Question about Nokia N78 Smartphone
Phone rings too soft for outgoing calls and soft receiving calls
When I use the nokia n78 and I make an outgoing call, it rings too softly and when someone calls and I go outside, I cannot hear them they are too soft. I have tried adjusting everything and nothing seems to help.
  • 23 Answers
You can download some high volume ringtones form the link below, these ringtones will amaze you, even I am using it in my n78 & 5800: Please rate my solution..
chopped-and-screwed
the-game-ft-lil-wayne-my-life
swagger-like-us
pink-so-what
crazy-frog
chopped-and-screwed
http://nokiafanboy.com/2008/12/20/download-free-nokia-5800-ringtones/
http://www.zedge.net/ringtones/1933/nokia-n78-ringtones/
Thanks..
Posted on Jan 03, 2009
Pl help to unlock soft bank sh 933 phone
hypersim works only in 2g mode for outgoing and incoming calls no data
Aug 05, 2014 | Cell Phones
My Nokia 701 cant make outgoing calls. Whenever I try to call someone it disconnects before it even rings and displays "No Answer"
If its a case where you can receive calls and texts, and send texts no prob but you cant call out then its a caller-id problem with your mobile service provider. Ring up the support team and have them reset your caller-id on their end. Once done, power cycle the phone and the phone shoild call outbound no problem.
Aug 19, 2013 | Nokia Lands Phones
For incoming calls the phone rings but I cannot hear the caller. The volume is set to the maximum. For outgoing call I cannot hear the ring tone nor the person receiving the call.
Sounds like you reciever speaker is out. It might be cheaper to get a new phone than fix this one. Check with out a local cell repair store to see what they charge then make an informed decision.
Sep 30, 2010 | Nokia 6131 Cellular Phone
Phone is muted...No one can hear me when I am calling, or answering a call. I can hear them fine. Phone shows "muted"?? How do you "un" mute?
Receiving Calls
1. To answer a call, touch or open the slide.
 If the slide is closed, simply slide it up.
 If the slide is closed, press the Voice
Commands key twice, then touch .
 If the slide is open and the touch buttons are
lit, touch .
NOTE If you touch Left Soft Key [Quiet] while the
phone is ringing, the ringing or vibration is muted
for that call.
NOTE If you touch Right Soft Key [Ignore] while the
phone is ringing, the call will end.
Mute Function
The Mute Function prevents the transmission of
your voice to the caller. To quickly activate Mute
touch Left Soft Key [Mute], then to unmute
touch Left Soft Key [Unmute].
NOTE! while doing this you must call someone then while talking with him touch Left Soft Key [Unmute] to Unmute
Hope it help you out ^_^
try download the manual if you loose it
http://www.cellphones.ca/upload/manuals/lg-vx-8500-manual.pdf
Jul 03, 2009 | LG CHOCOLATE VX8500 Cellular Phone
How do I find the latest phone # from which I just received a call?
The 3rd or 4th soft key under the display has MENU underneath it. If you press it and use the Navigator button down, it will step to outgoing call log.
Carl
Apr 16, 2009 | Panasonic KX-T7633 Corded Phone
Nseed to reset message on answering machine
There are two models - The TRU8885 and the TRU8885-2 -
For the TRU8885 the manual PDF form >>>Click Here<<<
The solution is on page 24 + 57 It starts on Pg 24 as...
Record Greeting allows you to record a personal outgoing message (greeting) which
the answering system automatically plays when you receive a call.
1) Enter the Answring Setup menu, and then the
Record Greeting sub-menu (see "Entering the
Menu" on page 16). To record greeting press
[STA RT] appears.
2) Press the START soft key. You will hear “Record Greeting.“ The message counter
displays 30 and then begins to count down.
3) Position yourself near the base microphone and record your greeting.
4) When you are finished recording, press the STOP soft key. Your greeting will
playback for confirmation.
Selecting Your Greeting (Base only)
Select Greeting allows you to choose between the two outgoing messages, a prerecorded
message or your own greeting.
1) Enter the Answ. Setup menu, and then the
Select Greeting submenu (see "Entering the
Menu” on page 16). P lay back greetin g
appears, and the current outgoing message is
played. LCD is an example if you recorded your greeting.
2) Once you have recorded a personal greeting, press the CHANGE soft key to
choose the greeting. The selected outgoing message is played. Each time you
press the CHANGE soft key, the phone switches the outgoing message between
the prerecorded and the personal outgoing message.
There is more on the PDF - Just ask if you need more
For the TRU8885-2 is essentially the same. The manual PDF form >>>Click Here<<<
If we need to dig further, just ask! :) We are just a mouse click away!
Thanks
Len
Mar 07, 2009 | Uniden TRU8885 Digital Answering Machine
Connectivity error
SOFT WARE NOKIA N95 CHAINS
Oct 31, 2008 | Nokia N95 Cellular Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
Have to be near fax machine to recieve fax
The Rings to Answer feature might not be set to answer after the
appropriate number of rings for your office setup.
If you have a voice mail service at the same phone number you use
for fax calls, you must receive faxes manually, not automatically. For
information on how to receive faxes manually, see receive a fax
manually from a phone
on page 48.
If you have a PC modem on the same phone line with your
HP Officejet, check to make sure that the modem’s software is not
set to receive faxes automatically. Modems with this auto fax
receive feature turned on will take over the phone line to receive all
incoming faxes, which will prevent the HP Officejet from receiving
fax calls.
If you have an answering machine on the same phone line with
your HP Officejet, you might have one of the following problems:
Your outgoing message might be too long or too loud to allow
the HP Officejet to detect fax tones, and the calling fax machine
might disconnect.
Your answering machine might not have enough quiet time after
your outgoing message to allow the HP Officejet to detect fax
tones. This problem is more common with digital answering
machines.
The following actions might help solve these problems:
a. Disconnect the answering machine and then try receiving a fax.
If faxing is successful without it, the answering machine might
be causing the problem.
b. Reconnect the answering machine and re-record your outgoing
message. Make sure the message is as short as possible (no
more than 10 seconds long), and that you speak softly and
slowly when recording it. Try again to receive a fax.
If you have a special ring pattern for your fax phone number (using
a distinctive ring service through your telephone company), make
sure that the Answer Ring Pattern feature on your HP Officejet is set
to match. For example, if the phone company has assigned your
fax number a double ring pattern, make sure Double Rings is
selected as the Answer Ring Pattern setting. For information on
changing this setting, see change the answer ring pattern
(distinctive ringing)
on page 63.
Note that some ring patterns cannot be recognized by the
HP Officejet, such as those with alternating short and long ringing
patterns. If you are having problems with a ring pattern of this type,
ask your phone company to assign a non-alternating ring pattern.
http://h10032.www1.hp.com/ctg/Manual/c00095626.pdf
May 20, 2008 | HP Officejet 4215v All-in-One Printer
Nokia N78 Smartphone Logo
168 people viewed this question
Top Nokia Computers & Internet Experts
Computer Links
Gopi Venkatesan
Gopi Venkatesan
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
