to fix this:
Aug 10, 2009 | Keurig B60 Coffee Maker
Coffee maker won't brew
This one has two AUTO dial settings - AUTO-ON and AUTO-OFF. AUTO-OFF merely keeps the hot plate warm for a fixed period of time. AUTO-ON is the one that allows your coffeemaker to go off at the pre-programmed time in the morning.
If it is set to AUTO-ON, but is not brewing at the set time, unplug the machine for longer than 20 minutes. Then plug it back in, reset the clock, reset the prog time for a time that is just a few minutes into the future, and then test the auto-on feature.
If it stil ldoes not brew, just turn the machine to brew and press on. If it brews a pot, then your problem is electrical. If it doesn't brew a pot on the regular brew setting, then you either have: A) Calcium buildup/clog, or B) a hose leak (or worse).
To rule out the calcium buildup possibility, let half a caraffe worth of vinegar sit in the water reservoir for about an hour. After the hour, turn it to brew and press on, and brew the vinegar just as if it were coffee. If the vinegar goes through, your problem is solved.
Otherwise, call Cuisinart and find out if you are still in-warranty. Thep roduct has a 3-year warranty.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart CBC-00FR 12-Cup Coffee Maker
I cannot get the auto start to turn on. The times are properly set. Does the Program green light need to be yurned on to auto start or what?
You have to set the coffemaker to AUTO-ON for it to turn on at a set time in the morning. The PROG function is merely to set the right turn-on time. Once this time is set, you must switch the coffeemake to AUTO-ON.
-Tha Mp3 Doctor
Mar 20, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
COD 4000 coffemaker is not brewing a full pot.
i had the same problem, its the screen in the clear water container is plugged...i sprayed mine out and now i have no problems. it was plugged with coffee grounds.
Nov 13, 2008 | Cuisinart Coffeemakers
Coffee maker shuts off during brew
Unplug for 20 minutes or longer, then:
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
I have a automatic grind and brew. It will only brew a full pot of coffee if I turn it on four cups. That wasn't to bad but now Ihave to unplug it to get it to come on.
Unplug for 20 minutes to fully reset, then:
-Tha Mp3 Doctor
Aug 25, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Black and decker coffee maker
what type of coffee maker? does it have a model number?
Dec 11, 2007 | Coffee Makers & Espresso Machines
Cuisinart DGB-600 Coffee Maker Logo
212 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Pierre Laplante
Steve Allison
Steve Allison
Norman Worley
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
