Question about Brother HL 1440 Laser Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
  • 1 more comment
  • Anonymous Dec 14, 2008
    Mine prints along fine then gives a red error light between sheets which switches to green just before the next sheet prints out. The prints are all just fine. Then it just stays red and shuts off the prinitng. I push the reset and it prints a few more then stops again. Then it doen't repsond to the reset . I open the cas and pull out the cartridge, reseat it and it prints some more then gives the blinking error light bizniz again.
    HL-1250 I cleared a paper jam from the back of the printer but the red light is still blinking. I've tried resetting but that didn't help. I assume that the next step is to take the printer to pieces to check that there is nothing left inside - the paper jam did tear as it came out. Does anyone have a copy of or link to a service type manual?
  • John May 11, 2010
    HL2040 BROTHER LASER PRINTER, the light-PAPER blinking after the printer tried to feed paper. Even the TRAY LAID FLAT ( it seems the motor did not have power to just lift the feeding paper tray in order to enable the roler pick up the paper ).
    This question is rather technical. I need guidance to "What is the problem of not feeding paper".
    Should I replace the Power board or Just the memory board. Or is there a way to reset this problem.
    No body would like to repair such cheap printer. But I need to know the problem even if I have to pay for the same new price just to have this printer back on.
    I highly appreciate anyone with more than expert in this printer to give me a reply.
    Thanks.
    Problem Solver:
  • 14 Answers
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Posted on Jan 07, 2009
Brother HL 20 printer paper jam light keeps blinking after jam removed
Please check paper sensor may e damage, need to relpace it on prior basis
Mar 30, 2013 | Brother HL-2040 Laser Printer
Brand: Brother Model: HL-2040 Problem: cannot print, paper error, red light blink, did not feed paper. What should i do? thanks.
pull tray out load a couple sheets look underneath and see if paper is lifted up when closing paper drawer. If the paper is not raised to the up position you have broken the tray lift mechanism and it is not worth fixing. You can jam an eraser underneath the tray to manually raise the tray to do a dodgy fix.
Feb 28, 2011 | Brother HL-2040 Laser Printer
When I turn on the printer the light paper flashes
The paper light flashing because there is some paper inside the printer. Open the front cover and remove the cartridge and look inside for the jammed paper. Remove the jammed paper and insert the cartridge , closed the front cover and switch on the printer.
It will help you to solve the problem.
Jul 22, 2010 | Brother HL-2040 Laser Printer
I have a Brother HL-2040. The "paper light is on & won't print.
Sounds like a paper jam. There's a flap at the back of the printer-once open you should be able to see if the paper is stuck there. (Exactly the problem I had yesterday-I didn't spot it at first and it nearly drove me mad! :)
Good luck,
Raf
Nov 13, 2009 | Brother HL-2040 Laser Printer
Won't print. blinking red paper light flashing
This usually means your printer is out of paper or there is a paper jam somewhere.
Mar 25, 2009 | Brother HL-2040 Laser Printer
Brother HL-2040 laser printer
Make sure to clean all the rollers you can see and make sure to check the paper sensor, and clean all rollers and paper paths with some Isopropyl Alcohol (AKA rubbing alcohol)
Sep 04, 2008 | Brother HL-2040 Laser Printer
Brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
May 05, 2008 | Brother HL-2040 Laser Printer
Printing mailing list
Sounds to me like the word doc's page size is not set to the same as your printers tray.
In word, file , page set up. page size/paper size is set to "letter" in US I think is standard, it's A4 in Oz
On printer driver check page size setting too
Contral panel, printers and faxs, RIgHT click on brother printer icon, properties, printing preferences, page size
post back
Nov 17, 2007 | Brother HL-2040 Laser Printer
Brother HL 1440 Laser Printer Logo
438 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
